Results 1 to 28 of 28
    May 20 2014
    e92
    DIY: Morimoto mini H1 bixenon projectors
    Morimoto mini H1 Bixenon projectors retrofit instruction for Audi B7 Chassis.
    I had it done almost two years ago, and writing a DIY now. So, I may have missed some steps. I have tried my best to recall everything and put it together.
    Why I did it?
    -Halogens suck.
    -Factory bixenons are expensive.
    -Bixenon conversion harness is expensive.
    -Morimoto mini H1s are good projectors and you can use any HID Kit. I had some DDT tuning kit left over from my other car so I used them. But I recommend you do your research on what you want to run, if not theretrofitsource.com does have nice kits.
    Total cost:
    Cost of projector
    Cost of HID kit
    Cost of shrouds
    Cost of positap connectors
    Glue, taps, paint.
    Total time:
    At slow pace about 6 hours. I did it over the weekend, just because I wanted the paint to dry and also was doing tons or trial and error. With these pictures as a guide it should take less time.
    Do it at your own risk. I am not responsible for any personal harm or property harm caused by trying the process outlined below.
    Preparation:
    1. Remove the headlight housings from the car.
    2. Open up one headlight at a time. Use a heat gun on the edges where lens meets the housing. Be careful not to heat up the same spot for long time, it will melt the housing/lens. Pry it open carefully. Try not to drop the sticky butyl rubber on the lens and bulbs.
    Picture of lens removed:
    3. Remove the bulb caps and bulbs.
    4. Remove the bottom plastic piece by unscrewing a couple of screws. If you want to paint it this is a good time.
    Picture of painted pieces:
    5. Good time to remove the orange lens cover from the turn signals too. Cut/grind/punch or use proper way to remove them. Up to you. Phil has a proper DIY on it. Don’t forget to get the stealth bulbs if you are going this route.
    Cutting and grinding:
    1. Remove the little metal bulb cover for the low beam by pinching the tabs from inside the headlight. You will be using this hole to fish the wires from projector for bixenon high beam functionality.
    Picture of the tab:
    2. This step is necessary to make enough room for projector body to fit inside the reflector bowl properly.
    Cut/grind the bulb cover hole on the reflector to almost flat to the surface.
    Picture of uncut bulb cover piece:
    Picture of cutting process:
    Picture of final result:
    3. Remove the H7 bulb holder metal hardware with needle nose pliers.
    Cut/grind the actual bulb holder until it looks like the following picture. Don’t go gorilla on the grinding process. Take care not to grind too much, you will be in trouble if you do grind too much.
    Picture of uncut bulb holder:
    Picture after grinding/cutting:
    4. This is the sequence your hardware how it should be assembled.
    Picture of assembly sequence
    5. Assemble the projector to the reflectors. Use your judgement on how tight the screws should be. Don’t go gorilla tight on them.
    Picture of projector attached to reflector
    If you are using iris shrouds from theretrofitsource.com, the will need a bit of trimming. Grind out about 4-5mm from the wide part like so.
    Picture of original and ground shroud:
    Electrical connections:
    This part is totally up to you on how OEM like functionality you want. I wanted complete plug and play and factory functionality. So mine setup is much more complex.
    Note:
    - You should have already fished the wires from projector through the metal bulb cover hole before assembling the projector.
    - I use posi taps and electrical taps extensively. Posi taps are very useful on this kind of project.
    1. Cut the low beam wires from the connector/or just tie it somewhere if you don’t plan on re-using that connector, I use this connector for something. H1 bulbs connect to the ballast directly so no need for this connector.
    2. This step is for bi-xenon high beam functionality. Cut the signal wire (yellow) from the low beam connector. Connect the red wire for bixenon flap (coming from projector) to yellow end and black wire (coming from projector) to brown end. I already put a connector in the picture.
    Picture of cut yellow wire from the low beam connector:
    3. Connect red wire coming from the ballast end to the cut yellow wire that we cut earlier. Close off the black wire coming from the ballast end. We won’t be using that ground.
