Page 1 of 3 123 LastLast
Results 1 to 40 of 91
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    Ultra Racing Strut Brace installed
    For those of you wanting to fit the S4 version I say Do It :)
    I'm in the UK so no AK brace/034 brace available & I don't have the CR-15 either
    Fitted & now wearing a beaming smile
    Steering feel/response/turn in is now so much more precise,the difference is like night & day.
    Well worth every penny IMO,
    A couple of install notes.
    as you can see (below) I have used a couple of cable ties to hold 1 hose out of the way to help prevent any rubbing.
    Other than that it goes straight in
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Jan 24 2014
    United States
    Where did you order from?
    Feb 05 2016
    UK
    http://www.ebay.co.uk/itm/1819889928...%3AMEBIDX%3AIT is the place I used,because at the time I ordered it they had 10% off
    Jan 28 2015
    BMW 435i Grand Coupe 2015
    Melbourne, Australia
    did you have to drill any holes?... my S4 doesn't have any bolts or holes on either side of the shock tower... I looked at this bar last year but definitely no holes for the mounting bolts on my car..
    Established Member Two Rings Danny2323's Avatar
    Mar 30 2015
    Cincinnati
    I'm installing it this weekend. I'll have a review, but I already have the CR-15 and AK, so we'll see what kind of incremental change it makes.
    2014 S4 DSG | Monsoon Grey | B&O | Nav | Sports Diff | Nappa Leather | Carbon Atlas Trim w/ oCarbon Dash | LED Interior w/ Red Ambient Footwells | LED Reverse & Turn Signals | Alu Kreuz | CR-15 Strut Brace | Carbon Mirrors | Llumar 50% Ceramic Tint | Trim Blacked-Out | M'Autolite LED Fogs | Eurocode Drivetrain Insert Kit | Ultra Racing Strut Brace | H&R Sways & MOOG ends | Bilstein PSS10 | SPC adj UCA | HRE FF01 IPA | PSS 275/35/19
    Jan 28 2015
    If you either of you could please take pictures of the mounting bolt points that would be great... I can see two bolts on the top part of the tower on the first picture that i don't have pre-drilled holes for... unless it's only supposed to mount on the two bolts on the lower section of the towers... but would be good to see a close up
    Feb 05 2016
    UK
    The side closest in the pic has 2 threaded studs already in place on my S4.The farthest one is the jump start post (negative terminal)
    Edit
    I pinched a pic on google to show the UK drivers side mounting points
    Nov 28 2015
    Montreal, QC
    very nice !! 1) what is that revo plate ? hold the tubing from moving ? or it's an engine damper ?
    2) any plan on going with the 2 other brace under the car ?
    Veteran Member Three Rings silverf0x's Avatar
    Dec 14 2015
    Montreal, QC
    Sorry for the off-topic, but is that heatwrap REALLY making a difference?
    Murdered B8.5 S4
    Build Thread
    Jan 12 2010
    SE Pennsylvania
    Did this brace come with adequate installation instructions including torque #s for the bolts?
    Did you need longer bolts?
    Install time?
    What changes did you feel...over rough roads, while cornering, during hard acceleration?
    OP, thanks for posting!
    From ebay usa...http://www.ebay.com/itm/182034018390...%3AMEBIDX%3AIT
    2014 S4 Prestige l Misano Red Pearl l Black Alcantara l DSG l Sport Diff l Carbon Inlays l 034 Solid Rear Sway bar w/ Moog End Links l Eurocode Trans Insert l ESC Rear Diff Inserts l CR-15 Strut Tower Brace l Uniden LRD 950 Mirror Tap l Chipwerke Pro
    Previous:
    1994 Ford Taurus SHO w/Yamaha V6, 5 Speed
    1999 Ford Mustang Cobra Convertible, Triple Black, 5 Speed
    2007 BMW 335i 6 speed l Tuned
    Dec 14 2015
    Montreal, QC
    Quote Originally Posted by 4wheelpilot View Post
    Install time?
    Would really like to know as well!
    (ho and thanks for the link)
    Murdered B8.5 S4
    Build Thread
    Dec 14 2015
    Montreal, QC
    Also, would that fit a B8.5?
    Murdered B8.5 S4
    Build Thread
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Quote Originally Posted by silverf0x View Post
    Nope. Its not insulating its reflecting. In the case of an engine bay you'd need to insulate from heat to be truly effective.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Dec 14 2015
    Montreal, QC
    Quote Originally Posted by blackfunk View Post
    Good to know thanks! And actually how much of a Real Life difference does that make?
    Murdered B8.5 S4
    Build Thread
    Veteran Member Three Rings skiptowncat's Avatar
    Nov 13 2014
    Manchester, England
    I would say virtually none. Think about how long an air molecule will be in the intake to be warmed up
    2015 C7.5 S6//DS1 STAGE 3//SRM INTAKES//034 X-PIPE//H&R SWAYS
    Feb 05 2016
    UK
    Quote Originally Posted by waxxonMTL View Post
    The revo plate is part of the revon intake,it holds the weight of the intake tube
    i may do the other 2 in the future,but not immediately
    Actually it does,since fitting the IATs on the P3Cars gauge take longer to rise when in traffic etc
    Install time?
    No instructions where included,so no torque settings are provided.The 2 main anchor points are suspension bolts (1 each side) so torque for those points are as OE fittment
    The other smaller nuts are just steadying the bar so I just nipped those up
    No longer bolts where needed
    Install time 10-20 mins
    Turn in is much sharper & more precise,feedback from the road is much improved whilst cornering & inspires confidence.
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    does the upper engine cover fit back on? or does the bar get in the way of it?
