Hi ladies and gents!
As some may know, I've swapped in a 4.2 V8 40V from a 2005 D3 A8 (BFM) into my 2000 B5 2.8 Quattro Sport 5-speed manual.
I used an ECU from a 2001 D2 S8 (ME7.1.1), in conjunction with a hybrid wiring harness, combined of the stock D3 and an S6 C5 item. My car is running, but with tons of codes. Running quite rich too.
Going through the wiring diagrams of the C5 S6, and checking pins in the connectors, as well as the connectors of every engine connection, highlighted discrepancies. Yep, ME7.1. versus ME7.1.1. My harness is off a 1999 S6, very different to a 2000-2001.
I have both wiring diagrams, so I have removed the harness to re-pin it to match the later ECU.
For the benefit of anyone who may wish to do a 40V swap, I have taken the time to put the ECU pin outs in order. So the pins---component / connection---colours. I have just completed the write-up for the ME7.1 which I will post here. I will complete that of the ME7.1.1 later in the week, and I'll add it to this thread. It can then be referred to, hopefully it can be stickied.
Audi S6 4.2 V8 40V (AQJ) - Bosch Motronic ME7.1 ECU Pinouts.
001 - Earth (Brown).
002 - Earth (Brown).
003 - D131, connection 15 via fuse 232 (Black / Blue).
004 - Z28, Lambda probe 2 heater, pin 2 of connector T4v (Yellow / Blue).
005 - Z19, Lambda probe heater, pin 2 of connector T4u (Yellow / Green).
006 -
007 - N128, ignition coil 2, pin 3 (White / Black).
008 - N190, ignition coil 7, pin 3 (Blue / Red).
009 -
010 -
011 -
012 - G108, Lambda probe 2, pin 3 of connector T4v (Yellow)
013 - G108, Lambda probe 2, pin 4 of connector T4v (Green).
014 -
015 -
016 -
017 -
018 -
019 - A79, climate control panel in dash wiring harness, via T10n/10 (Blue / Lilac).
020 -
021 -
022 -
023 - N31, injector cylinder 2, pin 2 (Green).
024 - N85, injector cylinder 7, pin 2 (Green / White).
025 -
026 -
027 - G70, air mass meter, pin 3 (Black / Green).
028 -
029 - G70, air mass meter, pin 5 (Green).
030 - G5, rev counter, pin 6 of connector T32 behind instrument cluster, via T15u/5 (Black / Lilac).
031 -
032 - Earth connection (screening) in engine compartment wiring harness.
033 - G185, accelerator pedal position sender 2, pin 4/-- via T15e/4 (Grey / Yellow).
034 - G185, accelerator pedal position sender 2, pin 6/S2 via T15e/6 (Brown / Green).
035 - G79, accelerator pedal position sender, pin 1/S1 via T15e/1 (Yellow / Blue).
036 - G79, accelerator pedal position sender, pin 3/-- via T15e/3 (Brown / Red).
037 - G5, rev counter, pin 11 of connector T32 behind instrument cluster, via T10p/2 (Green / Blue).
038 - A16, cruise control connection in dash panel wiring harness via T15e/10 (Black / White).
039 - F36, clutch pedal switch, pin 1 via T15e/13 (Red / Green).
040 - E87, climate control panel, pin A7 via T15u/2 (Black / Yellow).
041 - E87, climate control panel, pin C15 viaT15u/3 (Black / Grey).
042 -
043 - OBD communication, track 193 via T10o/1 (Green / Black).
044 - N112, secondary air inlet valve, pin 2 (Lilac / Yellow).
045 - N261, intake manifold change over valve 2, pin 2 (Green / Red).
046 - J299, secondary air pump relay, pin 6/85 (Blue / Grey).
047 - K83, check engine lamp, pin 14 of connector T32a behind instrument cluster, via T10o/2 (White / Red)
048 - K83, check engine lamp, pin 13 of connector T32 behind instrument cluster, via T10n/2 (Yellow / Brown).
049 - .
050 -
051 - G39, Lambda probe, pin 3 of connector T4u (Red).
052 -
053 - G70, air mass meter, pin 4 (Blue / Green).
054 - Speed signal, Pin 3 of connector T32, behind instrument cluster, via T10o/3 in ECU box (White / Blue).
055 - F47, cruise control brake pedal switch, pin 4 via T15e/12 (White / Red).
056 - F, brake lamp switch, pin 2 via T15e/11 (Red / Black).