    Picture of connection to the bixenon shroud:
    What this essentially does is, use the ground from low beam wire and just the signal from the ballast end to activate bixenon high beam. When you pull/push the stalk to activate high beam, bixenons activate along with the high beam bulb. My setup is different though. I have my high bulbs set only for DRLs, more wiring is needed.
    Note: There are many ways to achieve different functionalities. What I did is to mimic the bixenon functionality along with DRLs and CH/LH function exactly as factory bixenon. I didn’t put those steps in because honestly, I did it in multiple steps and I can’t recall the signal diagrams. If I find it and someone wants it, I will upload them.
    More cutting
    1. Cut/drill/grind the holes on the headlight bulb caps just a hair smaller than the rubber washer on the h1 bulbs.
    Picture or the bulb caps cut:
    2. Use some glue like “amazing goop” to attach shroud to the concentric rings and to the projector body. Take care not to drop any glue on projector lens. Clean everything up with alcohol and assemble everything together.
    Picture of assembled units:
    Ballast mounting
    Again, there are million places to mount the ballasts. I wanted easy access and removal of the headlight as single unit, hence, this option. So I made a bracket out of zip ties.
    1. Cut the zip ties and drill small holes at the end like in the picture.
    Picture of cut and drilled zip ties
    2. Screw the zip ties on the two little holes behind the headlight housings.
    Picture of cut zip ties screwed.
    3. Put the double sided tape in the middle between the screwed zip ties and attach the ballast there. Use a third zip tie through the holes of those two and secure the ballast.
    Picture of final ballast mounting:
    Connections
    1. Mount the headlights to the car, do not secure them with the screws yet.
    2. Connect/tap the ballast end wires to the signal and ground wires at the headlight connectors.
    I use taps at the end of the connection to make life easier.
    Pictures of posi taps at the end of connectors:
    Pictures of headlight connector and ballast wires tapped to it:
    3. Connect ballast to the bulb and bixenons. Make sure everything is secured and install the headlights properly.
    Finally, clean everything up and put everything together. Snap close the lens to the housing, heat the edges and press lens to the housing firmly.
    Final product pictures:
    Coding and aligning
    Code the car to accept xenons.
    Don’t be an idiot. Please align your headlights properly straight to the road and not on on-coming driver’s face. Use a Philips screw driver or allen key to align the headlights.
    Outer adjustment holes: left and right
    Inner adjustment holes: up and down
    Also if your cut off lines are not straight, remove the headlights, use some big flathead kind of tool or needle nose pliers on a notch just above the big nut holding the projector. Go slow, if needed, loosen the big nut.
    Thank you Phil, Axis and other members for you insight and clear DIYs. I wouldnt have been able to put it together.
    Edit: Check our Phil's DIY for removal headlight, clear corner, bixenon function retrofit.
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    Dude.... this is a damn good DIY.
    Veteran Member Four Rings DanKing's Avatar
    Aug 14 2014
    California
    nice dude !
    '07 6MT Brilliant Red 2.0T
    JHM Stage 1 • JHM test pipe • ST coilovers • Smoothed Cupra R lip • Relak Skirts • 3sdm 0.06 • 034 mounts • Revo snub • GFB DV+ • S4 Recaro seats • RS4 Steering Wheel • Joey'd Bi-Xenons • Phils V4 LEDs • STI projectors • LEDs everywhere • APR Carbonio Intake • p3cars Gauge
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    my biggest concern / question is how forgiving is it to level and aim left/right/up/down?
    May 20 2014
    e92
    Quote Originally Posted by Sanjman View Post
    Level? No autoleveling with this setup. Once the projector is mounted, cut off is fairly straight. Trial and error on getting perfect straight cut off though. I added the step at the end of the DIY on how to adjust the cut off line.
    Aiming is just like halogens/xenons. Same allen key adjustments. We are not modifying any moving parts.
