Originally Posted by
irontmp
Can someone point me in the right direction to get a original ac compressor from for a great price. I have a 2016 Dodge Charger rt. I stay in the Miami, Florida area. Please.
A year or two (2) ago, I was "told", my A/C Compressor - Factory original Oct 2005 build, was "making noise", when system was fully recharged - at an Audi Dealer, (I won't go there, again).
This was their third, "try" to find why, the system charge would only last one (1) year - and failed each Summer... in AZ!
On my own, with a sniffer/uv tool, I found the "leak", that was causing the issue - in the Coil/Condenser.
I dilligently, searched for the OEM Original MFR for Audi - best I came up with - DENSO... specific to VIN...
I dilligently, collected all the VW/Audi seals, valves and OEM, (I thought), mfr parts - the Compressor was/is a DENSO - from 034 out of CA, at that time it was the most reasonable $ for what was thought to be OEM Original MFR. Still, not inexpensive.
Since the A/C Compressor replacement Work, is what I'll call - Major Work - my mechanic & I replaced the punctured Condenser, the two (2) schrader valves, the VW/Audi seals, used a Snap-On A/C "tool" (brand new...) did the evac, tests, recharge, and the compressor stayed in the box, until mine "went" - so far so good!
But, what I learned in this - DENSO, is the OEM Original MFR for, mine at least B7 S4 Avant A/C major components - specific by VIN...
The thought to be OEM Original MFR, advertised as such, Condenser - "wasn't"! The core may work fine, (and so far mine has, so far), but the mounting plate/brackets for the power steering surpentine coil, are: solid aluminum "blocks", vs. the bent metal "clips" in the pretender...
So, my mechanic and I decided, since the A/C Condenser is the "leading plane" of Road Debris, and the DENSO is the real-deal - I paid the full VW/Audi price for the real VW/Audi Condenser!
Now, it sits in a box - waiting...
WB
