View Poll Results: Stock vs. Aftermarket Pistons
Voters
13. You may not vote on this poll
  • New OEM Pistons
    4 30.77%
  • Custom Aftermarket Forged Pistons
    9 69.23%
Results 1 to 28 of 28
    Senior Member Two Rings Butler230's Avatar
    Jul 11 2014
    New Albany, IN
    Which would you choose - stock or aftermarket piston?
    Quick Background - My 2012 A4 blew a piston at 40,000 miles and since it has a APR Stage 2 tune Audi won't cover the damage. The repairs are underway and all costs are out of pocket.
    My car is sitting at the shop with the engine pulled as I try to determine my next step. I've found new stock pistons & rings readily available for about $1,000 a set. However, I've also been searching out aftermarket options. Obviously Audi has some issues with it's pistons so I'm trying to decide if I would be better off in the long run waiting for a shop to custom manufacture a set of forged pistons for me.
    Audi changed the wrist pin in these engines in 2011 to a 23mm size, so none of the readily available aftermarket options will work. I've found a shop that can create a custom set for $650 plus an additional $150 if I wanted skit and crown coating. Lead time is 4-6 weeks and I've already been without the car for a month. Of course this is cheaper than the OEM option, but I'm hesitant to pull the trigger. Everything I've read makes me believe the forged pistons are a much better option, but I was wondering what you all might do in this instance?
    Anyone have experience with aftermarket pistons?
    Would you pay the extra $150 for coatings?
    For the purpose of resale, do you think non-OEM pistons would cause an issue?
    Lastly, does anyone know the recommended bore, stroke and compression for this pistons? These are numbers I'll need when/if I have something made.
    TIA
    2012 A4 Avant Prestige, Audi Exclusive Nogaro Blue
    Carbon Atlas Trim, APR Stage II, EC HFC, RS4 Spoiler, Alu-Kreuz, 034 Trans
    - SOLD
    My 2012 A4 Avant
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    If lead time isn't a deal breaker, forged all the way.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Veteran Member Four Rings lettuce's Avatar
    Jun 19 2015
    Boston
    I believe Mahle makes forged pistons for these motors with a 23mm wrist pin. Otherwise you can go with a 22mm and some rods. Keep in mind the machining you'll have to do on the block with aftermarket options. And if you get some made, make sure they have a stock-like dome top. Important for our direct injection motors.
    I believe stock compression ratio is 9.6:1 with an 82.5mm bore.
    B8 A4 - Eurodyne-tuned F23L - 12.6 @ 107 on 93
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    Can't you get a complete motor out of a salvage car for less money than trying to rebuild everything?
    My 2009 A4 Prem+ Build thread
    Jul 11 2014
    New Albany, IN
    Quote Originally Posted by lettuce View Post
    Thanks, I read another of your posts regarding the domed piston. I haven't found anyone offering those yet, but I'm still searching. I spoke directly with a rep from Mahle and they told me to check with Integrated Engineering. I'm awaiting a reply from them.
    Quote Originally Posted by Lambda13 View Post
    Since I want to make sure I don't install an engine with oil consumption issues, I have to try to find a late 2011 or 2012 model. There aren't many readily available, but I did find a 20,000 mile version for $5,500. Install would run nearly $2,000 so I'm looking at approximately $7,500 for a used stock engine and no idea on previous history. The rebuild is only going to cost around $4,500 and that includes upgrading to ARP head, main and rod studs, a carbon cleaning, new chain tensioners and a possible upgrade to forged pistons.
    I'd love to just drop in a new motor and be on my merry way, but unfortunately it just isn't in the budget.
    - SOLD
    My 2012 A4 Avant
    Jul 07 2012
    Boston, MA
    Quote Originally Posted by Butler230 View Post
    Hmm, I've seen a couple motors for around $2,500.
    Or better yet, 1 year warranty, multiple options, all from a 2012. A bit more, but they have a warranty.
    http://www.automotix.com/usedengines...parts-all.html
    Just some ideas for you. Choose your adventure! haha
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Since cost and resale are important just buy oe Audi, if you where going to keep it long term buy forged.
    Veteran Member Four Rings B8 S4's Avatar
    Apr 27 2014
    United States
    Bore the bitch while you have a chance!
    2013 B8.5 S4 | APR Stage 2 + DSG Tune | APR CPS | AWE Touring + Downpipes | RocEuro | H&R Coils | J-Codes | 15% Tint |
    435I 6MT - Daily
    Jul 11 2014
    New Albany, IN
    Thanks for those. I was just going off of what the shop had found for me. I honestly hadn't looked into it too much. Looks like I could do it for closer to $6K, but I think I'm still leaning towards keeping the original block.
    - SOLD
    My 2012 A4 Avant
    Jul 11 2014
    New Albany, IN
    Quote Originally Posted by B8 S4 View Post
    Don't think I'm not contemplating it. I just have to weight it all and see what options I have.
    Thanks for all the responses so far.
