Results 1 to 26 of 26
    Feb 06 2016
    Honolulu
    Advice Removing Lower Radiator Hose On Thermostat
    Changing out my thermostat this weekend.
    Job isn't too bad but I'm stuck trying to disconnect the lower radiator hose from the thermostat.
    No matter how hard I pull it won't budge and yes, I have removed the clip.
    I even tried gently levering with a screwdriver to no avail.
    Is there any "trick" to getting it off?
    I've seen video's of guys removing other similarly connected hose and seems like they just pop off after a bit of pulling.
    Senior Member Three Rings 67Twisty's Avatar
    Jul 11 2015
    North Carolina
    No real trick for removal. I think I used a hose pick on mine. Wiggled it up and down and kept pulling until it popped off. You can use a little white lithium grease when re-installing to avoid this issue next time it needs to come off. Because of the plastic coupler at the radiator end, it's an expensive part to replace so avoid cutting it if you can.
    Andy
    ‘17 Q7
    ‘07 Avant 6MTQ
    ‘03 525i Touring
    Feb 15 2016
    Cambridge,Ontario
    squirt some silicone lube around the connection and where the clip slips around. just keep twisting and rocking , it will come ..
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Veteran Member Four Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    I confirm, no trick, do not twist.
    Wiggle and pull. A flat screw driver might help.
    I had hard time few weeks back. You have to judge the right force to not break the plastic connection.
    Feb 15 2016
    Cambridge,Ontario
    and by the way DEFINITELY replace the hard coolant pipe oring ... I thought I could put some curil T on it and id be okay .. nope .. I ended up going back in a day later to replace the oring.
    1976 Yamaha XS 360
    Feb 06 2016
    Honolulu
    Roger that.
    From all the diy's I read they all recommended replacing the o-ring so have one on hand.
    But damn! I've got to get that hose off!!! GRRRR!!!
    2005.5 A4 B7 2.0T
    Feb 15 2016
    Cambridge,Ontario
    you probably have some dried coolant fighting you . its nature is to harden up under atmosphere to prevent leaks. It will come of you rock it back and forth while pulling down.
    just don't get frustrated .. it will end in tears
    1976 Yamaha XS 360
    Oct 24 2015
    Perth, WA
    Dont use silicon on anything that can get into the engine. It doesn't burn and can cause problems. (Source: ElsaWin).
    My respray thread
    Veteran Member Four Rings b7_Andy's Avatar
    Jul 18 2015
    Scrap Transmissions!
    Ha my engine's made of silicone! JK, it's okay to use silicone spray on cooling system parts. I haven't had to pull a radiator hose off my Audi yet, but I was working on an older BMW and there was no chance that the radiator hose was going to budge. So two things: heat and and a pry bar. Now these parts are plastic so be careful how much heat you use. I held a heat gun pretty far away from the hose not to burn it. I would say that a hair dryer on the highest setting is definitely safe enough to where it will get some heat on the hose, but won't burn the plastic. I then used the bar for my jack to pry at the hose. You have to be careful not to break any plastic while prying so take your time and gently work it until it starts to budge. Of all the methods I tried (pulling, hammering), prying it with a bar was the only one that worked. Although I don't feel as credible here because this was all done on a Bimmer so I'm not sure if you'll have enough space on the A4 to pry at the hose. Once the hose starts to budge you can twist it while pulling and it will come off. I hope this helps, and I sprayed a little bit of silicone lubricant before putting the hose back on...
    Feb 15 2016
    Cambridge,Ontario
    Yeah the silicone spray lubricant will be fine. Can't really pry that one though adios a plastic collar. Just keep working it. Hot water on the outside of the connection may help too. As stated heat can do wonders I used a hose pic for the other line on there as I found that one worse.
    Oct 24 2015
    Perth, WA
    Just use something like machine grade oil.
    My respray thread
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Did you first try draining your coolant via the drain hole? All our cars have it on the lower radiator hose, except if user experiences on this forum are correct, most of ours are broken/stuck.
    Mine at least was so I had to pull the whole dam hose off which was annoying (although mine came off easily) and made a mess. Unfortunately, to fix the issue with our broken drain holes (lol), the lower rad hose has hoses crimped to it so you have to replace the whole part which costs roughly $100 I think...Anyway, I bought it and have it waiting in my garage to swap out next time I do anything with my coolant so I can just use the drain port next time instead of having the remove the whole hose....
