Results 1 to 14 of 14
    Active Member Two Rings vexa27's Avatar
    Sep 23 2015
    Boston
    AC not working in my RS5?
    We finally got warm weather here in NH. I pressed the AC button, it lit up but would turn off as soon as I let go of the button (AC itself would not function). I'm assuming this means there must be an issue with the AC? Any other people run into this?
    2014 Sepang Blue Audi RS 5
    Capristo | AWE Non Res Downpipes | CF Side Mirrors | Ecodes
    Instagram
    Dec 26 2008
    STL
    I have the exact same problem with my S5, but I have 0 Freon in the system due to removal of the AC lines.
    I'd say check the Fuses, then have someone at the auto parts store check your Freon level. Hopefully it's not the AC compressor issue, as that's a major PITA to replace.
    Sep 28 2010
    NW NC / DE
    I had it once. Wire/connection came undone. Shop said it was a 5 minute fix.
    Dec 26 2008
    STL
    Wire connection at the AC switch panel?
    Mar 05 2016
    IN
    My 13 had an issue where one fuse knocked out the AC and the over head lighting. if your "dome" light doesn't turn on might be due to that.
    2013 S5 estoril blue
    Veteran Member Three Rings plat's Avatar
    Dec 19 2015
    GVRD, BC Canada
    As with most AC systems after hibernating all winter, it is most likely that the refrigerant has leaked out of the system. It happens because the lubricating oil in the HVAC system is not being circulated (i.e., AC remaining dormant for several months) and it makes the rubber seals dry up. When this happens, the gas leaks out. It is a good habit of using your car's AC system, at least, once a week for 10 minutes. When the A/C system is recharged with fresh refrigerant, it will include the lubricating oil. After getting a fresh charge of refrigerant, it is good to have the technician go over the A/C system pipes and joints using a leak detector to make sure there are no gas leaks.
    Current: 2016 S5 in Sepang Blue with Technik Package.
    Dec 26 2008
    STL
    That's a good copy&paste info :)
    Hopefully the issue for OP is simple like a fuse, or wire loose behind AC panel.. and for me as well lol
    Senior Member Four Rings
    May 20 2015
    Audi S5 Deep Sea Blue Pearl
    PA
    I crossed my fingers when I turned mine on for the first time this year in my S5 the other day lol. Turned on, although it's probably smart to check my freon level I suppose.
    Veteran Member Four Rings jkownz's Avatar
    Jun 15 2011
    2015 RS 5
    who needs AC? open up them windows and hear the sweet sound of a NA V8 at 8250 RPM.
    MODS 2015 Audi RS5 / Custom Made Headlights / Full Xpel PPF / Tinted / Blackvue DR650G / Eventuri Intake / BLK 501GTR'S 20X10.5's All around / Storage Bins / Euro Folding Mirrors / Capristo Exhaust / A.W.E Non-Res Downpipe / CF Engine Cover / 034 Transmission Mount Insert / Apikol Rear Differential Mount Insert / 034 Rear Diff Carrier Mounts / Euro Tail Lights + Sweep Module / L.E.D Interior Lighting / Airlfit 3H Bag Suspension /
    May 20 2015
    PA
    Quote Originally Posted by jkownz View Post
    Well that too of course if i am moving at a decent speed. But when that sun is blasting in the car and i am in crawl or light to light traffic. And my back starts to sweat like i am in a sauna on that leather seat, its time for the windows and moon roof to close lol. Those black leather seats can killer in the summer if you aren't moving fast in traffic. I have went into stores before with a full drenched back, sorry not sorry lol.
    Some new cars have those snazzy seat coolers. Hell id use that more than the seat heater, only my fiance really turns hers on.
    Senior Member Three Rings d1amund's Avatar
    Oct 27 2014
    Park City, UT
    {raises hand}. It was 93 here today. That'll be our low for the next 5 months lol
    One of these days Audi will catch up with premium vehicles such as GM and Chrysler...I sure would love some cooled seats too!
    Jun 15 2011
    2015 RS 5
    im just messin with you guys. I would get that fixed asap. Had a issue on my old B8 A4, was just a AC control sensor that went bad. was quick fix.
    Oct 27 2014
    Park City, UT
    Oh I know you were; looking forward to that hot humid air?
    Jun 15 2011
    2015 RS 5
    Quote Originally Posted by d1amund View Post
    Was 83 today and I was already bitchen haha. But I would take it over -3 and snow.
    Sent from my SM-N920V using Tapatalk
