Originally Posted by
VERJ
I assumed they would have provided 1 and it wasn't something I had to ask for. The garage is supposed to be reputable and able to do lowered cars so I felt I should listen to them when they said its within audi spec for camber, caster, and toe in.
if I go back to them, to get it fixed once and for all. I can tell them about the D-shaped alignment bolt to fix the camber, as far as I can see, the camber is causing the problem.
I stated this earlier:
The shop is going to put your car on the lift and tell the computer it's an audi A4. The computer will pull the specs for an audi assuming it's on stock suspension. The tech (because he doesn't know what he's doing) will align to what the computer tells him and NOT according to the car's current ride height.
The computer (because it doesn't know you're lower) tries to shove a square peg in a round hole by trying to align your car presuming you're not lowered.
Like I said, 1) take it to a Porsche dealer 2) take it to a race shop that specs RACE CARS and not "lowered cars". Saying a car is "within spec" means that the car is within spec for a stock car. You're not stock so those dimensions no longer apply.
Lastly, the alignment in the rear affects what happens in the front so if you start with a fucked up rear, your front will be screwed too.
VERJ
alignment was previously done at Audi when I go in for my oil change etc with Audi care. They roll in onto the alignment machine before they put it on the lift, then they give a print out of the alignment to the service manager, so you can see right away if an alignment is needed, or to bring it to within Audi spec.
Can anyone show me a print out or tell me what I alignment should be at? something I can bring to them and request
Audi cannot properly align a lowered car. Their techs aren't trained to do it and their machines try to force it to factory specs.
Audi spec is up to +/- 2 degrees of camber all around. FYI, 2 degrees is enough to cause improper wear
