Results 1 to 10 of 10
    Active Member Two Rings eclaytor's Avatar
    Dec 19 2015
    Richmond/VA
    Digital mpg display frustrations
    When I purchased my first audi, I noticed the attention to detail and precise engineering. Everything was designed to work perfectly and accurately..... except that is the calculated trip mpg. I am consistently 10% lower in actual mpg than what my trip computer reads. At first I thought this was an anomaly with my A4 but I just purchased a Q5 and it has the same 10% error.
    By the way the rest of this car was designed, I'm sure this is deliberate.
    Anyone else notice this? It's certainly nothing that affects the car but it does bother my ocd.
    __________________________________________________ ________
    2012 A4 Phantom Black - Sline - 6MT - Solowerks - 2 child seats
    Veteran Member Three Rings ToddBrunswick's Avatar
    Dec 07 2015
    PorscheCayenne
    Culver City, CA
    Nothing constructive to say regarding the actual car related issue. But maybe some Prozac or Zoloft would help?
    Pedal Responce Consigliere
    "I have a special practice. I handle one client" -Tom Hagen
    Aug 17 2015
    California
    Using a VagCom cable, you can code an offset intk the mpg number to make it more realistic. Off the top of my head, I cant remember the code, but a couple minutes of searching should find it easily.
    Established Member Two Rings gstrouse's Avatar
    May 13 2007
    2012 VW Tiguan SEL 2015 F-150
    Northampton, PA
    Quote Originally Posted by eclaytor View Post
    Yes, I have a 2012 VW Tiguan SEL and the 2014 A4 Premium Plus and both read lower when actual calculated by hand. And yes, I agree it's deliberate. I have owned several VW/Audi cars in the past and never saw such a difference.
    Dec 23 2015
    Cincinnati Ohio
    I have the same problem. The trip MPG is always 3 MPG higher than actual. Maybe we should add this to the diesel emissions scam.
    Mar 21 2015
    This common in a ton of cars. You should always do the math for a proper mpg reading.
    Veteran Member Four Rings lettuce's Avatar
    Jun 19 2015
    Boston
    The speedos on these cars (and most, actually) do something similar as well. They'll tell you you're going maybe 5-10% faster than you are. Good for liability purposes (my car said I was going the speed limit, I swear! Damn Audi, I'm suing them for my speeding ticket), but annoying nonetheless. At the drag strip I'm easily going 112-115 or so when I cross the finish line, then get my slip back and I posted a 107 trap speed. That 0-60 time you calculated going off your speedometer? Yeah, it was actually your 0-57 time. At least it's easily corrected with a slightly taller wheel/tire combo.
    B8 A4 - Eurodyne-tuned F23L - 12.6 @ 107 on 93
    Senior Member Two Rings ChicagoDave's Avatar
    Oct 21 2015
    Chicagoland, USA
    I noticed the same thing. Computer: 24 mpg. Basic arithmetic: 22 mpg.
    I'll poke around in VCDS to see if I can find the display offset.
    Dave
    2012 A4 Avant - Brilliant Black :: Zisa LED Lighting :: Awesome Floor Mats :: Warning Triangle :: Total Newbie
    Retired - 2002 VW Passat GLX w/ 4Motion :: 14 Years and 202,000 miles
    Retired - 1995 Chevy Impala SS :: 5.7L LT1 V8 :: Dark Cherry Metallic :: Fell apart at 98,000 miles
    Veteran Member Three Rings kt883's Avatar
    Nov 10 2010
    Stoney Creek
    I think the setting is located in the same place as where you set oil service requirements, special settings or something like that at main screen
    Senior Member Two Rings mecg's Avatar
    Apr 12 2016
    Readfield, Maine, USA
    Correct Consumption in DIS program:
    [17 - Instruments] [Adaptation - 10] -> Channel 3 change 100 to xxx (see samples below)
    Sample 1 - Calculation based on volume per distance (e.g. l/100km):
    DIS: 9.3 l/100 km.
    Real: 9.8 l/100 km. (100 * 9.8 / 9.3 = 105.38)
    Channel 3 will be changed from 100 to 105
    Sample 2 - Calculation based on distance per volume (e.g. MPG):
    DIS: 23 MPG.
    Real: 24 MPG. (100 * 23 / 24 = 95.83)
    Channel 3 will be changed from 100 to 96
    All that said, if your DIS is giving you a higher than calculated MPG reading increase the 100 to something higher. I set mine to 105 and the DIS is now much closer to the mileage/gallons calculated MPG. I may fine tune it a little more in time, depending on continued comparisons down the road. YMMV. Literally.
    2013 Audi A4 quattro Prem, ZF8, APR Stage 2+ 93/E85 Tune + Cast Downpipe/HFC, R8 coils, aFe Dry Pro, Eurocode Intercooler pipe, Turbo Muffler Delete, Fitch Fuel Catalyst, RS Grille, Tinted windows, Audi logo puddle lights, Interior LEDs, VCDS tweaks, 18x8 Andros R9 Wheels w/ Michelin Pilot Super Sports
    2008 Saab 9-5 2.3T BCB², K&N, Fitch Fuel Catalyst, Interior LEDs
