Results 1 to 17 of 17
    Junior Member Two Rings
    Jan 16 2016
    Windshield replacement...anything I should be aware of?
    Was driving around on Sat and thought I heard something hit my windshield. Thought nothing of it at the time. Fast forward a few hours later, and there's now a huge crack creeping up half of my windshield.
    I wasn't sure what to do - if I should take it to Audi, or a glass place, or what. My family mechanic recommended I just go to Safelite, so I now have an appointment with them set up for tomorrow. I had called Audi dealer service, and they said they outsource it anyway.
    Luckily my insurance is going to cover the whole thing, with no deductible. I can't imagine how much that would have cost out of pocket.
    Is there anything I should know about going to a place like Safelite? They had a few different options for what kind of glass I needed, i.e. rain sensors, lane dept warnings, etc. My car is a 2015 - I know it has the rain sensor warning, but don't think I need the lane departure glass.
    Is the new glass they put in going to be noticeably different from the factory? Anything I should tell them to do, or not do, before they install?
    w
    Veteran Member Three Rings ALAN12186's Avatar
    Mar 30 2016
    Brick, NJ
    whatever you do make sure you get Audi OEM glass
    13 S4/6mt/SDiff/MMI/B&O/Black Ops/APR Stg2+ Ultra,SC & 187MM Crank Pulley,TB & CPS V2/APR Intake/Milltek Res GT100/TA HF Cats/FF103 19x9.5/ Vorsteiner Front Lip/E Codes/ECS Diffuser/P3-Vidi Track Pack/Bilstein B12 & H&R OE Springs/EBC Red Pads & Slotted Rotors & SS Lines F&R/Brembo Calipers/CR15/APR 7MM F&R/034 Sway/Moog Links/ECS Drivetrain Mounts/Eurocode Krez/ECS Clutch Line/034 Trans, Motor & Sub Mount/SB STG 3 Clutch/USP Slave/Enlaes Spoiler/ECS SS/Autotech HPFP/Jokerz Blower/Killer Chill
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    From what I understand, some are Acoustic. Look to see if yours is and demand the same OEM.
    Oct 14 2012
    Empty...for now...
    SE PA
    Another vote for making sure you get OEM Audi glass. Some insurance companies cover you for aftermarket glass at no charge, but may not cover you for OEM glass (i.e. you would have to pay the difference). First and foremost I would get written confirmation from your insurance company that your policy covers you for OEM Audi windshield glass. Then, once you have that confirmation in hand, have Safelite (or whichever shop you choose) confirm that they are indeed going to supply OEM Audi glass. And finally, I would recommend taking photos of the markings on your original windshield. Somewhere on there are some descriptive markings including the Audi logo and possible Audi part number for the glass. Then you have a basis for comparison to the replacement glass.
    SOLD 2015 Daytona Gray S4
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    Your policy likely does not cover OEM glass. I just had a replacement done by Safelite last weekend, and all I can say is to make sure they double or triple check that they have the right piece of glass. Side assist options change what glass you get, and what hardware mounts on your windshield. Make sure they run by VIN to ensure you get the right piece. You'll likely end up with a Pilkington EZ-Cool Acoustic piece. If you look at the windows/windshield from the factory, you will see the Pilkington name; only difference is the lack of rings. You're insurance company may be different, but mine would not let me pay the difference. It was an all or nothing thing for me; aftermarket vs. OEM. It bothered me at first, but I guess I have to ask you what the difference is? Other than the rings, I would really like to hear/see what the difference is.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by ALAN12186 View Post
    +1. You have to request oem glass for replacement and it will take a week or so for them to order it.
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    A rock just skipped up and Chipped mine this morning.. Going to call Geico to have them get it done at the dealer..
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    THIS x10 (seems like a lot of others agree). Got a non OE installed on my B7 A4 and it had a terrible magnifying effect on the bottom. Make sure you tell them you want Audi OE otherwise they'll just get a 3rd party.
