Results 1 to 37 of 37
    Junior Member Two Rings
    Mar 13 2015
    Midwest
    2009 A4 2.0T to 2013 engine swap
    My engine has many issues - no boost from turbo, oil consumption from bad pistons/rings, and timing off. I'm thinking swapping a 2013 engine might be the best solution. This way I don't have to worry about the oil consumption issue on the swapped engine. Can anyone who has done this please chime in? I've seen a lot of theoretical discussion, but I'd like to hear of any firsthand experiences.
    Aug 06 2012
    Parker, CO
    First off ---- aren't the transmissions completely different? 6spd vs 8spd
    Vehicles: '16 VW Touareg, '13 allroad. '06 VW Touareg
    Mar 13 2015
    Midwest
    I appreciate your comment, but I'm looking for firsthand knowledge if possible. It looks like there are a few parts that need to be swapped from the old engine like the fuel injectors. It would be great to get a list of these items...
    Feb 24 2013
    CA
    Umm lol
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by Slick_B8 View Post
    Umm lol
    Subscribed.
    Established Member Two Rings thrill23's Avatar
    Apr 30 2016
    OEM Parts
    Miami, FL
    Quote Originally Posted by treginginco View Post
    Valid point
    Established Member Two Rings dbv2's Avatar
    Mar 06 2016
    To
    If you're going through all this trouble of swapping motors, I'd just suggest rebuilding your current motor and installing better internals. Less labour, less time, less headache, less wiring, less troubles in the future knowing you changed your internals. You're wasting your time doing the 8.5 swap.
    Jun 26 2009
    Bremerton WA
    Quote Originally Posted by dbv2 View Post
    Not the OP but, I am looking into doing a swap vs a rebuild as well for several reasons. In order to be somewhat timely I would want to have as many parts on hand prior to starting as I could. I fear getting into the block to find the cylinder walls scored and now having to replace the block. Others have found low mile post 2012 engines for around $1500. Everything I have researched indicates all that needs to be moved over are the intake manifold, wiring harness, the accessories bracket (due to power steering change). Add in the additional tooling and stand cost for going into a motor. The used motor will also likely have newer accessories that you upgrade for free like the head,water pump, balance shafts, timing chain, cam bridge, and oil pump. Lastly a motor out and in can be done in a day at most two. Plus you can strip spare parts to recover investment or scrap metal them.
    VMR 710's, APR software, Eurocode HFC
    Mar 06 2016
    To
    Quote Originally Posted by van462 View Post
    It's just a risk anyone would take hoping the motor thats sitting on the shops floor actually has proper compression across all 4, as well as no internal damage. It's just a risk these days I'm not willing to take, rather since the car seems as if its already not running, take the time to rebuild using proper parts and upgrade whats needed. His car isn't running by the looks of his first post, a little while longer to get things rebuilt and up to spec wouldn't hurt him in the long run vs getting an unknown motor and taking the chance that it doesn't just blow on him 6 months down the road. Been there, it sucks..
    Mar 13 2015
    Midwest
    After weighing the options, I've decided to go with a 2013 engine. I'll update this post in a couple weeks once the engine is installed. There are a few items that will be swapped from the earlier engine, and there are some others like the alternator that we'll need to use from the newer version. I might do a high flow catalytic converter while we're at it, since the oil consumption issue caused the old cat to fail.
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    I bet the body plugs are the same. All fueling parts + harness and you would probably be good to go. Audi builds their cars like lego's. All easier to swap motors around than the average person would expect.
    2016 S3
    Instagram- @Thisisastickup
    Veteran Member Four Rings Zach L's Avatar
    Feb 23 2010
    Austin, TX
    The only time transmission would matter is if you were changing from 4-cylinder to 6-cylinder. All 4-cylinder transmission bell housings are the same and will bolt up to most other 4-cylinder VW/Audi engines.
    The hardware will not be the issue here... it will no doubt just bolt in. It's the ECU and engine wiring harness that you're much more likely to have issues with and I would spend some major time investigating. The last thing you want to be doing is swapping out an engine harness.
    The newer cars use an entire different ECU made by a different company. There is a good chance of differences in the engine sensors used and the wiring to those sensors. If you encounter such differences, your best bet will be to swap the sensors any sensors from your previous engine onto the new longblock. Your goal here is basically to fool your current ECU into thinking your previous engine is still in your car.
    EDIT:
    Just checked and it's only non-US cars that have the newer Simos ECU. The US cars use the same Bosch MED17 ECU for both B8 and B8.5. This should actually be a pretty easy swap. Good luck!