    - SOLD
    My 2012 A4 Avant
    Veteran Member Four Rings Dub_prime's Avatar
    Sep 10 2012
    2010 A4, 2008 Passat, 2002 GTI
    Bham AL
    I would personally go for the beefed up internals to avoid issues in the future, but the parts are readily available for the 2010. I wouldn't be able to wait for the custom Pistons to be made, but you could do the aftermarket rods and Pistons with a 21mm wrist pin, doo eet!
    Jul 11 2014
    New Albany, IN
    I talked with Integrated Engineering today and they offer an off the shelf option that includes both connecting rods and pistons. I'll also need new rod bearings too so it is definitely more expensive, but at this point I'm leaning towards going this route.
    - SOLD
    My 2012 A4 Avant
    Sep 10 2012
    Bham AL
    I just have to say, if you are spending the money to set thing right, why not spend it the right way the first time.
    Jul 11 2014
    New Albany, IN
    Quote Originally Posted by Dub_prime View Post
    I agree.
    - SOLD
    My 2012 A4 Avant
    Veteran Member Four Rings Alex1188's Avatar
    Mar 10 2013
    Forest Lake, Minnesota
    Im pretty sure IE offers only 9.5-1 compression ratio while stock is 9.6-1
    |CURRENT|01.5 S4|
    |TOTALLED|09 B8 A4 QUATTRO|EURODYNE|FRANKENTURBO F23L|
    |PAST TURBOS|IHI JH5|PROTOTYPE BW K03 BILLET WHEEL|
    - OEM IHI K03 APR STAGE 2+ V1.0-1/4 MILE TIME [email protected](-85DA)
    Veteran Member Four Rings integroid's Avatar
    Mar 01 2013
    Atlanta, GA
    There are pros and cons to forged pistons. Just make sure you know what you are getting yourself into before going the aftermarket piston route.
    If I was to put aftermarket pistons in any of my cars, the first place I would look is Mahle...specifically the 4032 pistons.
    2024 RS3 Kemora Gray
    Jul 11 2014
    New Albany, IN
    Quote Originally Posted by Alex1188 View Post
    You are correct, but I'm told this won't be an issue.
    Quote Originally Posted by integroid View Post
    I know most of the pros, what are the cons?
    As of right now (subject to change since I'm still researching) is a set of Mahle pistons, IE connecting rods, Mahle rod bearings and new OEM main bearings.
    - SOLD
    My 2012 A4 Avant
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    What would a con be? Not being an ass but I've never heard of a single con of forged pistons. Enlighten me
    Other than different expansion rate and *possible* faster ring wear, I haven't heard any complaints.
    2016 S3
    Instagram- @Thisisastickup
    Veteran Member Three Rings cybernet99's Avatar
    Sep 06 2014
    2010 A4 S-Line, 2013 MB GLK350, 2004 Yamaha R1 @AlterdA4
    Ottawa, Canada
    I bit the bullet and ordered the full IE Sport Series short block, IE Sport Series head assembly and IE intake manifold ... Another couple weeks and it should be at my shop ready to drop in. :) Can't wait!!
    I'd say go with the IE setup!
    Follow my build on IG - https://www.instagram.com/AlterdA4
    Integrated Engineering (Sport Short Block | Sport Head Assy | Intake Manifold w 4 x 890cc Injectors), BW EFR8474 Turbo, Custom 4.5" FMIC, Custom 3.5" SS Turbo back Exhaust, Tilton Racing Twin Disc clutch/PP & LWFW, 034 Billet Motor Mounts, AP Racing BBK 380(F)/330(R) floating rotors
    Mar 10 2013
    Quote Originally Posted by b6Hate4 View Post
    Different alloys will have different knock characteristics, and also different weights which can also affect knock and wear on other parts of the rotating assembly, such as wrist pins and bearings. Hence why IE offers there pistons in 9.5-1 instead of 9.6-1 like factory. So IE pistons are actually less efficient than Stock pistons.
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    There's too many replies here to quote so I'll try and sum up areas that I wanted to share my personal opinion / experience on:
    First issue - why did you blow up a piston? That should be identified first. Was it a fueling issue (95/100 it usually is)?
    If you want to "build" a motor, go with forged internals.
    Draw back on forged internals is the added noise until they warm up and the expansion like someone said. You should not drive the car around until you've givin' the motor a chance to heat up. Now, what does that mean temp wise? It's really just a few minutes to allow the cylinder walls to warm up along with the pistons themselves and getting the coolant around the motor warm all together. If you turn the key and 'go', you'll be off slightly in tolerances between the piston's skirt and cylinder walls which can sometimes be faintly heard like chatter. This will mark the piston's skirts and walls slightly; overtime will create extra wear.
    Thermal coating on top of the pistons is amazing and helps fight pre-detonation big time. Labristic coatings on the piston's skirts help with not only lubrication but also fitment into the cylinder bores. All of which needs to be spec'd out as coatings add a few thousandths of an inch. With the proper piston ring selection, cut and material, you shouldn't have faster wear unless you're really pushing the motor's cylinder pressure (meaning, big a$$ turbo).