    Jan 16 2016
    Just got off the phone with Safelite. So, they have the OEM glass, now I'm just waiting to hear back from my insurance company to see if they will cover it.
    Safelite is asking if my car has lane departure warnings. I don't believe I have that - only the blind spot monitors. Does the glass have any impact on blind spot monitors? Or is that only for land departure warnings?
    Also Safelite doesn't seem to have a way to look up the glass based on VIN, which was surprising. They just ask you what features your car has. So an ignorant person could just pick the wrong glass by accident, which doesn't seem to make sense.
    I also opted to have the replacement done at their shop, rather than with the mobile repair. Just seemed better that way.
    Senior Member Three Rings draekin13's Avatar
    Jul 14 2014
    08 GTI, 11 F-350 King Ranch
    Kennewick, Wa
    I just had mine replaced not to long ago as well, I went with a local company that the auto dealership I work at uses for replacements. As bakedziti said Pilkington makes the OEM Audi glass and that saved me a lot of cash (no insurance involved), glass is acoustic and has the grey sun shade bar at the top.
    2011 R8 v8 Manual Ice Silver
    2019 S4 Prestige Glacier White, Black Optics, S Sport
    Jan 16 2016
    Guess I got lucky - insurance company approved OEM.
    Jan 12 2010
    SE Pennsylvania
    Quote Originally Posted by s4tress View Post
    w
    Safelite has done good work for me in the past.
    But since the cost will be covered by your auto insurance, why not take it to your Audi dealer???
    I would.
    2014 S4 Prestige l Misano Red Pearl l Black Alcantara l DSG l Sport Diff l Carbon Inlays l 034 Solid Rear Sway bar w/ Moog End Links l Eurocode Trans Insert l ESC Rear Diff Inserts l CR-15 Strut Tower Brace l Uniden LRD 950 Mirror Tap l Chipwerke Pro
    Previous:
    1994 Ford Taurus SHO w/Yamaha V6, 5 Speed
    1999 Ford Mustang Cobra Convertible, Triple Black, 5 Speed
    2007 BMW 335i 6 speed l Tuned
    Jan 16 2016
    Quote Originally Posted by 4wheelpilot View Post
    I would.
    Because they told me they just outsource it anyway - and I was told they actually use Safelite! Figured Safelite does this every single day and are probably as good or better at it than the dealer. It was also just more convenient for me.
    Jul 10 2015
    SATX
    USAA covers OEM replacement but you have to ask. Also have to demand OEM from 3rd parties such as SafeLite as they likely have more profit in 3rd party and will try to give the run around and longer lead times to discourage you.
    Veteran Member Three Rings u2nelson's Avatar
    Oct 08 2012
    Home of the CR-15 brace
    Palmdale CA, United States
    USAA insurance and I used Safelite and they covered OEM no problem. I had to ask for OEM glass, they said it would take a couple days to order it or I could use their brand which was in stock. I said order it up, I want OEM. Came in two days and the replacement process was flawless, highly recommend Safelite, they do this all the time, total experts at it.
    2013 S5 6MT / Monsoon Grey / APR Stage 2+ / AWE Touring+Res DP / EC Alu-Kreuz / EC USS system sways and links / Bilstein PSS10 coilovers / SPC ADJ UCAs / Spacers H&R 5R / EC Adj Short Throw Shifter / EC TF intake / Apikol rear diff mount / O34 Trany mount insert / BC Forged RS41 19x9.5ET20/ Mich PS4S 265/35/19 / Gyrodisk 2pc rotors / CR-15 Upper Strut Tower Brace / [email protected]
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Sep 23 2006
    Las Vegas, NV
    I am currently on with Geico's glass repair and since my glass is acoustic without lane departure they said the OEM and Aftermarket was the same price.. ($213.67) I demanded OEM and they said it would take a few days but they can get it for me.. They are currently scheduling with Safelite to come out.. If you do have Geico be sure to call them instead of using the website.
