after I drive the car throughout the day running errands at first it runs fine. it seems like after the car gets hot, the accelerator pedal stops working. Car idles fine, just when I push the pedal, nothing.
Audi ran their diagnostics, had a professional mechanic looking at it with them and they confirmed the problem with the codes it gave (don't know the codes) that the the ecu was bad and wasn't putting out the correct voltage accelerator voltage. Basically ecu was trash and to replace the ecu. soooo replace the ecu with a new one... still the same issue.
has anyone experienced this that can help?
audi s4 b5 6 speed avant