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Feb 06 2016
    Honolulu
    Quote Originally Posted by BenMTL View Post
    I did drain the coolant but there was still residual coolant when I pulled the other two hoses.
    2005.5 A4 B7 2.0T
    Feb 15 2016
    Cambridge,Ontario
    keep at it , did you try pouring some hot water on it ? ( it would actually have worked better with the coolant still in it though as the coolant keeps that stat cold and the hot water heats up the line you are trying to get off.
    1976 Yamaha XS 360
    Veteran Member Three Rings allstock's Avatar
    Mar 19 2014
    greater sub of Chicago
    WD40 and thirty minutes worked for me. Make sure you secure it back on correctly. For some reason they pop off easily when you think connected correctly. Dead of winter after the change and I didn't correlate a cloud of steam thinking it was exhaust. At a light my engine temp started looking different then started to climb. I blew the light and hauled ass home less than a mile and killed the engine just as it got to the highest point. The freezing weather helped.
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    I gave up on it (lower hose connector) and the worthless petcock. I just pulled the T stat off and let it drain out that way.
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by B72011 View Post
    im not sure you can really give up on it when changing a stat.
    1976 Yamaha XS 360
    Oct 09 2015
    Colorado
    Put your purse down and pull! Lol Jk but seriously you just have to wiggle and pull it out
    Oct 23 2015
    Australia
    I'd just hate to have a worthless petcock,or my wife would anyways lol ! Jokes aside what you need to remove most coolant hoses is a pick or set of picks.One at 90 degrees for sure and just work it around between the hose and pipe...works every time.
    Heidi - Audi A4 B8.5 T Q S-line,7 DSG,-Ibis white- E-tuners stage 1 ecu/tcu, lowered on Vogtlands ,19"rotors,quad exhaust,S4 diffuser,full Maxton skirt kit,AEM intake,10" Android auto screen
    Jun 15 2011
    Exiled.......
    Yeah I have those, I just didnt want to break plastic. Then you're in the position of having to go to Audi and open the wallet WAY WAY WAY up for the part and wait 2-3 days or get on the net and find it for a few less $$ and wait 5 days for the part to come in. I'd rather not yank on dried up, brittle plastic and cheap by draining thru the t stat when doing the t stat.
    Now when I go to change the Tbelt in 40K and to swap to new coolant--I may have to revisit the issue with the hose petcock garbage?
    Feb 15 2016
    Cambridge,Ontario
    Put your purse down and pull! Lol Jk but seriously you just have to wiggle and pull it out"
    wow that's as bad as .. go knock on your neighbours door and see if there are any guys home that can help ..
    he'll get it ..
    1976 Yamaha XS 360
    Feb 06 2016
    Honolulu
    Thanks for all the "positive" advice!
    I'll let you guys know how it goes when I have at it again over the weekend.
    2005.5 A4 B7 2.0T
    Feb 15 2016
    Cambridge,Ontario
    We are expecting nothing less than victory !!!
    Veteran Member Four Rings Audi_509's Avatar
    May 20 2010
    2008 A4-sold. 2019 A5-sold,: '23 S5
    WA
    Or broken parts!
    Feb 06 2016
    Honolulu
    So I declare VICTORY! LOL!
    Gave the coupling area a shot of penetrating oil yesterday.
    Tried again this afternoon and after a bit of pulling and tugging the hose almost popped off by itself.
    The weird thing is that it was almost like it had to be in a perfect alignment and it just came off.
    Go figure!
    Another frustrating thing I came across is removing that stupid little "C" shaped hose that runs across the thermostat.
    It was nearly impossible to remove since the rubber had fused to the metal hose connector. Had to use a razor blade to get all the residue off.
    I'm like all of you, love the Audi.
    But I'm really surprised at the simple problems.
    My car has less than 60k on it and has had defective thermostat, cam follower going bad, cracked glovebox hinge, etc., etc.
    2005.5 A4 B7 2.0T
    Feb 15 2016
    Cambridge,Ontario
    Glad you got it done ... you are were on your way after that im sure... I am not sure what the c shaped hose is you are referring too as I didn't take any hoses off any metal lines.. But I have 1 2005.5 so maybe its a little different.
    1976 Yamaha XS 360
