Results 1 to 16 of 16
    Dec 21 2013
    A7 long term reliability
    Always wanted to get an Audi and A7 fits what I need. I'm thinking of getting a second hand one and I'm curious how do they hold up long term? Anything I should bewared of?
    Thank you for your input.
    Veteran Member Four Rings name.goes.here's Avatar
    Mar 17 2012
    South of Boston
    As long as you keep up with the maintenance, should be okay. The C7 platform is generally well built.
    His: 2015 Audi A6/Quattro/Glacier White/Premium Plus/Bose/Cold Weather Package/Sport Package
    Hers: 2016 Infiniti QX50/AWD/Majestic White/Premium Plus Package
    Established Member Two Rings cooncified's Avatar
    Oct 16 2013
    Orange County
    Bought mine with 25,000 miles. I am at 55,000 now. Thermostat stuck closed at 26,000 miles, wasn't the best experience with a new to me car (on our first roadtrip). Once that was fixed the car has been rock solid and I dont regret it at all.
    Established Member Two Rings porksoda's Avatar
    Jul 07 2015
    GTA
    Quote Originally Posted by cooncified View Post
    what model year was your car?
    __________________
    C7 A6 3.0T
    Garnet Red w Nougat Interior.
    Premium Plus w Sline
    Registered Member Three Rings DoughBoyFreshLV's Avatar
    Apr 01 2014
    Las Vegas, Nv
    Quote Originally Posted by snowmuch View Post
    If you buy a used one get a cpo, warranty lasts forever and they take care of whatever you need. The thermostats will go out on these cars in the earlier models, but it's a bug they later figured out when the cars started to hit 25k miles. I just took my car in for an oil change at 39k, (I haven't been to the dealer since last may) told them to check a vibration at idle I thought might be a bad motor mount, there was 1 seat recall, back up cam went bad and some other nonsense... my car was completely finished in 1 day oil change, seat recall fixed, new back up cam, new motor mounts... I got a nice loaner, they covered all problems under audi car, oh and flushed my brake fluid for free! These are the bests cars to own / drive and their service depart is alway awesome! I also have a Mercedes, love the car but I despise the service department!! they are alway trying to milk me for money and they never go out of their way for anything! I just bought a new battery from Mercedes-Benz road side ass. back in December, the piece of shit died on me and it under warranty for 18 months, then they refused to cover it lol. I'll be trading this benz in for another audi shortly.
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    AKA: Yoshi123
    Dec 21 2013
    Quote Originally Posted by Yoshi123 View Post
    Holy...This car sounds problematic... Never had this much issues with my previous C300 C63 or 535i M combined... I'm getting audi care on this car for sure.
    Apr 02 2014
    2005 Porsche Boxster, 2006 Lexus LX470
    Upstate South Carolina
    TrueDelta is a good reference site relative to vehicle reliability and is based on repair data submitted by enrolled vehicle owners. TrueDelta solicits this information (including mileage and also if no problems were encountered) from enrolled owners quarterly.
    Cheers!
    Lou in SC (a 2014 A7 TDI owner)
    Apr 29 2016
    anchorage
    Quote Originally Posted by name.goes.here View Post
    Can you tell me when the c6 platform ended and the c7 began? Any major differences between them? Thanks, Chris
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Quote Originally Posted by chrisosowski View Post
    C6 models first arrived in 2004 as a MY2005, and ended in 2011 (with an exterior facelift for MY2009). The C7 began as a MY2012. The C6 models are quite dated now and the C7 is far better in every way.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Oct 16 2013
    Orange County
    Quote Originally Posted by porksoda View Post
    2012
    Established Member Two Rings SunDevil's Avatar
    Aug 18 2015
    Scottsdale, Arizona
    10,000 trouble free miles on my 2016 A7.
    Current: 2016 A7 Prestige. Ibis White. 20"s
    A8 Black
    996TT Arctic Silver, 6 manual .... my 1st dream car
    997cab Black, 6 manual .....utter disappointment
    997TT Guards Red, body colored grill, 6 manual
    R8 V10 2010 Blue, gated 6 manual
    Oct 22 2014
    Atlanta, GA
    ...told them to check a vibration at idle I thought might be a bad motor mount...new motor mounts...
    Did it turn out to be the motor mount causing the vibration? I'm having that in my 101K miles A7 and since it seems to be idling fine, I'm wondering if the motor mounts might need to be replaced. What's the best way to determine, other than replacing them? :)
    Veteran Member Three Rings Avned's Avatar
    Apr 20 2016
    Las Vegas
    Quote Originally Posted by SpectreGadget View Post
    I believe the A7s have active motor mounts as the S6s. I had a motor mount issue as well and if it goes bad it will throw a soft code. You can check this using a vcds cable.
    '22 RSQ8
    '13 S6 DS1 stage 4 flex fuel - SOLD
    Oct 22 2014
    Atlanta, GA
    Quote Originally Posted by Avned View Post
    I have checked an no codes, so I suppose it's not that. Thanks
    Active Member Two Rings brodie's Avatar
    Dec 27 2014
    H2 SUT|Hellion Cobra|B5 S4|C7 A6
    Columbia, MD
    It's not an A7 but I have a 2012 A6 3.0T with 123K miles on the ticker. It's been solid without any maintenance other than routine oil changes, brake pads and an AC compressor change.
    Senior Member Three Rings zoomzoom!'s Avatar
    May 28 2016
    2015 Q5 3.0T (Wife), 2000 GMC Sierra
    Richmond, VA
    My 2013 A6 has been relatively bulletproof with just over 50K miles on the clock. The only "real" service issue I had was a small electronics module on the driver side of the car....would intermittently make the window and sunroof stop working normally. Was fixed under warranty.
    Overall I'm not seeing many problems whatsoever across multiple audi forums.
    __________________
    Richmond, VA
    2018 S5 Daytona Cabrio
    2015 Q5 Ibis (Wife)
    SOLD: 2013 A6 3.0T
