Results 1 to 22 of 22
    Mar 11 2012
    Audi A5
    Ventura, CA
    Destroyed Wheel Hub Thread
    Help! I cross threaded one of my lug nuts and ended up destroying the thread in the hub a couple weeks ago. I ordered a new bolt because I thought that might help and I would be able to get it in there and correct the thread but no luck. While trying to fix it I accidentally attempted to put the jacked up nut in one of the different holes and ended up jacking up that one's thread too.
    I was so frustrated that I ordered a stud conversion right then and there.
    I started installing the conversion today and got the other 3 wheels converted just fine but because the thread is jacked up on this hub I wasn't able to get the stud to fit in the last hub.
    I took it to 3 different shops and all 3 said they can't touch it because of the electronic e-brake and one quoted me $850 for a new hub. I walked out real quick.
    I found a brand new hub for ~250 but am hesitant to buy it because I'm not comfortable installing it myself and not sure if I need a VAG-COM to release the ebrake to do it which I don't have.
    Anyone have any ideas? Can I just use a tap to fix the thread? Or do I have to buy a new hub?
    2011 A5 2.0T//Ice Silver Metallic//30% Tint//RS5 Replica Grille//LED Interior Lighting//APR Carbonio Cold Air Intake, HFC, Downpipe, and Stage 1 ECU Tune//Carbon Fiber Mirror Caps//Lamin-x tailights//H&R Swaybars and Street Performance Coilovers
    Feb 24 2013
    CA
    Where in california are you located? I was having the same issue and multiple places said it couldnt be repaired and that i needed to replace it. I stopped by supremepower in the oc area and they were able to fix the threads with a rethread tool of some sort.
    Mar 11 2012
    Audi A5
    Ventura, CA
    Quote Originally Posted by Slick_B8 View Post
    I'm in Ventura county. Id be kind of scared to make that drive on only 3/5 bolts.
    Mar 11 2012
    Audi A5
    Ventura, CA
    Any idea if it was just a tap/die or if it were some sort of helicoil?
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    i'd say you definitely need a new hub
    if you can thread anything in there anymore, then the hub's threads are probably destroyed
    Veteran Member Four Rings Alex1188's Avatar
    Mar 10 2013
    Forest Lake, Minnesota
    By the looks of your wheel lug, id say you should be able to just go buy a tap of the same thread as the wheel lug and clean out the threads on the hub. More than likely there is just a ton of dirt/crap in the threads that is causing the lug to bind/cross thread. Plus a tap is probably only 5$, worth a shot before spending $xxx on a new hub.
    |CURRENT|01.5 S4|
    |TOTALLED|09 B8 A4 QUATTRO|EURODYNE|FRANKENTURBO F23L|
    |PAST TURBOS|IHI JH5|PROTOTYPE BW K03 BILLET WHEEL|
    - OEM IHI K03 APR STAGE 2+ V1.0-1/4 MILE TIME [email protected](-85DA)
    Mar 11 2012
    Audi A5
    Ventura, CA
    Quote Originally Posted by Alex1188 View Post
    That was my thought as well. That's what I took it to the shop for because I've never done it myself. But I guess I can't really screw it up anymore than it already is.
    Veteran Member Three Rings Jacon's Avatar
    Jan 05 2009
    B8 A4 6MT P+
    Ft Worth TX
    You can put in a helicoil, but some shops wont touch the car for liability.
    Thats unfortunate, but the correct and safest repair is to replace the hub. :-(
    My current rides...
    Audi
    Jetta
    Established Member Two Rings RW12's Avatar
    Dec 28 2015
    1997 Safari van, SV650 Superbike, YZ85 supermoto
    Vancouver
    I prefer using keenserts to helicoil, but I would personally replace the hub
    May 22 2013
    Southern ME
    I don't know how involved replacing the hub is but the carista app works great for disengaging the parking brake. I just used it last weekend for doing brakes.
    Feb 24 2013
    CA
    They cleaned out the threads on mine when they did it. It was bad as yours and its been holding up perfect.
    Mar 11 2012
    Audi A5
    Ventura, CA
    Ordered a tap from ebay a few days ago, it got here today and worked like magic. It cleaned up the thread great! Got my stud in there with locktite drying right now and should be good to go tomorrow
    Oct 10 2016
    Colorado
    Quote Originally Posted by Sauci View Post
    I'm in the same situation. Would you please post which tap you purchased to fix this? Can anyone help with the right item, dimension, etc?
    much appreciated.