057 - E45, cruise control system switch, pin 3 via T15e/9 (Red / Yellow).
058 - CAN-Low, via T15u/14--->A122 (low bus) dash wiring harness--->TCU (Orange / Brown).
059 -
060 - CAN-hi, via T15u/15--->A121 (high bus) in dash wiring harness--->TCU (Orange / Black).
061 -
062 - Constant 12V+ via T10p/4 (Red).
063 -
064 - N80, activated charcoal system solenoid valve 1, pin 2 (Lilac / White).
065 - J17, fuel pump relay, pin 16/85 via T10p/8 (Red / Blue).
066 -
067 - E3, hazard warning light switch, pin 8 via pin 2 of connector T3au (Lilac / Blue).
068 -
069 -
070 - G39, Lambda probe, pin 4 of connector T4u (Lilac).
071 -
072 - G185, accelerator pedal position sender 2, pin 5/+ via T15e/5 (Green).
073 - G79, accelerator pedal position sender, pin 2/+ via T15e/2 (Yellow / Lilac).
074 -
075 - E45, cruise control system switch, pin 2 via T15e/8 (Blue).
076 - E45, cruise control system switch, pin 5 via T15e/7 (Red / Grey).
077 -
078 -
079 -
080 -
081 - Pin 25 of connector T32 behind instrument cluster, via T10o/10 (Yellow).
082 - G28, engine speed sender, pin 3 of connector T3k (Grey).
083 - G188, throttle valve drive angle sender 2, pin #2 (Brown / Red).
084 - G188, throttle valve drive angle sender 2, pin #4 (Black / Brown).
085 - G70, air mass meter, pin 1 (Grey / Lilac).
086 - G40, Hall sender, pin 2 (Green / Lilac).
087 - G163, Hall sender 2, pin 2 (Blue / Lilac).
088 - N33, injector cylinder 4, pin 2 (Brown / Lilac).
089 - N86, injector cylinder 8, pin 2 (White / Yellow).
090 - G28, engine speed sender, pin 2 of connector T3k (Blue).
091 - G187, throttle valve drive angle sender 1, pin 6 (Blue / Brown).
092 - G187, throttle valve drive angle sender 1, pin 1 (Black / Grey).
093 - G2, coolant temperature sender, pin 4 (Grey / Red).
094 - N163, ignition coil 4, pin 3 (Grey / Yellow).
095 - N191, ignition coil 5, pin 3 Grey / Brown).
096 - N30, injector cylinder 1, pin 2 (Brown / Black).
097 - N83, injector cylinder 5, pin 2 (Brown / Green).
098 - G40, Hall sender, pin 1/+ (Green / Black).
099 - G61, knock sensor 1, pin 1 of connector T3bc (white).
100 -
101 -
102 - N, ignition coil 1, pin 3 (White / Green).
103 - N164, ignition coil 5, pin 3 (Brown / Green).
104 - N156, intake manifold change over valve, pin 2 (Green / Yellow).
105 - N145, electro / hydro engine mount solenoid valve, right, pin 2 (Blue / Red).
106 - G61, knock sensor 1, pin 2 of connector T3bc (brown).
107 - G66, knock sensor 2, pin 2 of connector T3bd (green).
108 - G2, coolant temperature sender, pin 3 (Brown / Grey).
109 -
110 - N189, ignition coil 6, pin 3 (Green / Grey).
111 - N158, ignition coil 2, pin 3 (Green / Brown).
112 - N84, injector cylinder 6, pin 2 (Brown / Blue).
113 - N32, injector cylinder 3 pin 2 (Brown / Grey).
114 -
115 - N205 / N208, inlet camshaft timing adjustment valves 1 / 2, pin 2 (Brown / Green).
116 - N144, electro / hydro engine mount solenoid valve, left, pin 2 (Blue / Red).
117 - G186, throttle valve drive, pin 3/M+ (Red / Lilac).
118 - G186, throttle valve drive, pin 5/M- (Brown / Lilac).
119 -
120 -
121 -
Audi S6 4.2 V8 40V (ANK) - Bosch Motronic ME7.1.1 ECU Pinouts.
003 -
004 -
005 - 005 - Z19, Lambda probe heater, pin 2 of connector T4u (Yellow).
006 - Z30, Lambda probe 2 heater, downstream of catalyst, pin 2 of connector T4t (Yellow / White).
007 - N127, ignition coil 2, pin 3 (White / Blue).
008 - N325, ignition coil 7, pin 3 (Blue / Yellow).
