    May 07 2016
    Central New Jersey
    Oil leak problem, large pool of oil under intake manifold in 2008 Audi A6 3.2
    Hi all ... My car has a major oil leak issue. I found a large pool of oil when removing the intake manifold. I'm have troubling locating the source of the issue. Has anyone else experienced a similar issue? Any words of advice/guidance would be appreciated.
    My initial thoughts are the following: could the leak be coming from the oil filter housing gasket? Or possibly the oil separator valve?
    Please feel free to share your thoughts.
    Jul 17 2011
    Sin City, USA
    The oil filter housing is made of plastic and has been known to crack due to the continuous heat/cool cycles. I would hazard a guess that it may be the culprit. Inspect the gasket, base and housing thoroughly.
    '09 C6.5 A6
    Aug 04 2014
    2014 S7, 2003 A4 3.0, 2007 A6 4.2 (Sold)
    Ohio
    My 4.2 did the exact same thing. it was the gaskets between the oil filter housing and the block
    Jan 30 2014
    1st gen Q45s
    FL, USA
    this brings up an excellent point---while ECS and another outfit have aftermarket billet caps, has anyone found an aluminum housing (part that mates to the block with the o-ring style gasket)?
    that would solve this permanently.
    Registered User Four Rings Sales@DriveAuto's Avatar
    Apr 13 2012
    Clifton/Mountainside, NJ
    Yep, most likely the oil filter housing (or gasket). Common problem on the C6's.
