    Veteran Member Four Rings A4orce84's Avatar
    Feb 12 2004
    Austin, Texas
    Bluetooth Module - Stock microphone swap with aftermarket?
    Hey Guys,
    I've had the bluebooth module with my RNS-E for the past year or so. Whenever I use it, people I call complain that it's hard to hear me, and at times there is a lot of interference / noise. I know on the highway it seems that it's really difficult for people to hear me clearly, and it's somewhat okay on normal roads in the city (50mph or less).
    Is it possible to reposition the mic / get a better newer mic out of a newer Audi?
    Not sure what solutions are out there and what people have tried, or if B7 owners who have this option from the factory experience the same issues.
    Anyway, just looking for some opinions / advice from people with the same setup.
    --Asif
    USP CLUB MEMBER #101
    2004 A4 1.8T USP - APR Stage 2+, Mototec Sport Exhaust w/AWE downpipe, Valeo Clutch Kit, 2.0T FSI Coils, EVOMS Diverter Valve, Boosted Intake, B5 S4 Front Brakes, RNS-E + Bluetooth Module, VMR 708s (RS4 Reps), Boost Brothers FMIC, '02 OEM Sport Suspension + B5 Front Perches, PODi, JHM Solid Short Shifter, JHM Solid Linkage Upgrade, and a lot more stuff!
    Senior Member Three Rings 67Twisty's Avatar
    Jul 11 2015
    North Carolina
    This is common to the OEM Bluetooth. Mine sounds the same way and people comment I sound quiet on the other end. The audio level output is low and turning up the volume only has a limited effect. Probably sme thing for the mic input level. I believe you can access mic level through VagCom although I haven't tried. I've also seen where someone spliced in an aftermarket microphone and mounted in down on the steering column. They claimed it worked better than the OEM stock location but YMMV.
    Andy
    ‘17 Q7
    ‘07 Avant 6MTQ
    ‘03 525i Touring
    Established Member Two Rings L'Audi's Avatar
    Apr 06 2016
    Long Island, NY
    I have the mic for my Pioneer 80PRS in the factory location, works like a charm.
    06 Dolphin Gray tip 2.0T
    GIAC Xplus | USP Testpipe | RevMotoring Springs | 19X8.5/9.5 Niche Targa | pioneer 80PRS | Taramp's HD1200, HD8000, HD10000 | 18-Sound 6's | B&C 8's | Audiocontrol Three.1, Audiocontrol Epicenter | Clarion EQS746, MCD360
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by 67Twisty View Post
    You can turn it up in VCDS. I have OEM BT and people rarely complain they can't hear me. I get it some, but not often. If you have VCDS I'll look up what I tweaked to get more volume.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Feb 12 2004
    Austin, Texas
    I do have VCDS! Thanks mtroxel !
    Thanks,
    Asif