    Nov 16 2006
    Skokie, IL
    I know there isn't autoleveling lol. Just thought that with a retrofit it would be a trial and error with mounting to get the adjustment right. The halogen housing adjust mechanism has its limitations too to how high/low and how in/out you can aim the beams. The point I'm getting to is that I'm glad someone was able to mount the projectors straight into the bulbs holes of the halogen reflectors and use the halogen adjusters to get the beam pattern we all want to achieve!
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    Senior Member Three Rings Mlambrecht17's Avatar
    Aug 11 2014
    Minnesota
    Any pictures of the beam cutoff?
    May 20 2014
    e92
    There are other members who already did this retrofit in B7 before I did. Someone in the forum helped me a lot during my research on wiring. I just can't recall the name, oops.
    I already did this retrofit on my other car about 5 years ago, so I knew what to expect. :)
    The only trial and error is to get the beam pattern straight, after that you can adjust the up/down/sideways with the headlights inside the car. I was almost going to purchase factory bi-xenons but thought to give this one a try because I knew how much work it would take.
    - - - Updated - - -
    Quote Originally Posted by Mlambrecht17 View Post
    Amazingly I haven't taken a single picture of cutoffs. Will do it soon and upload.
    Senior Member Two Rings flavormonkey's Avatar
    May 14 2015
    RS4 Avus
    United States
    this is funny...saw your original post first. Thanks for the update!
    Veteran Member Four Rings JUSADUB's Avatar
    Mar 10 2009
    Gig Harbor, Wa
    Im working on this set for a friend.
    Brand new aftermarket a4 headlights
    morimoto mini h1 bi xenon 7.0s
    4500k bulbs
    iris shrouds
    going to be ordering some clear corners for the turn signals.
    BrownBag on vwvortex
    USP CLUB MEMBER #142
    Instagram: e_geeezy
    B6 A4 Avant
    17 4Runner
    Aug 09 2007
    Mount Airy, MD
    Well done! A few questions regarding how you wired it up and needing to code it for xenons vs just leaving it.
    To get high beams to work with the projectors, couldn't you have just plugged the projector actuator into the highbeam bulb connection? What is the benefit of tapping into the headlight harness and cutting the low beam bulb connector off vs just plugging the ballast into the original low beam connector? I guess I'm not following that bit. Just to have DRL vs City lights?
    example from a retrofit i did a whiiile ago:
    - Will
    06_Avant . DTM K0R-Gt. etc...
    The Avants Timeline
    Veteran Member Four Rings dalmation53's Avatar
    Aug 19 2013
    Miami
    Holy amazing DIY batman...haha damn this was good indeed. I wanted to do this and finally going to buy the iris shrouds. But i do have a question is grinding the hole strictly needed or not? Because i suck at grinding and don't trust myself.
    Sent from my C5306 using Tapatalk
    Ivan
    Mar 10 2009
    Gig Harbor, Wa
    Quote Originally Posted by hemantpd1 View Post
    How much trimming did you do on the shrouds?
    Instagram: e_geeezy
    B6 A4 Avant
    17 4Runner
    Mar 01 2016
    San Diego/CA
    Quote Originally Posted by dalmation53 View Post
    Without trimming it will not fit if you are ordering from retrofitsource.
    Quote Originally Posted by JUSADUB View Post
    I did 5mm trimming.
    Mar 10 2009
    Gig Harbor, Wa
    I did 5mm trimming.
    Thank you.
    Instagram: e_geeezy
    B6 A4 Avant
    17 4Runner
    Mar 10 2009
    Gig Harbor, Wa
    I finished the retrofit I was building for a friends A4. Everything works but it seems to be the adjuster are maxed out and he can't not get them to go up any higher. His car is also bagged so at his ride height their still too low. Anyone have any ideas how to go about fixing this? The other problem is he's two hours away from me. So I'm giving him over the phone support as much as I can. Also I want to add that I stuff the ballast and can bus into the headlights. Not sure If that would be my problem. The ballast are sitting on hop on the low beam housing right above the projectors.