    Daily Driver: B8 A4 quattro 6MT, Aruba Blue on Black, Premium Plus, Sport Package, Bang & Olufsen
    Current Projects: 2006 Cayman S 6MT • 2006 VW GTI 2.0T 6MT • 1997 VW Golf • 1982 VW Rabbit Diesel • 1972 VW Bay Window Bus
    Feb 23 2010
    Austin, TX
    A factory built and sealed engine is always preferable to a rebuilt engine, no matter how good the rebuild is. Rebuilt engines ALWAYS have more problems. I've pulled engines from low mileage junk yard cars and installed them, while knowing friends/family that have had things rebuilt. I'd take an 80k miles factory sealed engine over a 40k mile rebuilt one.
    Mar 13 2015
    Midwest
    So the 2013 engine swap is complete. It's nice to have the car back on the road...and no smoke from the tail pipes for the first time in a long while. I did a HFC too. Drives better than ever. Added bonus: it doesn't sound like a diesel anymore.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Quote Originally Posted by John Sharif View Post
    Nice job man! What was your total cost? And was there anything you learned that would be helpful to anyone else who might be considering it? Because I agree zachL that I would rather have a used factory motor than a rebuilt one.
    Veteran Member Four Rings Alex1188's Avatar
    Mar 10 2013
    Forest Lake, Minnesota
    I'm assuming this was a 2013 non E-85 complaint motor that was swapped. Should have been plug and play if so.
    Mar 13 2015
    Midwest
    I paid a shop to do it. $3100 for the 2013 engine, turbo, and alternator. $400 shipped for the 034 HFC. $2500 labor, belts, plugs, fluids, and new starter. Wasn't cheap, but it seemed like the best solution for me.
    Veteran Member Three Rings ducati's Avatar
    Sep 02 2008
    Greater Toronto Area
    John any photos of the swap.$6000 is lot of money to pump into a 2009.I would personally just got rid of it and save for 2012-13.
    Feb 23 2010
    Austin, TX
    The engine can be had for $2500 (~30-40k miles) and a swap would be fairly simple. No custom work required. It literally bolts and plugs in. Certainly a viable option if I'm in the same boat as the OP.
    Sep 19 2015
    Waynesboro, VA
    Hey there. What were the engine codes of the engines you swapped ? I have a 2010 with a trashed engine. valves stuck in pistons and that sort of thing. Looking at a swap versus rebuild. I would appreciate any advise that anyone could give. Thanks.
    Veteran Member Three Rings kt883's Avatar
    Nov 10 2010
    Stoney Creek
    Theres a shop local to me that I saw a post for and recommended a friend to go to and they did an engine swap for him. The post said they did a 2009 to 2014 engine. They also throw in rebuilt engines that they fix up the weak points on.
    Get some advice from them. They are called TSH auto, search on here for the thread
    (I'm not affiliated with these guys at all and I've never even been to the shop)
    TSH Auto Inc
    Address: 195 Oakdale Rd, North York
    Phone: (416) 533-0909
    Currently
    2015 Audi Q5 3.0TDI S-Line, Malone stage 2 with Deletes
    Previous:
    -2013 Audi S4 3.0T S-Tronic Teknik
    -2010 Audi S5 4.2L 6MT
    -2008 Audi TT 3.2L S-Tronic
    -2007 Audi A4 3.2L S-Line 6MT
    Established Member Two Rings a_brooks86's Avatar
    Jan 20 2016
    2009 Audi A4 P+, 2015 Ford Focus SE Hatchback
    Southeast Missouri
    Quote Originally Posted by speedsterman View Post
    I have a 2009 (engine code CAEB) and currently in the process of swapping in an engine from a 2013 (engine code CPMA). Ordered mine through ebay from a company called LKQ. You'll see a handful of guys on here that ordered them from the same place. I paid around $2300 for it, if I remember right, and it only has 45xxx miles. Similar to what Zach L mentioned. If you're planning on doing it yourself, it might be the best option for sourcing an engine. If you're not doing it yourself, a route like the one that John Sharif or kt883 mentioned might be the best option.
    2009 A4 2.0T Premium Plus
    - Solo Werks S1 Coilovers
    - 034Motorsport Adjustable Upper Control Arms
    - Michelin Pilot Sport A/S 3+ Tires
    - B8.5 Engine Swap (CPMA)
    - CTS Turbo Kit w/ Test Pipe
    - TR11 Intercooler
    - Eurodyne Maestro w/ K04 tune
    - Snow Performance W/M kit (yet to be installed)
    - Aluminum Charge Pipe kit (yet to be installed)
    Jul 12 2017
    Chicago, IL
    Quote Originally Posted by a_brooks86 View Post
    thanks for this! can I ask if it was listed around $2300 or if they move on the price? All the engines I see listed (2012 on) are usually more than $3000
    my CAEB has the oil consumption issue and AoA etc aren't planning on helping... so if it is relatively plug and play then the swap would be great
    Jan 20 2016
    Southeast Missouri
    Quote Originally Posted by nthreasher View Post
    This was mine. There are similar ones for the same price.
