Results 1 to 40 of 40
    Veteran Member Three Rings BDP's Avatar
    Feb 07 2015
    Ohio
    Out of Curiousity- What are your local shops charging for shop fees on ECU Tunes?
    I have a local shop that wants to charge me 1.5hrs of labor on a TCU & ECU tune. The shop rate is $95 an hour which puts things at about $142.50 to get flashed. Personally I'm shocked that an ECU/TCU tune would literally take a full 1.5hrs of labor...ACTUAL LABOR. The same shop quoted me 2hrs labor to put on the AWE resonated downpipes I have. To me the downpipes seem like a good 2hrs of labor, where flashing a tune literally takes what...hit enter...maybe hit enter again.
    Also for a Stg II upgrade, with the ECU tune labor plus the install of the pulley they are quoting 6.5hrs. Does that sound right? I guess this means it's 5hrs to put the pulley on...I guess this shop doesn't know how to do stuff in parallel and the manger in me just doesn't get it.
    This is at a GIAC dealer shop, the APR shop isn't much cheaper.
    Senior Member Two Rings justr0's Avatar
    Jul 24 2015
    2001 Mustang GT, 2007 VW Jetta, 2015 Honda CRV Touring
    Wow that's crazy! I'm sure they charge the same if you want to reflash back to stock for servicing etc...ridiculous!
    My shop doesn't charge me for flashes :) (APR)
    2014 Phantom Black CPO
    P+/DSG/Sport Diff/B&O/Black Optic/Carbon Inlays/Magma Red & Black Nappa/19" Rotors/Supercharged Badges/Conti DWS
    Mods:APR II+DL501/InjenSP CAI/AWE Touring 90 BD+Res.DP/CR-15/EC AK+Sway+EL+Mounts/Bilstein B8/H&R OE/ECS Flush Kit+SS Lines/Motul RBF600/RS4 Grille/SunTek Carbon 35%/PC 19" Rotors/PD Emblem (Red)/Carista/BV DR650GW/Passport Max2
    TBD:Akebono pads/Slotted Rotors or JHM 382mm Kit
    Veteran Member Four Rings bmoreS4's Avatar
    Apr 27 2011
    Couple Audis and a VW
    MD
    Normally shops charge 1 hour, so doing an ECU and TCU tune might be 1.5
    2020 B9 SQ5 - 034+ / E85 / APR / CTS / MTM / VPS
    2001 B5 S4 - Stage 3 / E85 / Thanks to Brad
    2018 Atlas SEL Premium / Black on Black / Black Wheel Package
    Cheap/Fast/Reliable - Pick Two
    IG: @s4dad
    Feb 20 2006
    NC
    Just FYI, I flashed my stage 2 and DSG tune in under 30 minutes from start to finish.
    2021 BMW M340i
    2021 Tesla Model Y Performance
    GONE - 2019 RS5 Sportback
    GONE - 2021 Audi Etron
    GONE - 2019 Audi Sq5 - JB4 Rev9 intercooler
    GONE- 2013 S4 DSG - DP stage 2 EPL
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    If a shop charges for flashing... Find another shop! I would never pay for a flash
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    It completely depends. The two local shops I've dealt with don't charge any shop time for the initial tunes, but sometimes charge a half-hour for subsequent updates. I also know of some shops that do charge for all tuning work, and it's probably justified up to a certain point. It is a little more than hitting a few buttons. A good shop will do a thorough inspection of the car to make sure everything is in working order before it's tuned. You also have to hook up a battery charger, clear codes afterwards, and they should verify everything is working properly afterwards. It really comes down to what a shop is willing to throw in to get your business on the tune.... Shops aren't making a lot of money off this type of tuning.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Veteran Member Three Rings LordMagnet's Avatar
    Jul 20 2015
    Connecticut
    My shop did my flash for free. They said I could come back anytime I needed to flash back to stock (service) and they would flash and then reflash back for free.
    2015 Audi S5 Coupe 6MT | Mythos Black Metallic : Black Nappa : Alu-Optic : B&O : Sport Diff. : 19" RS Rims : Carbon Fiber Inlay | APR Stage 2 : Roc-Euro Intake : AWE Touring Exhaust 102mm : EuroCode Short Shifter : USP Clutch Line : CR-15 Strut Tower Brace : 034 Mounts : H&R OE Sport Springs : 15mm/20mm Spacers : Tint 35% Sides / 20% Rear : Interior LED Kit : E-Codes : Vinyled Grille | 413 AWHP / 375 AWTQ
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    While I don't necessarily agree with it, the logic holds that the car is in the shop's possession, and it is occupying their time that could be used to work on other customer's cars. I am not sure how APR or Unitronic works, but I know GIAC tuners have to log into a specific site and provide all necessary vehicle information before a tune is released for the specific car. It took longer than expected for me, but that was due to issues with a new GIAC dealer site that was released within the last few months. Again, I don't agree with the labor charge, but I understand that this is your local dealer's opportunity cost of providing you a service; pay to play my friend.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    1.5 sounds fine to me for flashing 2 ecu's. If you go to a dealer they charge you the same to flash a computer 1.0 for the first and .5 for every computer there after. But like others have said you should be paying for a flash. There is enough profit built into the tune price to where they would install the flash for free. Also my Manager friend. If the work doesn't overlap you get charged whatever the quoted rate for the job reguardless if the tech can do both jobs at once. Only when the job's functions or requirements overlap that's when you would get a break on labor.