    Instagram: e_geeezy
    B6 A4 Avant
    17 4Runner
    Mar 01 2016
    San Diego/CA
    You can try to adjust three screw holding the headlight. That can give you little bit of height.
    Mar 10 2009
    Gig Harbor, Wa
    He did and it didnt do much. People on the Facebook group "headlight junkie page". Told me I might have to redo it and use the bolt method. Im using the shaft and nut method.
    Instagram: e_geeezy
    B6 A4 Avant
    17 4Runner
    Senior Member Two Rings aviator79's Avatar
    Apr 10 2012
    Suffield, CT
    About to do this. Got headlights out but without pics this DIY is not much use. I will figure it out but had hoped to find a DIY for help like this...Photobucket...PITA.
    Stock B7 A4 quattro
    MS6 BNRs3
    B5.5 WV Passat
    Mar 01 2016
    San Diego/CA
    Quote Originally Posted by aviator79 View Post
    https://www.youtube.com/watch?v=W6UvaSYdeDo
    Dec 03 2016
    nowhere
    I really hope that lamp bracket is metal otherwise I'd probably strip the threading. Looks like a delicate process. Kool if you can pull it off the way he does.
    But will they point the same??
    Apr 10 2012
    Suffield, CT
    I got it all figured out except I did not receive concentric rings to mount the shrouds. Hopefully I can find something to make them from...
    Stock B7 A4 quattro
    MS6 BNRs3
    B5.5 WV Passat
    Apr 10 2012
    Suffield, CT
    My only idea now would be to get some 3" ABS and cut a slot out to make it have 2.75"ID. I assume these should have been included but IDK. Mounting the shrouds without them will not work.
    Stock B7 A4 quattro
    MS6 BNRs3
    B5.5 WV Passat
    Apr 10 2012
    Suffield, CT
    Figured out how to mount shrouds.
    Wiring up with relays.
    Do I need to use vac-com to program ECU/BCM for Xenons? as it will see less resistance? The relays also only tap into one HL low beam. IDK if that will cause issue? Should I not use the relay setup?
    Stock B7 A4 quattro
    MS6 BNRs3
    B5.5 WV Passat
    Apr 10 2012
    Suffield, CT
    I believe step 2, ELECTRICAL CONNECTIONS is wrong.
    I can only assume you meant HIGH beam wires as you want the solenoid to activate and lower the cutoff when you turn on the high beams.
    That is how I wired mine.
    Now for wiring ballasts seams that if I program with VAG-COM for Xenons I will lose my halogen Highs which I don't want (EDIT, or you might be able to code it but IDK how or if that is just in other audi as read a post about getting both to work on 2004 audi A8 OEM setup).
    If I wire without the relay I may have flicker issues or may work? If I wire with relay I will get an error like dipped headlight or low beam out or something unless I put a resistor in the RH low beam connector to simulate a bulb.
    I think my best bet is to wire with relay and get a resistor to install later. Have to finish this tonight...
    Stock B7 A4 quattro
    MS6 BNRs3
    B5.5 WV Passat
    Apr 10 2012
    Suffield, CT
    Well they work. Wife just left for work in car. Hopefully stay working as I need to go to bed.
    Stock B7 A4 quattro
    MS6 BNRs3
    B5.5 WV Passat
    Apr 10 2012
    Suffield, CT
    So I have had problems with the HIDs not working at times. I assume was a bad ballast but determined to be bad relay kit. Removed relays and directly wired however had to change vag com setting:
    Go to Components – Module 9 and change the fourth digit to either a 2 (with Daytime Running Lights) or a 3 (without DRL). For example if the code reads xxx?x, update the ? to a 2 or 3 (it is likely a 0 or 1 currently, which are for halogen cars).
    I changed mine to 3. They do not work correctly if I leave them as 0.
    But now I have no high beams because OEMs would only use Bi-Xenon for high beams. Is there a setting I can use to get high beams to work? or do I need to get another relay kit or install resistor and set back to 0.
    Stock B7 A4 quattro
    MS6 BNRs3
    B5.5 WV Passat