    Here, check these out. When searching, make sure the seller is LKQ. There are many like this, but here are a few.
    http://www.ebay.com/itm/2013-Audi-A4...tZQd-n&vxp=mtr
    http://www.ebay.com/itm/2013-Audi-A4...hZYn~5&vxp=mtr
    http://www.ebay.com/itm/2013-Audi-A4...VZU2mF&vxp=mtr
    - TR11 Intercooler
    Jul 12 2017
    Chicago, IL
    thanks! Realized my error... I was searching for compatible with 2009 , which would only bring up the CAEB engines, this is much better!
    Veteran Member Four Rings Frinkferta's Avatar
    Aug 27 2012
    Earth
    Did you guys use the 2013 intake manifold? Or swap the plastic one back on? I'm thinking E85 compatible...
    Jan 20 2016
    Southeast Missouri
    Quote Originally Posted by Frinkferta View Post
    We're just swapping over the plastic manifold. I don't want to have to deal with all of the extra work that would go into bringing over the E85 compatibility. It would be neat to do though.
    - TR11 Intercooler
    Jan 20 2016
    Southeast Missouri
    Ah, no problem. When I first started looking for a replacement engine, I did the same thing. It wasn't until I heard about Lettuce's build thread and went through it that I realized how easy it was to make this "incompatible" engine work like a charm.
    - TR11 Intercooler
    Jul 12 2017
    Chicago, IL
    For high mileage cars... is it worth swapping in a lower mileage transmission too? is there a point where the 'sealed for life' transmission cant have the fluid drained and filled and its easier just to get a lower mileage one and bolt it in while everything is out?
    Feb 03 2017
    NH
    Yeah there is a thread confirming the ZF8 transmission fluid should be changed around 60k
    2013 A4 Premium - [ Exhaust tips / Rubber Floor Mats ] APR Stage 2 | CR-15 | ECS Luft Technik | 034 HFC |
    Jun 27 2019
    Avon, IN
    Im thinking of swapping my 2011 a4
    Hey so I am looking at putting a 2013 engine in my 2011, do I need to put the 2013 alternator in as well or will my current one do the job? If so what else do you suggest switching out?
    Jul 16 2018
    Atlanta
    You'll need to swap the accessory bracket over since the 2013 has no power steering pump. I'd stick to the alternator from your original engine. Maybe B8.0 J533 would use the same protocol with the Valeo VR as with the Bosch VR, maybe not. If you know enough to know it'll work, or if you like walking the edge, try it out and find out. You'll also need to carry over your crank position (engine speed) sensor; the B8.5 uses a different variation from the B8.0.
    Apr 09 2023
    Hawaii
    I have a 2009 A4 with a bad 2.0t
    I am trying to find out if I can swap in a 2014 2.0t but can't seem to find any information. Does anyone know?
    Jul 16 2018
    Atlanta
    There's plenty of information on swapping a B8.5 CAE or CPM into a B8.0. forum search for CAEB swap
    Apr 09 2023
    Hawaii
    Quote Originally Posted by Smac770 View Post
    Okay, I'll search CAEB swap. Thanks. Numerous google searches only turned up this thread....
    Apr 20 2020
    '04 allroad 2.7T, '07 A4 2.0T qt, '10 A4 2.0T, '10 TT 2.0T qt, '02 Ford Ranger 3.0L.
    Chino, CA
    Good to know. That means there is a power steering pump delete option for B8.0. Right? @Smac770
    Jul 16 2018
    Atlanta
    I know I've typed it many times, that's why I know there's plenty on the B8.5 > B8.0 swap. Between the B8 A4, B8 A5, B8 Q5 forums here and at audiworld.
    If you're starting with a B8.0 CAE:
    and swapping in a B8.0 CAE, then the only thing you have to consider is the flexplate/flywheel. Does it already have the one you have, or do you need to swap your old one over.
    and swapping in a B8.5 CAE, then there's the above concern, and you also have to swap over your 2-pin engine speed sensor as well as your accessory bracket so you still have a place to mount the power steering pump.
    and swapping in a B8.5 CPM, then there's the above concerns, and then you also have to swap over your injectors and intake manifold.
    Or such; typing this off the top of my head.
