Page 1 of 4 123 ... LastLast
Results 1 to 40 of 151
    Established Member Two Rings Longwolf's Avatar
    Oct 27 2005
    Gainesville, FL
    Instructions: External Video Input to MMI Screen/Phone Mirroring
    **UPDATED**
    Thanks everyone for feedback to this post, I have updated these instructions to reflect the suggestions below and the requests for additional clarification.
    With a few simple parts, you can plug and play your phone (or even iPad, Roku, Apple TV) to mirror on the dash MMI screen. I installed this on my B8.5 S5, and the results are great. There will be lots of cables/wires/adapters involved, but it is an easy job and will cost you less than $200 and only a few minutes to install. I wrote this for mirroring my iPhone 6S, but it will work with any phone that has a video out adapter. Since the folks at Apple are greedy-planned-obsolescence-proprietary-cord scumbags, the Apple Lightning-to-HDMI adapter will cost $50, where those lucky to have a Droid phone will only need to spend half of that amount.
    Car: B8.5 S5 (manual FTMFW!)
    MMI Version: 3G+ w/Nav
    Difficulty: 0.5 beer (0 beers being easy, 12 beers being a full day job)
    Time: Less than 1 play-through of the song In-A-Gadda-Da-Vida.
    Cost: $150 - $200 depending on iPhone vs. Droid.
    Why: I mostly use it to run Waze through the MMI screen when I drive long trips. Praise Jebus for Waze.
    What it will do: Mirror your phone screen to the MMI screen. Do not attempt to stream Fast & Furious to your screen, your Audi will self destruct.
    What it won’t do: Allow you to listen to FM/Sirius/Jukebox/SD card music in your Audi while the video is mirroring. This kit ports the video AND sound to your car, so for music you have to also run music off your phone. Which is fine by me since I usually stream internet radio in the car (recommend Radioparadise.com) or MP3s on the phone (recommend Porcupine Tree).
    ** Before you start: You will need to have enabled the Video-in-motion (VIM) feature on your Audi through a VAG-Com. It is an easy hack, and there are lots of FAQs/resources online about how to do it. You just need to have the Ross Tech VAG-Com cable/software , or find a friendly Audi owner who will do it for you (I enjoy helping local VW/Audi people hack their cars with my VAG-Com).
    What you'll need:
    Audi AMI RCA Cable Adapter (I bought OEM since some people had compatibility issues with the knockoff ebay/Amazon cables): LINK $80 (thanks to my friend Pierre at AoA!)
    RCA-to-HDMI Adapter: AMAZON $34
    3 RCA Male-to-Male Adapter: AMAZON $7
    Apple iPhone to HMDI out adapter: LINK $49 (if you have a droid phone, you will be able to pick up a much cheaper droid version of this part)
    Short HDMI Cable: Short HDMI Cable: AMAZON $7
    Dual Port Power Outlet: AMAZON $13
    NOTE: You need to have 2 charging cables; 1 mini USB to charge the RCA-to-HDMI converter (required for converter to work), and another that plugs into the iPhone lighting to HDMI adapter (optional, but recommended since you will want the phone to charge while mirroring). With both of those, the phone will charge while you mirror the screen.
    iPhone Lightning Extension Cable (Optional): AMAZON $33
    (be careful, cheaper generic ones will NOT work, I've tried)
    Here's a quick summary of the installation:
    Here are all the wires you need laid out:
    (note: I am not showing the Lightning extension cable that I have running through the roof of the glove box down into the ashtray for a seamless & clean install)
    Instruction Steps:
    1. In your glove box, install the Audi AMI/MMI RCA adapter.
    2. Plug the 3 RCA wires into the RCA-to-HDMI adapter (you'll need 3 of the RCA male-to-male adapters). Make sure the RCA-to-HDMI adapter switch is set to NTSC.
    3. Plug the short HDMI cable into the RCA-to-HDMI adapter, and plug the other end of the HDMI cable into the Apple iPhone Lightning-to-HDMI adapter.
    4. Plug the Apple Lightning-to-HDMI adapter into your iPhone, or what I did was install a Lightning extension cable, so you can then run the extension cable behind the glove box and down into the center console. I have my cable coming up into my ashtray so I can leave my phone there to charge while I use the adapters.
    5. Once you have it all plugged in and powered, go into the Settings menu (while in Media), and scroll down for the options to switch the input to NTSC (vs. PAL) and 16:9 aspect ratio. In my experience, the phone mirror function would not work when I used PAL and the screen would be compressed if you chose 4:3 ratio.
