Results 1 to 35 of 35
    Established Member Two Rings jimmysb7s4's Avatar
    Dec 15 2013
    ukiah california
    Dsg clutch slipping
    I have a 2012 s4 dsg with 79000 miles on it and about awhile back I got a code for clutch pressure to high. So I put on the rack checked fluid level it was good so I went ahead and pulled pan and did a service on it was all good till now. Yesterday I was driving and it started slipping under load on freeway In 7th gear so I shifted to 6th and no slip. Checked codes and got clutch 1 excessive slippage. Has anyone replaced there clutches and does Audi sell them separately I kno ssp has a set. Just trying to decide if I should replace trans or try ssp clutches or do stock clothes if available! Thanks!
    Dec 15 2013
    ukiah california
    Did a log with vcds this morning and when it starts slipping the pressure is at 15bar and clutch 2 goes to 13bar is that where they are supposed to be?
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Shit that's the first I've heard of dsg clutches slipping...I thought a company was selling a clutch upgrade that was good for 1000wtq. I think you'd be better off (cost wise) going with aftermarket vs oem, but check to be certain. Don't think there's a need to replace whole tranny brotha. Keep this thread updated with what happens. Good Luck!
    Will
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    I'd look into the pressure code further first. Really hard to imagine you've burnt out a clutch pack, ESPECIALLY at only 79k, but I guess anything is possible. There are DSG cars with hundreds of launches (and others with more than double your mileage) and I've never heard of any issues.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Four Rings 4RCFED's Avatar
    Aug 27 2014
    12' Audi S4 (sold), 18' Discovery HSE (V)
    Sandy Springs, GA
    Maybe a DSG tune would fix the problem?
    2012 S4 (sold)
    Veteran Member Four Rings hodrosS42001's Avatar
    Mar 18 2012
    New Jersey
    Quote Originally Posted by jimmysb7s4 View Post
    You should 'never' be under load in 6th or 7th gear.. Your putting a ton of stress on that clutch pack.
    Dec 15 2013
    ukiah california
    Ya just cruising on freeway going up hill it slips with cruise control on then I downshift to 6th gear and it goes fine for
    Dec 15 2013
    ukiah california
    And also the pressure code has not came back since I did the service on it. Just keeps coming back with code for clutch 1 slipping it could only be 2 things the clutches or mechatronics is think. And it only had 20 launches on the trans.
    Dec 15 2013
    ukiah california
    Well I went ahead after a few more tests decided to order the ssp clutches and will be swapping them out and afterwards getting the apr tcu tune
    Veteran Member Three Rings brainpan's Avatar
    Apr 11 2010
    sk8 banana
    ontario
    Have you gotten a quote on the clutch install?
    Sent from my Note 5
    Bryan
    Mar 01 2006
    Kitchener, ON
    http://www.uspmotorsports.com/AUDI-S...h-Package.html
    http://www.sspperformance.com/audi-s...h-package.html
    This should over kill the problem for you! (posted for others use)
    First time I heard of clutches slipping on the DL501...
    2023 Audi S3 / Stronic // Daytona Grey
    Past
    2018 VW Golf R // 6 MT // Deep Black Pearl
    2010 Audi S4 // Stronic // Phantom Black
    2001 Audi S4 // 6 MT // Light Silver Metallic
    Dec 15 2013
    ukiah california
    I'm gonna install clutches myself since I have my own lift at my shop. They looks pretty easy to do after looking through the repair manual. Just pull the trans and pull the front plate off trans then they are right there. And ya I haven't heard much about them slipping. But I always felt like they were getting worse like on the freeway it would feel like they were slipping when I was pushing it hard
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    so which ones are you going with?
    600 or 800 :-D
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Dec 30 2015
    Sacramento, Ca
    Any of the clutch packages will work just fine....600ft/lb package is more than sufficient as there never has, nor ever will be a s4 that makes more than +/-450wtq. Good luck brotha!
    Will
    Apr 11 2012
    some pics of the installation if you can? subbed.
    Dec 15 2013
    ukiah california
    Ya I went with the 600ft lbs one I figure it should be plenty for our cars! Ya I'll definitely be taking some pics of the install and what not! Can't wait to get them in with dsg tune
    Dec 07 2012
    Atlanta, GA
    I'd be curious to know if starting off from a stop may have some shudder due to a more grabby disk, wot shifting and launches
    Sent from my Nexus 6P using Google's ProjectFI
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by theswoleguy View Post
    When I changed the clutch packs to Alta reds in my caddy (1000ft/lb rated), there was a noticeable difference in shifts! It was quicker/grabbier than oem, never shuddered from a stop and almost gave it a dsg fart. Good shit!