009 -
010 - G131, Lambda probe 2 downstream of catalyst, pin 3 of connector T4t (Green).
011 - G131, Lambda probe 2 downstream of catalyst, pin 4 of connector T4t (Yellow).
012 - G108, Lambda probe 2, pin 3 of connector T4v (White).
013 - G108, Lambda probe 2, pin 4 of connector T4v (Brown).
014 -
015 -
016 -
017 -
018 -
019 - N31, injector 2, pin 2 (Green).
020 -
021 - ABS connection (15a), T10n/4 via 10A fuse S7 (White).
022 -
023 - J271, Motronic current supply relay, pin 4/86 (White / Black).
025 -
026 - G70, air mass meter, pin 1 (Grey).
028 -
030 -
031 -
032 -
033 -
034 -
035 -
036 -
038 - A16, cruise control connection in dash panel wiring harness via T17i//10 (Black / White).
039 - F36, clutch pedal switch, pin 1 via T17i/13 (Red / Green).
040 - E87, climate control panel, pin A7 via T17k/2 (Black / Yellow).
041 - 041 - E87, climate control panel, pin C15 viaT15u/3 (Black / Grey).
042 -
045 - N261, intake manifold change-over valve 2, pin 2 (Green / Black). ** ASG (A6 models).
045 - N335, variable intake manifold change-over valve, pin 2 (Green / Black). *** ANK (S6 models).
047 -
048 - N156, intake manifold change-over valve, pin 2 (Blue / Black).
049 - .
050 -
052 -
054 -
055 - F47, cruise control brake pedal switch, pin 4 via T17i/12 (White / Red).
056 - F, brake lamp switch, pin 2 via T17i/11 (Red / Black).
057 - E45, cruise control system switch, pin 3 via T17i/9 (Red / Yellow).
058 - CAN-Low, via T17k/13--->A122 (low bus) dash wiring harness--->TCU (Orange / Brown).
059 -
060 - CAN-hi, via T17k/14--->A121 (high bus) in dash wiring harness--->TCU (Orange / Black).
061 -
063 - Z29, Lambda probe 1 heater, downstream of catalyst, pin 2 of connector T4s (Yellow / Red).
066 -
067 - E3, hazard warning light switch, T17k/16 (Lilac / Blue).
068 - G130, Lambda probe downstream of catalyst, pin 3 of connector T4s (Grey).
069 - G130, Lambda probe downstream of catalyst, pin 4 of connector T4s (Blue).
071 -
072 -
073 -
074 -
075 -
076 - E45, cruise control system switch, pin 5 via T17i/7 (Red / Grey).
077 -
078 -
079 -
080 -
081 -
083 - G188, throttle valve drive angle sender 2, pin 2 (Brown / White).
084 - G188, throttle valve drive angle sender 2, pin 4 (Black / Brown).
085 -
086 - G163, Hall sender 2, pin 2 (Green / Lilac).
087 - G40, Hall sender, pin 2 (Blue / Lilac).
088 - N33, injector cylinder 4, pin 2 (Lilac).
089 - N86, injector 8, pin 2 (White / Lilac).
091 - G187, throttle valve drive angle sender 1, pin 6 (Yellow / Black).
092 - G187, throttle valve drive angle sender, pin 1 (Black / Blue).
094 - N292, ignition coil 4, pin 3 (Grey / White).
095 - N326, ignition coil 8, pin 3 (Grey / Black)
096 - N30, injector cylinder 1, pin 2 (Black / Red).
097 - N83, injector cylinder 5, pin 2 (Brown / Yellow).
098 - G163, Hall sender 2, pin 1/+ (Green / Black).
100 -
101 -
102 - N70, ignition coil 1, pin 3 (White / Green).
103 - N323, ignition coil 5, pin 3 (White / Brown).
104 -
105 - N144, electro / hydro engine mount solenoid valve, left, pin 2 (Blue / Red).
109 -
110 - N324, ignition coil 6, pin 3 (Green / Grey).
111 - N291, ignition coil 3, pin 3 (Green / Brown).
113 - N32, injector cylinder 3, pin 2 (Grey / Green).
114 -
115 - N205, inlet camshaft timing adjustment valve, pin 2 (Brown / Grey).
116 - N145, electro / hydro engine mount solenoid valve, right, pin 2 (Blue / Red).
118 - G186, throttle valve drive, pin 5/M-- (Brown / Lilac).
119 -
120 - N208, inlet camshaft timing adjustment valve, pin 2 (Brown / Yellow).
121 -