    Mar 11 2012
    Audi A5
    Ventura, CA
    Quote Originally Posted by eclipse1 View Post
    much appreciated.
    I went to check my ebay history for the tap, but unfortunately it's been over 3 years and ebay does not store purchase history longer than than so I can't see the exact one that I purchased.
    The tap dimensions were:
    Diameter: 14mm
    Thread pitch: 1.5mm
    Hope this helps.
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    Everything about this is wrong, first of all, no one in their right mind pays $250 dollars for an OEM wheel hub when you can get febi or a half dozen other brands for $100 bucks or less. Second, tapping it will certainly clean the debris out of the threads, but if the threads themselves are gone that far back into the hub, your not actually catching on anything but a thread or two. Lastly, you should never be using loctite to put your wheel bolts on. Well wait thats not lastly, the last thing about this is that the electronic parking brake has nothing to do with any of this, that sounds like an excuse for the shop to get you out because they dont want to deal with it or they want to charge you an insane amount.
    You ideally should be replacing the hub, the problem is its in the rear, and even if it wasn't , you want to be doing the bearing at the same time, because you can't reuse them once you separate the hub. That's where the bulk of the labor charge comes in because its a more complicated procedure to do those rears. Be careful what you torque that bolt to, because you are likely not hanging on by much now.
    Nov 20 2016
    Quote Originally Posted by RW12 View Post
    Agreed, I may have to keensert my oil pan soon enough.
    Established Member Two Rings Tineo's Avatar
    Jul 08 2013
    Dairy Land, Asturias - Spain
    It's best if you replace the hub
    if the car is NOT quattro, it is easier to remove the bearing and then remove the hub .... but when removed, the bearing can be damaged so the most interesting thing would be to install new hub+bearing at once.
    2008 A4 B8 3.0tdi Quattro Sedan 6MT EuroSpecs
    Ibisweiss | TLR remap to 301hp | S-Line interior | Rotor 19" rims | S4 front & rear brakes | Depo taillight LEDs w/ fulldynamic LED turn signals | 80mm exhaust tips | S4 blackgloss grill with blackgloss valence | S4 pedals | RSNAV 8.8" ...and more
    Dec 03 2016
    nowhere
    The OE Audi/VW hubs are more in cost cause they go though a hardening process the cheaper aftermarket hubs don't. If you ever get to inspect one of the knock-offs you can see how soft the material is.
    HEAR
    APR stage 2
    Nov 20 2016
    Quote Originally Posted by flowhigh View Post
    Don't buy knock offs, buy legitimate aftermarket hubs that are induction hardened... audi does not make their own hubs. Lemforder sells most of the audi OEM parts with the audi logo ground off for a fraction of the OEM price.
    Feb 15 2016
    Cambridge,Ontario
    Ummmmmm...........
    Quote Originally Posted by Spawne32 View Post
    Sent from my SM-G973W using Audizine mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Nov 20 2016
    Ummmmmm...........
    ummm? a knockoff is different from an aftermarket part...
    Veteran Member Three Rings bloodstar57's Avatar
    May 15 2007
    2024 SQ8 E-Tron, 2019 RS5
    LI, NY
    Just thought I update this and share my experience . I had a similar problem on the B9 RS5 and I fixed it. Things to note: The hubs are very very hard and thus the threads are tough. What I found was that the hub threads were full with that metal of the crossed threaded lug. I even tried to use a thread tap and found that the hub threads destroyed tap.
    Solution: used a high carbon thread chaser to clean the threads.
    It was hard to thread initially but it gets better as it cleaned out the threads. Used cutting lubricant and kept tightening and loosening until i can hand tighten.
    https://a.co/d/5tNE7pw
    https://www.autozone.com/test-scan-a...store_set=true
    Hope this helps for posterity!!!!
    "Above all, love each other deeply"
    2024 SQ8 E-Tron
    2022 Mach-E GT PE
    2019 RS5
    2014 SQ5 Sold.
    2015 Ghibli SQ4, Sold.
    2013 Q7 3.0t Prtige S-line Sold.
    2009 S5 6spd Sold.
    2007 A4 2.0t 6spd S-line Ti Sold.
    1996 A4 2.8 Sold. 2006 Suzuki (2x) GSXR-750 Sold