    Dec 15 2013
    ukiah california
    Yesterday I pulled trans out and pulled clutch pack out and found the k1 clutch smoked. All the steel plates in the k1 clutch were black and the middle steel plate was warped. The k2 clutch had a little wear but for the most parts was pretty clean. So I installed the new ssp clutches after I soaked the discs in fluid for a hour and put the trans back in and changed the filters. When I pulled the side filter on the outside of trans it was black with metal. I also pulled the mechatronics and cleaned on the black debris off of it. Filled it and brought it up to temp and topped fluid off. Then they recommend a clutch adaptation so I did that and took it for a test drive. It shifts like it was brand new cant even tell a difference in the aftermarket clutches compared to the oem ones! Gonna drive it for a week and then get the apr tcu flash!
    Veteran Member Three Rings rubicant5x's Avatar
    Apr 05 2016
    2001 Audi S4
    Cleveland, OH
    I don't know about the aftermarket clutch packs and their HP ratings but according to this (take it with a grain of salt) https://en.wikipedia.org/wiki/Direct-shift_gearbox - the DL501 will take up to 650 ft/lbs.. The aftermarket stuff can't be bad but I would only do this if I had a nuked tranny like the OP did.
    Matt
    2018 Audi RS3
    2001 Audi S4
    Dec 15 2013
    ukiah california
    Ya only reason I did it was because mine were bad otherwise I would have never touched the trans
    Apr 05 2016
    2001 Audi S4
    Cleveland, OH
    Out of curiosity, how long did it take to drop the tranny?
    Matt
    2018 Audi RS3
    2001 Audi S4
    Nov 18 2014
    When the tranny goes on my 2015 after however many miles, is this going to essentially return it to stock (or better) performance? I'm thinking about long term ownership and what major repairs to expect if I want to run the car into the ground.
    Dec 15 2013
    ukiah california
    Quote Originally Posted by rubicant5x View Post
    I had the trans out in 2 hours with clutches out. It was easier then I thought it was gonna be book time is 9.7 to remove and replace
    Dec 07 2012
    Atlanta, GA
    How long did it take you to do the whole job?
    Any special tools?
    In the driveway/garage on your back style?
    I've done several Quattro clutches just nothing dsg
    Dec 15 2013
    ukiah california
    Any special tools?
    From start to finish it was 6 hours And I have my own shop with lift and stuff where I do side work. And no special tools other then the normal power tools and sockets in what not. In the repair manual it said needed a pulled to pull clutch but ones the cover came off the clutch pack pulled right out
    Veteran Member Three Rings skiptowncat's Avatar
    Nov 13 2014
    Manchester, England
    2015 C7.5 S6//DS1 STAGE 3//SRM INTAKES//034 X-PIPE//H&R SWAYS
    Dec 15 2013
    ukiah california
    Quote Originally Posted by skiptowncat View Post
    I saw those don't think it comes with the steel plate just the discs
    Nov 13 2014
    Manchester, England
    Must be able to get the plates somewhere as well. I think mine need replacing as well.
    Veteran Member Three Rings friskuh's Avatar
    Jul 31 2017
    Orlando
    how did the upgrade go with the tune??
    Veteran Member Three Rings uponone nogaro's Avatar
    Sep 13 2011
    01 Silver S4, 00 Noggy S4 Sport Package, B8.5 Dsg S4 Dual Pulley,240sx w/2j swap
    Bay Area CA.
    How has the ssp clutch upgrade been so far I’m in th same boat clutch 2 slippage to high i will order the ssp clutch kit as well hopefully fix my problems
    Junior Member One Ring
    Jun 25 2019
    MA
    I've got to call BS on this after having removed the trans from my S5 cab. There is absolutely no way you could remove that transmission from an S4/S5 in 2 hours. Between getting the cats off and accessing some of the bolts, it takes a fair bit of time to drop these transmissions. I agree its not hard just time consuming and sometimes requires 3 hands.
    Junior Member Two Rings
    Apr 14 2019
    Northeast, NJ
    Quote Originally Posted by Gustaf View Post
    I was thinking the same thing. And 6 hours total? You're also dealing with the driveshaft, cooler lines, draining fluid, taking apart clutch, reassembling clutch. And you'd be crazy not to replace the teflon seals, orings, various seals, pressure pipes, maybe a solenoid or two...
    Jul 05 2015
    Lower Hudson Valley
    Quote Originally Posted by jessenepywoda View Post
    F1 pit crew could do it.
    Sep 13 2011
    Bay Area CA.
    Any updates on the ssp clutch
