I was just wondering for anyone who has vented their AEB valve cover, did you install some kind of baffle? I know the AWM has a plastic baffle from the factory, but I was thinking a welding in a little aluminum plate.
99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
Next up E85, efr 7163 or gtx3071r?
01 allroad 2.7t 6mt, GIAC stage 1
2001A41.8TQM Cat delete, 3"exhaust Turbonetics T3/T4 .63 A/R@18PSI, ATP Exhaust manifold, precision Turbo 39mm wastegate, Forge Splitter, FMIC, 80mm TB, SEM Motorsports Intake, AEB ported/polished, 3 angle valve seats with Supertech inconel exhaust valves/SS Intake, upgraded valve springs/ TI retainers, ARP head stud/main bearing stud kit, Skat rods/stock pistons, solid motor mounts, race density trans/snub/diff carrier mounts, stage 4 clutch with SM12lb flywheel, tuning by Motoza Performance
2017 MK7 CSGM GTI Sport DSG
PP (Golf R Brakes, +10HP, VAQ LSD), LP, Kessey
LW 17" Sparco Assetto Garra's, 034 Res-X resonator Delete
2020 SQ7- Wife's ride
2008 RS4- I like this car
2000 S4- Working?
For Sale: 2002 Audi TT ALMS
https://www.audizine.com/forum/showt...EM-Arizona-10K
2000 S4- Working?
r.i.p.CASABLANCA B5 1.8t
r.i.p.BRILLIANT YELLOW B5 30V
PCV?Just dump it on the ground!
2000 S4- Working?
2000 S4- Working?
