Results 1 to 33 of 33
    Dec 26 2015
    Portland, OR
    Creak/groan in front end when steering turned at a stop
    I have a 2007 B7S4, with 80k miles on it. When I turn the steering wheel at very low speeds (such as backing out of my garage in the morning, or parking), or while stopped - I hear a creak, or groaning noise coming from the front of the car.
    I don't have access to a lift - just a floor jack and jack stands, and I haven't been able to locate the source of the problem. It wont make the noise if the suspension is unloaded. I suspect that it may be bushings, but do not know which ones.
    Can anyone help? Is there a part in the front suspension of these cars that would typically be in need of replacement at my current mileage?
    Oct 03 2007
    New York
    Upper and lower control arms. Could be the steering rack. The description is kind of vague, but you can visually inspect the control arms for cracking/tears in the bushings.
    AKA: Eightx3
    Dec 26 2015
    Portland, OR
    Thanks Matt - I'll try and get a better look this weekend.
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    Quote Originally Posted by Matt C View Post
    Thanks I have this same issue on my B6 151k miles, going to look at that also.
    Veteran Member Four Rings Guitarmageddon's Avatar
    Oct 23 2010
    EARTH
    I had this problem almost the entire time I had the car. Control arm bushings replaced, and nothing. Brakes replaced, and nothing. It would happen while braking at low speed full lock turns. I gave up on tracking it down, nothing else seemed to be affected.
    Veteran Member Three Rings Aok303's Avatar
    Jul 11 2012
    Bicycle bicycle i want to ride my bicycle
    Lakewood-Morrison / Colorado
    how many miles. a lot over look this as a possibility but sometimes its early signs the axial need to be replaced or reworked. look for a torn boot easy answer. sometimes it does not have a torn boot. you only hear it slightly when going slow or turning when is in the starting stage. to much road noise to hear it at normal speeds untill its really bad.
    other wise sound like brushing on the control arm, pillow mounts could be worn, steering rack. or even strut bar brushing depending on what the actual sound is like
    Jan 28 2013
    18 Cadillac ATS-V 8at + 06 Acura TL 6mt + 05 Audi S4 6mt (SOLD)
    Fremont, CA
    Quote Originally Posted by Guitarmageddon View Post
    +1
    Seems to only happen when slowing down to turn into a driveway or parking spot, but not consistently enough to indicate something is damaged. My guess? There's something inherently poorly designed in there. And it's pretty embarrassing when it happens, when others are in the car or near it outside. It's like "hey that's a nice car...err WTF was that noise?!"
    Veteran Member Three Rings s4ski's Avatar
    Jul 01 2013
    2005 S4 Avant, Skiis
    Anchorage, AK
    I have heard it before, but really up ticked after I had aftermarket downpipes installed about a month ago. Clunking sound when turning sharp into a parking space at low speed. Subframe was dropped for install, maybe related.
    Oct 03 2007
    New York
    Quote Originally Posted by s4ski View Post
    A clunk is different than a groan. There are two bolts under the battery that sometimes come loose. Remove the battery and check the triple square hardware and see if they're tight. This is pretty common on the B6...
    AKA: Eightx3
    Jul 01 2013
    Anchorage, AK
    Thanks for info, I will check it out
    Dec 26 2015
    Portland, OR
    My noise is a groan - similar to a dry door hinge on an old pickup truck. It only happens when turning the steering wheel, and I can only hear it when stopped, or at extremely low speeds (walking speed).
    From the descriptions above, I'm leaning towards something in the steering system. Rack, tierod ends, bushings, etc. Going to try and get one of my daughters to turn the wheel for me while I listen this weekend and see if I can't narrow it down.
    Feb 04 2016
    London
    I'd say top mounts.
    Dec 26 2015
    Portland, OR
    What are top mounts?
    Feb 04 2016
    London
    Suspension top mounts
    Dec 26 2015
    Portland, OR
    I assume that it the top of the coil spring, where it mounts to the body?
    Dec 26 2015
    Portland, OR
    Well, I forgot that it was mothers day weekend when I said I was going to work on my car, so I didn't actually get to it.
    I did notice this morning that it groaned pretty loud when I turned around in my driveway, but when I got to work (30 miles) it made no noise at all. So it seems to only happen when cold. In fact, now that I think about it, I only hear it when the car has been sitting for at least a couple of hours.
    Veteran Member Four Rings AudiSport12's Avatar
    Feb 17 2006
    Coastal Georgia
    Power steering pump? My A6 used to do it similar to your description and that was the problem.
