Results 1 to 10 of 10
    Veteran Member Four Rings SLU_S5's Avatar
    Sep 06 2014
    Rochester, NY
    Windshield Washer Sprayer Clogged?
    Just tried to use my windshield washers for the first time in a while but no fluid came out. Fluid reservoir is full and I can hear the usual noise from the sprayer motor(s) when I try to activate it.
    Could it be clogged? Anyone know a solution?
    2010 S5 Prestige 6MT: B.Black:
    APR: Intake // AWE: Touring + non-res DPs, S-Flo filter // CR-15: Brace // ECS: LWFW, Diff Mounts, SS Brake Lines // Eurocode: AK, Sways // JHM: Tune, Short Shifter // KW: H.A.S. // OEM+: B8.5 S-Line Competition+ Bumper, BO S5 Grille, Ecodes, RS5 BBK, 20" RS5 Rotors// SBC: Stg 2 Daily // 034 Motorsport: Intake Pipe, Trans & Motor Mounts, ACAs // Others...
    IG: @SLU_S5
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    How cold is it right now? I've certainly had mine freeze on me before.
    2013 Audi S5 - EPL Stg 2 E40 ECU/TCU, AWE Track 102mm, RocEuro intake, etc.
    2014 Audi Q5 S Line
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Sep 06 2014
    Rochester, NY
    Quote Originally Posted by HazeMyth View Post
    Happened to me a couple times before too. It's in the 60s though. Hasn't been below freezing in about a week.
    IG: @SLU_S5
    Jul 17 2015
    Colorado
    Do you notice anything blocking the nozels? With temps in the 60's I'd be hard pressed to think it's frozen, heh.
    2014 Audi Q5 S Line
    IG: @MrHazeMyth
    Sep 06 2014
    Rochester, NY
    Didn't look that close. Maybe there's some salt or corrosion in the nozzles or something. What's weird is that there's no fluid is coming out at all despite having a full reservoir and what sounds like a functioning pump.
    IG: @SLU_S5
    Jul 17 2015
    Colorado
    Quote Originally Posted by SLU_S5 View Post
    The pump will still function if there's no pressure in the lines. Just be careful about trying to let it run for too long without fluid going through it, because you can easily burn out a motor by doing that. The I/C spray kits on Evo's and STI's were known for burning out when you inadvertently ran them dry, and they work exactly like windshield washer motors in most cars. Inspect the nozzle and see if you see any clogging. Maybe take a safety pin and delicately poke the nozzles to see if they open up. I have actually had magnesium chloride block my washers before on another car. That's the salt crap they put down on the road here.
    2014 Audi Q5 S Line
    IG: @MrHazeMyth
    Veteran Member Four Rings NaiveTurtle's Avatar
    May 20 2013
    Vancouver, WA
    Take a needle or safety pin and poke it through the holes on the sprayer. There are three holes per sprayer. This is also how you adjust the angle on them if you need to. If that doesn't solve your issue then you have a clog somewhere else. Tiny specks of dirty and stuff build up in those sprayers over time if you aren't using them much.
    2008 GMG World Challenge 6MT []S5 Ibis White Matte Metallic Purple/Black Alcantara
    [Mods - GIAC 91 Tune | GMG WC Sport Downpipes | GMG WC Sport Cat-Back | GMG WC Front & Rear Sway Bars | AP Racing 6-Piston Front BBK | 20x9.5 HRE P40's | Accuair B8 Sport Kit]
    2004 Ocean Blue Metallic A4 Avant
    Instagram: @NaiveTurtle
    Deactivated Four Rings
    Sep 15 2008
    Is Big
    Fort Worth, Texas
    Suck on the nozzles while someone activates the washers. Post pics.
    Established Member Two Rings Crusader105's Avatar
    Jul 22 2014
    2010 Subaru Forester XT, 2005 G35 Coupe, 2006, 2015 WRX STI Kawasaki 500R, 1986 RX-7
    Elora, ON
    If none of the nozzles are working, I'd think you've got a blockage or leak in the line that feeds the nozzles vs all the nozzles themselves.
    Or the pump even if it's running it might be toast.
    2010 A5 Prestige in Meteor Grey Pearl/S Line/Tech Pkg/M6/CR-15 Front Strut Brace
    Sep 06 2014
    Rochester, NY
    Fixed it! It appears that the line got pinched between the hood and the hood strut mount when the hood was closed. Moved the line aside and the sprayers work just fine now.
    IG: @SLU_S5
