Hi all,
i have a 06 quattro 2.0 6sp with a few mods since 2011/2012 bought the car in 08. currently it has a 3" test pipe, a BSH PCV block off plate, GIAC tune (Stock/pump/race fuel), foam ECS air filter, and ECS upgraded piston diverter valve, hi-perf ECS coil packs. all basic stuff. in last few years gas quality has dropped and now have to use octane booster or a few gallons of VIP race fuel to even use the pump tune, much less the race tune.
i love the car and it still only has 46,800 miles, US car i brought to costa rica where i live. now for my questions:
i want to do a turbo upgrade and associated requirements, with new tune for the changes. i prefer to be able to use pump gas as VIP gas here is $30 a gallon (octane additive ok), and still pass emissions inspection which i cannot right now without taking the 3" cat bypass out and pulling the BSH block of to use the PCV.
my goal is about 350-350 crank HP and prefer to have good low end and mid range as top speed don't interest me. my friends here all all over the board saying get a frankenturbo, or a chinese one (kits of $1200) other say better a tuners kit using stock mounting with a GT28RS etc.
my budget of parts is about $3K, tune and labor will be extra. also can't seem to tell from some of these kits if a HPFP upgrade is required or optional, same with the injectors to S3/ S4 or RS4?
so many variables its confusing. can those that have done this help me out here, also i want to keep driving this car another 6-8 years but it is not my primary (that is a Q5). as the motor is coming up on 50,000 what other things should be changed or upgraded, rods, rings?, head items valve train, belts etc.
i have been changing the cam follower on the fuel pump every 15,000 miles, oil every 5K miles and put ceramic pads last brake job. 2 months ago completely replaced the front and rear suspension arms and bushings to frame as our roads suck. car is very tight now.
I've seen kits from KMD tuning, JHM, ECS etc but all are different and vary greatly in price. any help advice is greatly appreciated.
thanks in advance
rick
