Results 1 to 7 of 7
    Senior Member Three Rings Scottie2LO's Avatar
    Dec 20 2009
    02 S4 04 S4
    Montreal
    B8 S5 6 speed manual Valet mode question
    if a car was in valet mode what symptoms would it have?
    speed cut off or is that related simply to automatic cars?
    lack of instant power ?
    Veteran Member Four Rings Sgibb16's Avatar
    Jul 02 2012
    2012 A5 & 2002 Passat Wagon
    Fredericksburg, VA
    I'm pretty sure valet mode just is just giving them the key-fob without the metal key in it. That allows you to lock the glove box and trunk but I think that's it.
    2012 A5 P+ | Sports Package | 6MT | 35% Tint
    REVO Stage II | AWE Quad Exhaust | 034 HFC | E-Codes | FK Silverline Coils | JHM Short Throw Shifter | Eurocode HFIC Pipe | Roc Euro Intake
    TR8 Intercooler | CTS Silicone Hose Kit & Turbo Outlet | CR-15 Strut Brace | Alu Kreuz | S-line Front & Rear Bumper Conversion
    Dec 20 2009
    02 S4 04 S4
    Montreal
    Quote Originally Posted by Sgibb16 View Post
    my bad, I meant a car thats chipped with different options
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    You might need to specify what chip or tune you're using than, since it sounds like you're referring to something that actually manipulates the ECU to keep someone from going over a certain RPM or speed.
    The built-in valet mode on the S5 only gives you the ability to keep someone from opening the trunk.
    > Open glove box and switch on valet mode
    > Use metal key to lock glove box
    > hand valet your fob and keep the metal key - This keeps them from being able to access the trunk or glove box, assuming you've locked the glove box
    Some cars, like the Hellcat, have far better valet modes that tune down power from the factory.
    2013 Audi S5 - EPL Stg 2 E40 ECU/TCU, AWE Track 102mm, RocEuro intake, etc.
    2014 Audi Q5 S Line
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Dec 20 2009
    02 S4 04 S4
    Montreal
    Basically I dont know what chip is in the car, but it appears to be stuck in a valet mode cutting fuel pressure down to 5 bar.
    theres no check engine light, everything works just no fuel pressure... and lack fo pwoer
    Jul 02 2012
    Fredericksburg, VA
    Quote Originally Posted by Scottie2LO View Post
    You should call some tuners with your vin APR, GIAC, Etc they can tell you if yours has been tuned by them
    Dec 20 2009
    02 S4 04 S4
    Montreal
    they dont accept vin </3 gotta go to my nearest tuner