    Feb 07 2015
    Ohio
    I don't have many options on flashes unless I want to drive 3hrs. There are literally 2 shops within an hour of me (APR & GIAC).
    Both quoted me 3 grand to do a Stg II install (Pulley, ECU, TCU) so I was curious to how much it would be just to go Stg 1 and was a little shocked to see the nearly $150 charge to flash the car.
    I guess outside of that my only other option would be Unitronic or EPL to avoid any flashing fees.
    Apr 04 2015
    United States
    1 Hour labor
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    Usually free. But we have plenty of options and competition between shops in the tri state area here.
    Since you don't have any real shop options where you live, the shops are taking advantage of that.
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Apr 22 2014
    2018 Q5, 2018 X1
    Sacramento
    Mine will charge for about 45 mins of labor on a ECU flash/reflash.
    2018 Q5 Tech Premium Plus
    2011 A4 JHM K04-R : JH MOTORSPORTS TUNED : CTS : 034 : ECS TUNING : SNOW PERFORMANCE
    Apr 11 2016
    You have to take in consideration the shop is not just doing an upload . They have to take time to gatter some information prior to the flashing process and build up your customer file in the data base : Ecu ID, Revision number, name address ,phone number , car specification , etc..etc.. that being said it take a good 10 minutes to properly enter those. After they have to proceed to the task of flashing the car. Not all the car's have the same flashing period ECU's and DSG's are not ALL flash the same way and in some situation they must take appart some other part's to start the flashing session. On other car's the flashing session can take as long as 2 hours.. It is certainly not a good thing to surcharge a customer for a flash but keep in mind that not every car is a 5 minutes flash session.
    Deactivated Four Rings
    Jun 23 2011
    Free to install the software in house and we offer the cable to install the flash yourself for $199 and then you can go back to stock at your convenience and be able to do any updates as necessary as well.
    Feb 07 2015
    Ohio
    Quote Originally Posted by Ben_magnan View Post
    Understood but 1.5hrs seems a little excessive to me. I can do system installs in less time then that on my computers while eating a doughnut, while drinking a cup of coffee. It's sad to see how archaic VAG tuning still is in respects to handhelds and the ability for custom tunes. I guess I've been spoiled with Cobb tuning over the years and actually having a kick A$$ handheld that comes along with their flashes.
    - - - Updated - - -
    Quote Originally Posted by Sales@EPL View Post
    Can you PM me your prices on your tunes?
    2018 Glacier White RS3 - Unitronic Stage 2 (E85) ECU, Stage 2 TCU
    2014 Estoril Blue S4 (DSG) - Sold (11.2@121mph 93 octane)
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    Unitronic and it's free at home flashing. Love it I went to the audi dealer last week for Audicare and flashed it the night before and the next day came home from Dealership and flashed back the the race file that I will use this weekend, and then back to the 2+ tune. Easy
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Apr 04 2012
    MSP
    1 hour labor is fair
    Jun 23 2011
    Quote Originally Posted by BDP View Post
    - - - Updated - - -
    haha I already sent you some prices.
    Aug 23 2014
    Philadelphia, PA
    Flash right at home with UniConnect. takes all of 15-20min
    https://www.moddedeuros.com/products...tool-uh008-tla
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    can't speak for recent times, but I know back when I had my b7 a4, the flash was 1 hour's labor, and the reason they told me is that they just don't know how long it will take. Most cars it's 30 minutes, some cars an hour, some over. even if it's 20 minutes the shop usually has a 1 hour minimum, but I get what your saying, you are buying a product from them, they should offer something.
    idk vote with your wallet.
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    Unitronic dealer (IIRC), was either 50 or $100, though depends on the dealer. The labor for Stage 2 was 3.5hours (I did it myself).
    I went EPL for the tune FWIW since it's an easy DIY flash once everything is set up computer/cable/ECU wise. I strongly considered Unitronic because they are Canadian (exchange rate sucks), and Uniconnect is a huge benefit to me. But they had no DSG tune and EPL had a great sale.
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
    Feb 07 2015
    Ohio
    Thanks everyone for your input. It sounds like I need to start researching a do it yourself pulley install.
    Quote Originally Posted by cjw View Post
    See the shops here are quoting 6hrs for the pulley install. I assume they are tacking on the software install time also with that.
    Jul 20 2015
    Connecticut
    That's brutal. I was quoted 2.5 hours of labor for pulley install and stage 2 flash.
