Originally Posted by
van462
If you had unplugged the MAF at idle and gotten a change then it would be bad. At idle even with the engine warm the injector cycle is based off of the maps more than the MAF reading. If you had revved it with the MAF disconnected it would have been really rough (and likely a code). Without knowing your fuel trims or o2 readings it will be hard to determine if you have a failing injector. If may be spraying too little and going lean causing detonation causing spark plug damage or stuck open and turning into a flame thrower that melted the plug tip off. If you pull your plugs again directly after a short run on a cold motor (to have the injectors spraying) look for the tan/light brown and dry color shown on 3 of your plugs above. If one is still wet with gas its stuck open.
Further troubleshooting will require at least a OBD dongle and possibly a compression/leakdown test.
Yeah I revved it, with MAF disconnected and it was popping/backfiring out my exhaust when I let off throttle. So I turned it off. So yeah unlikely it's MAF then?
I pulled plugs again & all of them EXCEPT cyl 2 are black, dry/sooty looking (like I was running rich?)
I cleared codes, cranked it, re-scanned, repeated these steps a few times and code wise, it's no longer ONLY in cyl 2. Which is weird.
I get random misfire (p0300) no matter what and it'll always be paired with p0301 OR p0302... never both, it just went back n forth. I have yet to get a code for p0303 or p0304 ---
It's always just p0300 + p0301 OR p0300 + p0302...
So cyl 3 and 4 seems fine (aside from the plugs being black). But anyways yeah it gives me a p0300 for random misfire and switches back n forth from cyl 1 and 2. So it seems cyl 1 or 2 has an issue. ALSO, I don't have a light tan/brown color on ANY of my plugs. 1, 3 and 4 are black and sooty and 2 is dry and clean looking, no oil or fuel on cyl 2 but maybe I didn't look or smell hard enough.
Tomorrow I'll crank car for 10-15 seconds and check all my plugs again! So far all I can really remember is what I stated above, 1 3 and 4 being black and sooty and 2 looking okay. But maybe it was clean bc it had fuel on it. I need to check again and smell.
so I'll do that tomorrow if 1 3 and 4 are rich idk why maybe b/c I'm staying at idle and not actually driving it. And if cyl 2 is clean b/c it's being covered and cleaned with fuel. That would make sense why cyl 2 plug is clean looking, but I'm going to smell it tomorrow when I check again, thanks man!
