Results 1 to 9 of 9
    Nov 03 2011
    All Over!
    Audi Engine Weights.
    Audi engine weights, these may be helpful to some in future, a sticky in the relevant section will be nice.
    I'm putting together a list of VAG engines that are likely to find their way into the A4 B5/6/7 chassis, with their weights. I will also include some of the engine that are actually available in the B5/6/7 platform from the factory.
    Please note, these weights are dry weights, they don't include air boxes, cooling systems, intercoolers and turbos etc. Unless otherwise stated, all the weights posted are from various Audi / Volkswagen SSP's (Self Study Programmes).
    I have been unable to find data on the 1.8T 20V or the 2.4 / 2.8 30V engines, I will try getting it direct from Audi UK.
    Audi 2.7 BiTurbo V6 30V --------------------------------200kgs / 441lbs.
    Audi 4.2 V8 40V-----------------------------------------200kgs / 441lbs.
    Audi 3.7 V8 40V-----------------------------------------198kgs / 437lbs.
    Audi 2.0 I4 20V------------------------------------------129kgs / 284lbs.
    Audi 3.0 V6 30V------------------------------------------165kgs / 367lbs.
    Audi 2.8 V6 12V------------------------------------------161kgs / 355lbs.
    Audi 4.2 V8 FSI-------------------------------------------198kgs / 437lbs.
    Audi 4.2 V8 FSI "RS4"------------------------------------219kgs / 483lbs.
    Audi 2.8 V6 FSI-------------------------------------------165kgs / 367lbs.
    Audi 3.2 V6 FSI-------------------------------------------172kgs / 379lbs.
    Audi 2.5 I5 TFSI-------------------------------------------183kgs / 403lbs.
    Audi 6.0 W12 "D2 A8"------------------------------------245kgs / 540lbs.
    Audi 6.3 W12 FSI-----------------------------------------247kgs / 544lbs.
    Audi 3.0 V6 TFSI------------------------------------------190kgs / 419lbs.
    Audi 2.0 I4 TFSI-------------------------------------------144kgs / 317lbs.
    Audi 1.8 I4 TFSI-------------------------------------------144kgs / 317lbs.
    Audi 5.2 V10 FSI------------------------------------------220kgs / 485lbs.
    Audi 4.2 V8 TDI-------------------------------------------255kgs / 562lbs.
    Volkswagen 4.0 W8---------------------------------------193kgs / 425lbs.
    Audi 4.2 BiTurbo V8 40V----------------------------------230kgs / 507lbs.
    Audi 4.0 V8 TFSI------------------------------------------219kgs / 493lbs.
    Audi 4.0 V8 TFSI "D4 S8"---------------------------------224kgs / 494lbs.
    1986 Type 85 Audi 90 quattro
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    i always heard on tbe forums that the 4.2 is about 50lbs lighter than 2.7t.
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Dec 10 2013
    Borden, Ontario, Canada
    Quote Originally Posted by GrapeBandit View Post
    Add in the turbos and it is
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Nov 03 2011
    All Over!
    The TTRS 2.5 I5 is heavier than I would have thought. Factor in the turbo, intercoolers and pipe work, and it's not much lighter than the much larger 4.2 V8 40V.
    The A8 4.2 V8 TDI is a monster.
    Mar 25 2015
    Finland
    I thought that the 2.7TT weight would have included the turbos? I also read somewhere that 2.8 30V weight would be 161kg?
    How is that 2.7TT so much heavier than 2.8 30V (if that 161kg is right)?
    Nov 02 2008
    A mess.
    Grapevine,TX.
    Here are the engine weights from when I swapped the 1.8T into my car. I still have the 2.8 30V longblock, I can weigh it before I pull the heads.
    The 1.8T (AUG) fully dressed (OEM flywheel/clutch, cat, downpipe, alternator, intake, p/s pump, starter) but without the a/c weighed in at 426lbs.
    The 2.8 V6 (ATQ) with the lightweight flywheel, 4 cats, downpipes, a/c (but no starter), weighed in at 519 lbs.
    Veteran Member Four Rings nefkntym's Avatar
    Jan 30 2007
    a bunch of tools
    Monument, CO
    Great info, thanks!
    2023 Q7 - Ibis White
    2024 SQ8 - Chili Red
    So many have come and gone…
    Veteran Member Three Rings BADRVCA's Avatar
    Aug 02 2012
    b5/b6/b7
    virginia beach , VA
    Any idea how much the 2.2t AAN engine weights ? I'm assuming close to the 2.5 ?
    Nov 03 2011
    All Over!
    Quote Originally Posted by BADRVCA View Post
    Very late reply, but this thread will help many.
    The older 2.2 I5 20V turbo motor is likely to be heavier than the more modern 2.5 FSI / TFSI.