    Sep 11 2004
    16 Q5
    Westchester, NY
    Quote Originally Posted by LordMagnet View Post
    Just curious, which shop?
    Apr 11 2012
    the tcu flash is much quicker than ecu flash, combined should be under an hour unless something goes wrong like 30 mins into it, then a lot of time gets consumed starting over.
    Aug 11 2015
    Alberta
    There is a YouTube video on a diy. I removed the supercharger as another way to do it. Maybe 2.5 hours of casual work and another thirty minutes of diy flashing with EPL.
    Sep 10 2012
    DFW
    This is true if you choose not to get the Uniconnect cable but as you can see by others the cable pays for itself the first time. If you buy the tune and cable together the cable is/was $100.
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Aug 11 2015
    Alberta
    Good Point, I'd see no reason not to go Uniconnect. The only downside is if you're a Mac user or have no laptop so you'd need to buy a mediocre one to use Uniconnect. The EPL program works on the cheapest of tablets.
    Jun 23 2011
    And we can also include a tablet with purchase as well.
    Registered User Four Rings Sales@DriveAuto's Avatar
    Apr 13 2012
    Clifton/Mountainside, NJ
    We don't charge for flashes. Even on the most complicated setup (figure a C7 S6 ECU and TCU tune, the latter of which requires more equipment and setup time), we can still knock both out in under an hour, and we're making money on the tunes. Most of the shops around us charge somewhere between a half hour and three hours labor to flash/reflash/unflash, which we feel is unnecessary. For most tunes, you plug the laptop in and watch the status bar progress forward. I can understand it taking time, but if your shop is tacking on a fee for this, what else are you overpaying for?
    Just our $0.02 - we try to make your dollar go further.
    Dec 19 2014
    Virginia
    Quote Originally Posted by sales@epl View Post
    free to install the software in house and we offer the cable to install the flash yourself for $199 and then you can go back to stock at your convenience and be able to do any updates as necessary as well.
    what he said!!!!!
    16 s3 eurodyne stage 2 ecu/tcu
    Jb4 Methanol Intake exhaust
    2010 s4
    Epl stage 2 ,test pipes non res downpipes custom exhaust , intake , dual pulley setup torque monster .
    Gone:
    07 a3 , unitronics stage 2 , water meth .
    Veteran Member Three Rings Silverbullet S4's Avatar
    Mar 10 2015
    CO - 6,200' +
    Zero cost for install at my shop. I wouldn't pay an extra fee for that. I'd go to another installer or run a different tune if there was labor cost for every time the tune is added/updated/removed.....
    2013 S4 - APR Stage 2+, DP, CPS v3, BLQ 20s, Solo Werks coilovers, CR-15, EBC Rotors F&R, Deval diffuser, AWE exhaust & USP Intake - TD1 inevitable
    Veteran Member Three Rings PSUGOLD's Avatar
    Mar 10 2014
    Philly Area, PA
    AWE Tuning is the shop that does my work, there are no other GIAC dealers near me. 1.5 Hours of labor to remove the tune and DSG software, then 1.5 hours to put it back on when I bring it back. $100 an hour labor. Sucks, but WTF else am I supposed to do?
    2016 Daytona Grey Pearl Effect crystal effect , Sports Diff, Adaptive Suspension, Carbon Atlas inlays, Borla Cat Back, DS1 Stage 1 w/ Boosted Euro TCU.
    Jun 23 2011
    Quote Originally Posted by PSUGOLD View Post
    With our ECU tune and TCU tune you buy a cable and install/uninstall either tune yourself any time you want. And we can also include a tablet to use with the cable if you dont have a laptop.
    Sep 10 2012
    DFW
    Tune from home!!!
    Unitronic Uniconnect is the answer.
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Established Member Two Rings Navyseal#6's Avatar
    Aug 17 2015
    Pennsylvania
    Anyone in central PA performing ECU/TCU tunes for a good price? Bloomsburg PA
    Veteran Member Four Rings littleredwagen's Avatar
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    Quote Originally Posted by Sales@DriveAuto View Post
    great service and great prices from you guys
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    2011 S4 Prestige 6mt Black
    2001.5 S4 EPL Stage 3 Yellow
    2005 S4 Avant 6spd Red
    Jul 24 2015
    +1 These guys are great and my primary shop for all my tuning work.
    Shout out to Dion, Matt, Kevin and Sam!
    Veteran Member Three Rings AerotusX's Avatar
    Mar 24 2014
    Wasn't charged for initial ECU flash here either. The pulley install and stage II flash took 3-hours for me.
    2015 Audi S4 Prestige | DSG | Moonlight Blue Metallic | Black/Magma Red Fine Nappa | Sports Differential | ADS | Aluminum/Black Wood Inlays | 19x9.5 VMR V710 | XPEL PPF | 3M Crystalline Tint | KW H.A.S. | Vag-Com | CR-15 | Alu-Kreuz | APR Stage II | APR CPS | RS4 Grill | Eurocode Sways | Eurocode Inserts | ECS TCU
