Well by my first oil change since the NEw Pcv vlave i realized I was losing oil again and this time it's being forced out of places like the oil filler cap, the oil filter housing and once again the PCV vent tube into the turbo inlet, It even crushed my oil filter cartridge It sucked it in so tight that i had to cut it off the oil filter housing center section. So I definitely have pressure building up inside the motor forcing oil out where ever it can go.
Not only that but all over in the PCV system There is a Creamy gunk lining everything. The gunk is not in the oil pan that i can tell or in the head as you can see from the pictures just in the PCV system. Also this time the oil being forced into the turbo inlet form the valve cover vent tube is the creamy color thicker oil.
What do you guys think is wrong here? I'm assuming the New Pcv valve I bought must be bad? But would that cause all the Gunk as well? what's forming all the Gunk I've never seen that before in this motor till between the last oil change and this one. other wise the pcv tubes have always been dry or have your normal brownish oil in it never this banana cream pie stuff! The original problem i had with the oil loss when i bought the car, the oil that was being forced into the turbo inlet it was normal brown oil, like i said this time it's the gunk oil.
I also ended up having to replace the oil level sensor in the oil pan it went bad at the same time all of this other stuff is happening. Thanks for any help!
