Results 1 to 4 of 4
    Veteran Member Four Rings Dannydyn's Avatar
    Dec 20 2013
    Mercedes Benz ML350
    EPC light came on, and disappeared
    So Friday evening, on the way home, my EPC light came on. Car kept driving fine without any issues.
    I called the dealership from the car and they asked me to bring it in on Monday to have a take looksee...
    The thing is, I had to make a stop at a store on the way home that same evening. When I got back in the car and started the engine, the light was gone.
    It is now Sunday and the light has not come up since. So my question is: should I still take it to the dealer? I'd like to avoid these morons touching my car if at all possible....
    Thoughts?
    Sent from my Samsung Galaxy Note 4
    2014 S4 | 6MT | Estoril Blue | Lunar Alcantara | Rotors
    AWE S-Flo | Bilstein B8 | H&R OE Sport | RS4 Grille | 35% Tint
    Mar 21 2015
    Get a Ross tech cable or something to read and clear codes. Ross Tech is more specific with codes.
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    The codes should most-likely be stored even if the EPC light went away. If you're under warranty, you might as well bring it in and see what they say.
    Established Member Two Rings Swat413's Avatar
    Nov 30 2015
    2005 Audi A4 Ultrasport
    Boston, MA
    I just went through this and had it fixed under warranty. It was an oil pressure sensor, I was getting the warning "Do not exceed maximum engine speed of 4,000 RPMs". The light would randomly come on when I got on the throttle, but the fix only took the dealer one day to do.
    Current: 2018 RS3 // Ara
    Current: 2005 A4 USP // Brilliant Red