    Here are the wires installed in the glove box:
    If successful, you should now see this new menu option in the Media Source menu:
    Here is the phone mirroring Waze:
    Here is the phone mirroring the web:
    You can still make and receive calls as if the phone was directly connected to the MMI via the AMI Phone cable or as if the phone was connected via Bluetooth:
    One part of the install you can't see here is the iPhone cable I have running up through the roof of the glove box, under the center console and into the ashtray. Next step is for me to install a power source in the glove box so I do not have to run the 2 charging cables and dual power outlet into the ashtray power outlet. I'll get to that in the near future.
    Additional notes:
    - This setup requires that both sound and video be utilized from your phone, which means that you can't listen to XM while mirroring your phone. For me, I run Waze while also streaming music off my iPhone at the same time.
    - You can substitute other devices for the iPhone; such as a Droid phone, Roku (it's been done), Apple TV (it's been done!), iPad, etc
    Now you can impress friends/cops/lovers with your car that has Waze built in to the infotainment center.
    I cannot take any credit for discovering this; many people have posted about this before with great instructions and pictures. I am just posting my experience and lessons learned. Other resources on how to do this:
    http://www.audiworld.com/forums/audi...creen-2888656/
    http://www.audiworld.com/forums/a8-s...music-2846216/
    http://www.audiworld.com/forums/s6-c...nment-2846402/
    http://www.audizine.com/forum/showth...I+Phone+mirror
    Christian Longwolf, Gainesville, FL
    '13 Audi S5: the daily hammer
    '23 Audi allroad: the kid hauler
    '18 Audi Q5: the grocery-getter
    '07 Honda S2K: the weekend toy
    '87 Porsche 951: the other weekend toy
    '06 A4 3.2 Avant: the airport car
    '87 Mercedes 420SEL: the beater & eventual project car
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    why not just skip all the cables entirely and go with wireless mirroring...?
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
    Deactivated Three Rings
    Aug 24 2015
    Quote Originally Posted by richib86 View Post
    +1
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    You ungrateful M'effers LOL.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Apr 29 2013
    Detroit, MI
    Could you use a Chromecast for this?
    2018 S4 8AT
    2012 S4 6MT
    2006 S4 6MT
    2000 S4 6MT
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Quote Originally Posted by BaumerS4 View Post
    I think you would need a wireless network to do this.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Apr 05 2016
    Portland, OR
    Funny, I was thinking the same thing.
    Hook the chromecast up to the built in wifi as well as your phone and in theory it should work.
    Edit: Also, the chromecast works without wifi... Might just have to try this now
    Senior Member Three Rings sc117's Avatar
    May 11 2015
    2015 Audi SQ5
    NOVA
    Well done!
    Is there a way to display waze into MMI and have phone display another app? Technically it's not mirroring- more like extended display.
    Any ideas to get this functionality?
    Feb 14 2016
    East Amherst, NY
    How would this work wirelessly? I can't get my wireless to work. Not sure if I need a subscription to something to have it functional though.
    2013 Audi S4 | Monsoon Grey | DSG |
    I detail for fun --> Instagram <--
    Veteran Member Four Rings Joker S4's Avatar
    Jun 20 2014
    B8-S4/Q5
    Mid-Atlantic
    I have a hot-spot capability on my phone and trying to use Chromecast with my phone, but can't get it to work how the video on YouTube suggests. I'd love to have Chromecast in my car so I can stream to it. I'm sure I'm doing something little wrong. I don't have the HDMI adapter for my car yet anyways.
    | 2012 S4 Prestige | TI Black Optics | Monsoon Gray Metallic | Black/Magma | STUFF | TD1
    Apr 05 2016
    Portland, OR
    I believe one of the newer updates for the chromecast allows you to "stream to nearby devices" from your phone without needing a wifi connection.
    If there is enough interest on this and no one has done anything yet I might go pick everything up next week and see what I can get working.
    Nov 20 2014
    New York
    Does this work on the 3G or just 3G+ in the 2013+ models?
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Quote Originally Posted by sonic32 View Post
    X2
    2021 Audi S4, P34 Intake
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    Quote Originally Posted by blackfunk View Post
    LMAO!!!!
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Apr 22 2013
    maine
    Quote Originally Posted by NY_Quattro View Post
    Would like to know this
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    This is great! Thanks for the write up. A lot of your pictures aren't showing up for me tho. Also, I may have missed it, but you didn't link us to the rca to hdmi converter that you used.