    2011 B8 S4
    2003 Z71 Tahoe
    2000 B5 S4 - Sold
    2001 B5 1.8TQM F21L - Sold
    2000 B5 1.8TQM - RIP
    2000 C5 4.2Q - Sold
    1997 B5 1.8TQ - Sold
    Dec 26 2015
    Portland, OR
    I just did a little testing and listening on my drive to get lunch, and I don't think that it is the pump. The noise does not vary with engine rpm. It only makes a sound while the steering wheel is turning. The noise only happens until the car is up to temp. On my drive back from lunch it didn't make any noise at all, but on the way there I cranked the wheel back and forth while stopped at a light, and it creaked/groaned every time. The noise sounds like it is coming from the general area of the steering track - right behind the firewall.
    Oct 05 2015
    Billings, MT
    My noise only seems to happen when I am turning hard, any speed, almost like I am rubbing against the sidewall, but i cannot see without lifting the vehicle up.
    Established Member Two Rings S4bro's Avatar
    Feb 17 2015
    Calgary, AB
    I have the same issue with my B7. I was quoted a steering rack by the shop, since the pump is only a few months old, and the noise does not vary with rpm
    It is only audible when i stop and turn the wheel usually to park or back into a spot.
    Oct 05 2015
    Billings, MT
    Quote Originally Posted by S4bro View Post
    Same thing I have.
    Dec 26 2015
    Portland, OR
    I checked the power steering fluid last night. It was was above the high mark when hot. I drained it back down to the correct level. Made no change to my problem.
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    Quote Originally Posted by ChevDog1 View Post
    careful with this, I think these steering systems actually like the fluid about 1-2cm above the max line on the dipstick. Don't know if that was an official bulletin or anything but mine and other people seems to have success slightly above max fill. Mine gets whiney when at 'max' or lower.
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Dec 26 2015
    Portland, OR
    I read about the fluid level. Just thought I would try putting it at the correct mark on the dipstick and see if it made any difference. I'll be adding a couple cm back to the level tonight.
    Jun 18 2009
    Phoenix, AZ
    The noise is usually from the lower control arm bushings rubbing against eachother since they're just dry rubber, they stick and release and make a groaning noise. I occasionally spray some WD40 all over them and the noise stops for a month or two.
    2017 Camaro SS 1LE
    Dec 26 2015
    Portland, OR
    Thanks for the tip! I'll give that one a shot tonight.
    Dec 26 2015
    Portland, OR
    When I got home last night, I shot some WD40 white lithium grease on both sides of each of the control arm bushings. Success - or at least mostly so. The noise is almost gone today. Just a little bit left near full steering lock. I'm going to try and pull the front wheels tonight for better access and spray it all with regular WD40 to get better penetration. I do think that I have found the problem though.
    Jun 18 2009
    Phoenix, AZ
    Nice. Yea the noise can be annoying, I always found it a little odd how the noise will start and stop randomly sometimes, but WD40 or some type of penetrating fluid usually helps.
    2017 Camaro SS 1LE
    Oct 02 2006
    Wadsworth,OH
    I get the same groan/creak from my suspension when I make slow turns. I believe it to be from outer tie rods. One of the boots has a rip (driver side) in the dust cover and that's the side I'm experiencing the noise from.
    The ball joint on the end of the tie rod is always pivoting when you turn so it would make sense if the dust boot is ripped and moisture gets inside it can begin to rust and bind up a bit which would cause the sound.
    Jason
    Oct 05 2015
    Billings, MT
    Jason
    great, i get it on both directions... Wait.. that didn't sound right at all...
    Apr 01 2016
    I changed the cv shafts on my S4, and it makes that stupid LOUD metal on metal noise. Anyone know what it could be?
    Nov 30 2014
    Dallas, TX
    I have a similar problem. I can hear a creaking sound when turning the wheel at low speed or when stationary. Sounds like a spring being stretched almost, I'll try the WD40 trick sometime soon. I have replaced all control arms and the sound is still there so it must be something else, I have always suspected something in the steering system because I bought the car with a busted power steering pump and had to replace the pump and all related hoses. I also hear a groaning noise when I am braking and turning right at the same time, anybody else have this issues? My rotors and pads are almost new but I installed "red stuff" pads and my mechanic warned me that they were pretty loud in general, they do a sort of high pitched groan when I am braking and almost at a complete stop, usually only when the brakes are hot.
    I am due for an oil change in 100 miles and my mechanic said he'd look into the creaking noise when he has her in the shop so I will post an update here soon!
    Nov 30 2014
    Dallas, TX
    Got my oil changed but unfortunately it was raining all day so the noise from the rain drowned out any noise from the car. I will try again on Monday if the weather is clear.