    Why drop in a junkyard motor when you'll prolly have to 'fix that one up'? Unless its a 2012+ where it has the newer timing tensioner and later generation OE pistons which don't have oil consumption issues. That means you'll be spending more money obtaining a newer year engine.
    What lettuce said in regards to the proper crown of the piston is critical; much so that the incorrect type will cause all sorts of combustion, fueling and pre-detonation issues you'll drive the car off a cliff.
    A 9.5:1 compression ratio is lower than stock which is 9.6:1. That means, naturally, you will lose some HP because of the less 'static' compression. This can be made up for by increasing the 'dynamic compression'; aka turn up the boost! I'm not sure how a stock K03 and stock or even some tunes will handle this gap (may not make up for it).
    Different type of pistons will have different thermal characteristics which can affect pre-detonation; however, a good forged piston, made by a reputable company won't have that issue. Furthermore, adding thermal coating to the crowns of the pistons helps combat against hot spots. The wording of 'different pistons have different knock characteristics' is incorrect context as 'knock' is technically past-tense
    I posting in a different thread where the OP stated he ordered an engine from IE. Me, personally, I've built many motors. Unless I 'know' the shop and the shop is also willing to provide the full spec sheet on said motor, I will not purchase a solution from them. You are literally buying blind. There are so many things that go into the build of an engine especially when you blueprint it. Deck height/correction, bore line, main journal specs, rod pin and journal specs, pistons, piston wrist pins, weight of all of what I said and more and let's throw in the harmonic balancer.
    I wish the best of luck to ya on your purchase and build. If it was me, I wouldn't be able to sleep at night knowing it's not a complete end to end solution.
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
    Jul 11 2014
    New Albany, IN
    Thanks Allowencer - that is a lot of great information I did not know.
    We still have no idea why the piston blew. I'm not sure how we would determine that. I was just driving around town running errands. Fuel has always been 93 octane and from either Shell or Marathon stations.
    - SOLD
    My 2012 A4 Avant
    Mar 01 2013
    Atlanta, GA
    Here is a great article with pros/cons for forged and cast pistons. Like stated above, noise and shorter lifespan are the main cons.
    http://www.minimania.com/PISTONS___W...herefores_1206
    Jun 12 2013
    Got any pics? Good detailed ones? I could take a good guess based on combustion chamber, the side of the piston, the crown, details on the rings and what the cylinder wall looks like. It's kinda like CSI; figure out the murder lol
    Build Thread
    Jun 12 2013
    Oh, and to add, stock [correct] piston diameter is 62.465 mm (meaning post stage 2 oil consumption fix). How do I know? First hand:
    Build Thread
    Jul 11 2014
    New Albany, IN
    Thanks again Allowencer. I stopped by the shop today and we talked for quite a while about all of the different options. We are going to go ahead and get the parts ordered for the Mahle pistons and IE connecting rods. I have confirmed there is absolutely no damage at all to the cylinder walls thankfully.
    Here are a few pics of the damaged piston and the corresponding metal bits found mostly in the oil pump screen.
    And the carnage left behind
    - SOLD
    My 2012 A4 Avant
    Jun 12 2013
    Question #1: Did you have oil consumption stage 2 done on your car?
    Question #2: In the first 2 pics, you'll notice the right hand side of the piston, behind the skirt / next to the wrist pin, it's quite dark. Do the other 3 pistons share the same characteristics?
    Question #3: In the first pic, is that the top compression ring basically 'pressed' / flush with its own groove? Is it melted in there or can you move it / take it out? Prior to taking it out, can you take a pic or do you have a pic where the ring has its gap?
    If there is no visual evidence or even measured evidence on no damage on your cylinder walls, you're lucky! However, some of that luck has to do with the piston failing from under the crown which will allow the pieces to fall down and into the crankcase.
    From what I see here, either it's an oiling issue or something else; however, I'm almost positive the first compression ring failed and just over time the combustion and pressure within the cylinder killed the 2nd ring and the oil rings; along with taking carnage with it.
    Build Thread
    Jul 11 2014
    New Albany, IN
    Quote Originally Posted by Allowencer View Post
    Question #1 - I have a 2012, so oil consumption doesn't apply to my year from what I understand. Additionally, I have not had any oil consumption issues.
    Question #2 - Yes, a little, but not to the extent of the broken piston.
    Question #3 - I'm honestly not sure. I didn't take the piston with me. I just stopped by the shop to take a look since he had everything out. I don't have any additional pics of the piston.
    He measured the cylinder and looked everything over and no damage was evidenced. Very lucky indeed. Most of the pieces found were in the screen for the oil pump. A few were found in various parts of the crankcase. Thank goodness for gravity! He is going to remove the crank and they will be cleaning and blowing out the entire block to make sure no pieces are still wedged in anywhere.
    I'm not sure on the oiling issue, but I'm pretty sure you are correct that the first ring failed and then eventually took the others with it.
    - SOLD
    My 2012 A4 Avant