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Nov 10 2014
    Apex, NC
    1) this only works if you have Nav
    2) if you want to do it wireless get the kivic-one
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Apr 22 2013
    maine
    Quote Originally Posted by doug97gxe View Post
    Why does it only work with nav?
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by DannyDeez View Post
    http://www.amazon.com/ViewHD-Composi...d+mini+hdmi2av
    Present:
    Sep 11 2004
    16 Q5
    Westchester, NY
    Thank you sir
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by jzinckgra View Post
    ability to watch video only works with Nav .. this is what i found from my research since i don't have nav... but the weird thing is the Kivic One Euro Car doesnt have Nav
    Present:
    Apr 22 2013
    maine
    So to be clear, this would work using Waze without factory nav? Don't care about video.
    Nov 10 2014
    Apex, NC
    yes.. full mirroring... waze .. google maps... messages... youtube... video .. anything your phone can do its just an exact mirror..
    if you're willing to take the risk on trying on a non-nav car let me know.. because i always wanted to do this
    Present:
    Apr 22 2013
    maine
    Sorry, I meant I have non nav car and wanted to know if this would still work with Waze or Google maps
    Nov 10 2014
    Apex, NC
    It's pretty much presenting a video image of your phone .. So all the apps your phone uses would work .. It doesn't care if the car had nav or not .. The big issue is will a non nav car let you present video on the screen from the ami adapter with the RCA's
    Present:
    Apr 22 2013
    maine
    Got it thanks. Doesn't look like Kivic supports Motorola phones which I have.
    Veteran Member Three Rings KRS Aaron's Avatar
    Jan 25 2011
    Evanston, IL
    Is there a non-sketchy website to buy a Kivic One through?
    2024 RS6 Performance - Nogaro Blue
    2012 S4 - Nogaro Blue
    2017 Aston Martin V12 Vantage S - Onyx Black
    1994 BMW 850 CSi - Mauritius Blue
    M2 CS Racing
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by KRS Aaron View Post
    http://car-solutions.com/en/news/kiv...-purchase.html
    http://www.amazon.com/Kivic-Wireless.../dp/B00LWQ5DNA <--- when it becomes available again
    Present:
    Jan 25 2011
    Evanston, IL
    Thanks for the links. After driving my wife's new Golf R all week, I really wish there was an OEM way to add more functionality to my MMI.
    M2 CS Racing
    Nov 10 2014
    Apex, NC
    http://www.audizine.com/forum/showth...ghlight=alpine
    currently available in Europe .. keep your fingers crossed on if it makes it to the US .. actually you can buy the European Version now but you won't get any support with it
    Quote Originally Posted by jamin_00 View Post
    Various pics of different screens this morning.
    Present:
    Jan 25 2011
    Evanston, IL
    Wow, that's awesome. My sister has an Alpine unit in her A3 that she really likes and I could definitely get on board with something like this. One of the pics shows the regular car menu so if they can pull up the drive select this is a winning solution.
    M2 CS Racing
    Nov 10 2014
    Apex, NC
    its 100% integration .. anything that's in the MMI will come up on a similar Alpine menu
    Present:
    Jan 25 2011
    Evanston, IL
    I read through the thread and it would appear that cars with Nav may not work. I shall continue my quest.
    M2 CS Racing
    May 11 2015
    2015 Audi SQ5
    NOVA
    Is it possible to set it up so only video goes into MMI but audio is via Bluetooth into MMI?
    Nov 10 2014
    Apex, NC
    oh yes sorry for the confusion.. this is for cars without Audi Navigation .. since you have Nav the original solution in this thread would work.. issue just would be it isn't wireless.. however you could run the lightning cable under the shifter to the cup holders
    Present:
    Junior Member Two Rings joeinla's Avatar
    Jul 25 2014
    B8.5 S4
    Downtown LA
    Does the original solution mentioned in this thread still require the VIM fix via VAG COM if you want to drive with screen mirror functionality?
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by joeinla View Post
    yes
    Present:
    Nov 10 2014
    Apex, NC
    HDMI is carrying video as well as Audio.. you would have to remove the red/white RCA cables then try it
    Present:
    Jun 05 2007
    Nashville, TN
    Has anyone tried this one? It's $95 HERE
    Description: Adapter for iOS and Android devices connection to car moniors. Due to RGBs output it can be connected to the OEM monitors via video interface. Allows to play video and audio on the connected monitor. Supports screens mirroring functions to display navigation, menu, applications, etc. on the connected monitor.
    Looks interesting...
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    What happens when you press the "FUN MODE" button????????????
