View Poll Results: What tire pressure are you running?
Voters
36. You may not vote on this poll
  • 29psi
    2 5.56%
  • 30psi
    0 0%
  • 31psi
    0 0%
  • 32psi
    2 5.56%
  • 33psi
    2 5.56%
  • 34psi
    3 8.33%
  • 35psi
    4 11.11%
  • 36psi
    3 8.33%
  • 37psi
    1 2.78%
  • 38psi
    7 19.44%
  • 39psi
    2 5.56%
  • 40psi
    5 13.89%
  • 41psi
    5 13.89%
  • 42+psi
    0 0%
Results 1 to 13 of 13
    Veteran Member Four Rings riceboy22's Avatar
    Mar 26 2015
    2015 Audi SQ5, Felt F65x, Levy Electric Scooter
    New York, NY
    Question What tire pressure are you running?
    I'm just wondering what tire pressure people are running. I know we have a lot of different setups out there, so if you feel it's worth highlighting, feel free to add in the comments. I'm running 275/40r20 and aim for 38psi (although I appear to be way off that from the alignment I just had done).
    Edit: It appears polls don't show up in Tapatalk.
    Current
    2015 Audi SQ5 3.0 TFSI (Build Thread | Flickr | Instagram)
    Past
    2006 Lexus IS350 | 2001 Audi S4 | 2000 Honda S2000 | 1999 Yamaha YZF-R6 | 1995 Acura Integra GS-R
    Veteran Member Four Rings B_Boy's Avatar
    Nov 24 2008
    2024 VW Atlas SEL Premium R-Line, 2024 Ford F-150 RCSB
    36 psi for 265-35/22 tire on 22x10.5 wheels
    b_boy
    '23 SQ5 P+
    Sport S, B&O, Nav, Black Optics, Black Nappa, Black Sport Exhaust, Mythos Black, VAG-COM, LED Reverse Lights, IE ECU Tune, CETE
    Tint: 15% F/R, 50% Windshield
    Wheels: Rohana RFX11 Brushed Bronze - 22x10.5 ET32 // Pirelli Scorpion Zero A/S+ 265/35/22
    Jun 20 2014
    Ontario/Canada
    39 psi on 275/40R20 on 20X10 wheels
    Jun 21 2008
    NYC | ATX
    I'm actually running
    265/40/21 F
    295/35/21 R
    @ 40psi
    I think mop had it at around 43psi originally.
    Sent from my Rickshaw
    Mar 07 2004
    2025 Q7, 2018 TTRS, 2022 Q5
    Charleston, W.V.
    Mine has the factory 20" peelers. The door label shows 29psi, but it rides like crap at that. The manual shows that the SQ5 with the same size wheels and tires should have 39psi. I called Audi customer care to ask what the difference was and they couldn't tell me. I looked up the curb weight and the Q5 TDI is a little bit heavier, but not by much.
    Mar 26 2015
    New York, NY
    Quote Originally Posted by BarryT82 View Post
    I think the difference is primarily driven by the maximum speed for each car, and ultimately I'm sure by the associated liability. The recommended tire pressure needs to support the maximum speed for the car. The reality though is that's not going to be particularly applicable to most of us given where and how we drive.
    Current
    Past
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    Bumping this thread instead of creating a new one. I was wondering what you 20" wheel guys were running since the door jamb in the wifes Q5 only shows pressure for the stock 19's.
    Im also surprised to see it listed so low at 33psi when my S4 calls for 41psi. Can anyone tell me why its like that? Shouldn't the bigger, heavier car need more pressure to support the load, or do I just have no idea how this stuff works?
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Jun 21 2008
    NYC | ATX
    Quote Originally Posted by DannyDeez View Post
    I'm at 40PSI for my 21s
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    38PSI on my 21's
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Mar 26 2015
    New York, NY
    @DannyDeez, for reference, here are the tables from the manual (stolen from AW):
    If you're looking at the door jamb, I believe it only shows the full load pressure. The recommended pressure under normal conditions is lower. I think people sometimes mistakenly assume that running a higher pressure (and the associated ride discomfort) equates to better performance. There's a point though where all you're doing is reducing your contact patch to sub-optimal.
    I haven't gotten around to chalking like others have suggested, but I'm currently running 36 psi on my 275/40R20 setup. For wider tires of the same diameter, my understanding is you'll generally want to run a lower pressure than the equivalent narrower tire.
    Edit: I mentioned this earlier in the thread, but I think the higher pressure recommendations for the SQ5 are partially based on the higher maximum speed. I may actually try dropping my pressures even a bit more.
    Current
    Past
    Sep 11 2004
    16 Q5
    Westchester, NY
    Quote Originally Posted by riceboy22 View Post
    Thanks for the post! The 20's I just put on her car are the OEM size 255/45/20 and they're currently set at 36psi.
    The door jamb shows 'cold tire pressure' which I can only assume means the pressure after the car has sat overnight (or at least a few hours) without being driven?
    Here's a pic of the door jamb:
    So the manual shows full load as being 33psi, but the door jamb shows cold pressure as being 33psi.
    I'm guessing since a lot of guys are running a general range it doesn't matter too much, but does anyone know which is correct?
    Mar 26 2015
    New York, NY
    They're both correct really. Recommended tire pressures are given as cold pressure, so that basically means the car hasn't been driven recently and the air inside the tire is the same as the ambient temperature. The door jamb for legal reasons shows only the full load pressure; the owner's manual is allowed to have both the normal and full load pressures. Those are all cold pressures though.
    I'm at 36 psi as well, so I'm a little below the recommended pressure for the SQ5 on stock 20s, but I'm also running a wider tire. I'm planning to drop it down a bit to maybe 34 to see how much it improves ride comfort. I'm ok with a little more squishiness in exchange for a softer ride during daily use.
    Current
    Past
    Sep 11 2004
    16 Q5
    Westchester, NY
    Ah ok, makes sense. Thanks for the info. The wife hasn't complained about ride quality, and it still feels fine to me so I might as well leave it where it is.
    I was just afraid that the pressure was too low given that my S4 has 41 listed on the door jamb.
