Results 1 to 9 of 9
    Dec 09 2015
    neither here nor there
    Question oxygen(o2) sensor & wideband sensor placement
    I picked up an AEM wideband gauge and I'm going to get a custom exhaust built, and I want to know what is the best placement for the o2 sensor and the AEM wideband sensor. ECU will have second o2 delete, so no need to worry about that.
    How far away from the turbine housing do these have to be, any certain angle, and what is the distance these two sensors be in relationship to each other?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Primary must be before the cat. If there is no cat, it can literally be anywhere. Just make it in a convenient spot to get at. At the least, I would have them staggered so they see plenty of flow, and the primary should be first in line since it is the most important.
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    too close it over heats, too far away it can collect condensation.
    best angle is anywhere between 10 o'clock and 2 o'clock.
    in relationship to each other, stagger them and keep them at least 2" away from each other
    all of this sbould be in the instructions from AEM, or at least I would think so
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Think I remember reading that somewhere around 10-12" after the turbo is a good location. I agree with Grape, keep it between 10-2 o'clock, otherwise it can be affected by condensation.
    2001 Corvette (C5) Z06
    Dec 09 2015
    The AEM is still in the mail, so I can't read the instructions, but they probably have them on their site, but didn't think to look until now
    Car is going to be catless too.
    Either way, I still needed to know the best placement for the stock primary o2
    Dec 09 2015
    I see some of you guys going with 3" downpipes and 2.5" the rest of the way. My plans are for a full 3". Is there any reason I shouldn't do a 4" downpipe and 3" the rest of the way back? lol bigger is better in this case, no?
    Veteran Member Three Rings Wrath And Tears's Avatar
    Apr 03 2014
    17 GTI Sport
    I believe the reasoning is fitment. Not only as it goes down by the transmission but also how it connects to the turbo / cat / test pipe. If it was all V-band I could see it working but I don't think a 4inch flange would mate to a 3 inch flange (obviously if you do some weird shit like adapters and whatnot it could work, I don't have experience with that though). Probably some other issues too.
    2017 MK7 CSGM GTI Sport DSG
    PP (Golf R Brakes, +10HP, VAQ LSD), LP, Kessey
    LW 17" Sparco Assetto Garra's, 034 Res-X resonator Delete
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    I think you see diminishing returns for go larger than 3". Plus its going to be a really tight fit for 4". How big is your turbo?
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Dec 13 2010
    FL
    I dont think theres diminishing returns. the best exhaust for a turbo is the one with the least restrictions, or no exhaust at all. I dont see anything wrong with going big post turbo, you want all that air thats already past the turbine to GTFO there as quick as possible, reduced back pressure. now if we were talking runner size on a turbo manifold, thats another story