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Feb 05 2016
    UK
    Quote Originally Posted by infinkc View Post
    It fits back on fine :)
    Dec 14 2015
    Montreal, QC
    Thanks for all the info @xpoweruk. Could you just confirm if it fits B8.5 ?
    Just made a 150$ USD offer, we'll see!
    Murdered B8.5 S4
    Build Thread
    Feb 05 2016
    UK
    As far as I'm aware the 8.5 engine bay is identical
    Jan 12 2010
    SE Pennsylvania
    Quote Originally Posted by xpoweruk View Post
    Do you know the oem fitment torque values?
    Thanks for sharing the benefits of this strut brace from your real world driving experience OP.
    Previous:
    Feb 05 2016
    UK
    It's 30 ft-lb + 90° I believe
    Jan 12 2010
    SE Pennsylvania
    Many thanks from this side of the pond.
    Previous:
    Dec 14 2015
    Montreal, QC
    Good to hear! My offer at 150$ was accepted :)
    Murdered B8.5 S4
    Build Thread
    Mar 30 2015
    Cincinnati
    Bad news - I goofed up, and didn't check to see if I had the passenger-side upper studs. My 2014 S4 doesn't have them, but I went ahead and installed it without them. It's attached with only the lower two suspension bolts, and the VERY weak negative jumpstart post. I don't know how impactful it is that I'm missing the upper studs.
    I took it for a short test drive. I have the CR-15 and Alu Kreuz, and otherwise stock suspension (for now, but I have PSS10, sways, and moog end links waiting to go). The UR brace did make a change, but it was very subtle. It might be because of the missing upper studs, and it might be because my front end was already stiffened up significantly, but the improvement was barely noticeable. The steering feels ever so slightly heavier, and just a hair sharper, but barely. With all the stiffening, I feel every little crack in the road. Not too harsh, because the stock suspension eats up bumps, but there's more noticeable "thuds." It almost seems like there's a slight harmonic after hitting cracks, like I can feel the suspension rebound more.
    To be honest, I'm not sure it's worth it if you already have the CR-15 and the AK, but only if you're B8.5. I can't say how much better it'd get if the same combo was performed on a B8, with the proper passenger side upper studs. Maybe it helps, I just don't know.
    Dec 14 2015
    Montreal, QC
    I don't have any bracing so far..
    Murdered B8.5 S4
    Build Thread
    Veteran Member Four Rings 1975audi's Avatar
    Nov 15 2012
    2013 ALLROAD B5 S4
    Ancaster Ontario
    subscribed.
    2007 RS4
    2000 B5 S4 stage 3
    Jan 28 2015
    my car is the same... mine is a 2015 and it doesn't have the two bolts at the top of the tower... So considering it's only held by the two lower suspension bolts and the bracket or mounting plates have all those bends, it makes me wonder if that would still allow for some flex.. It would reduce some no doubt but it doesn't appear solid enough at the mounting plates.. I guess the other option since i know how to weld, it would be to weld extra metal supports at the bends to form a rectangle for added rigidity.... just a thought... I rather weld on the bar than go opening holes or touching the car.
    Nov 28 2015
    Montreal, QC
    wow that suck for b8.5 :( glad you guys did the research :) Like mentionne before, I don't think the fact theres only a lower point holding the bar really ''stop the flex''. A strut bar has to be well fixed to do its job. Maybe we could pin point this thread to UR and they could develop another one ?
    Feb 05 2016
    UK
    It is quite possible that the smaller studs are of no real consequence TBH.
    It is sold as a 2 point brace afterall.
    I would say that because you already have all the other stiffening mods done that flex has already been reduced considerably.
    For instance I imagine if you fitted the UR brace before the CR-15 it may well have felt so good already that the CR-15 had only a small impact
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    so do the B8 cars have more bolts that allow attachment than the B8.5s? It looks like from the two photos the B8 had 3 bolts on one side and 1 bolt and the ground stud on the other. Is this not the same on the B8.5
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Feb 05 2016
    UK
    Also it wouldn't take long to drill a hole pop a bolt through.
    Mar 21 2015
    Just get the cr-15 and call it a day.
    Dec 14 2015
    Montreal, QC
    Hmm I already bought that strut bar thinking it was fitting B8.5.. Will have to sell it back I guess..
    Murdered B8.5 S4
    Build Thread
    Mar 30 2015
    Cincinnati
    Agreed to everything above. I definitely think having everything stiffened up beforehand has made the impact of the UR minimal. If you have a B8.5, and no bracing, then definitely, positively, start with the CR-15. Best bang for the buck. Also, I'm sure missing the upper bolts affects its ability to work right. It results in a pretty significant "lever arm," with the only attachment point being offset from being inline with the bar. Maybe triangulating the bracket would help, but I'm not going to mess with it.
    Jan 28 2015
    i think if this bar was a little bit more reinforced at the mounting plates it may or it could potentially introduce a fraction more rigidity than the CR-15 due to the fact that it mounts directly onto the shock towers, which is where any chassis movement will mainly be generated.. whilst the CR15 sit behind the shock towers... anyway this is all hypothetically speaking as without any measuring devices we will never know.. having both if you have the cash definitely wouldn't hurt or even having one or the other will still provide some much needed rigidity at the front for all of us RHD guys that have been disadvantaged with no RHD versions of the Alu Kreuz or the 034 x-brace...
    Dec 14 2015
    Montreal, QC
    How does the driver side fits where the negative pole is? Does the pole needs to be removed first? And if so, is there any precaution that needs to be taken before removing the pole (like disconnect the positive pole has well?)
    Murdered B8.5 S4
    Build Thread
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    i bet he already made at least 50k in strut sales. very smart and innovative guy!
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Mar 21 2015
    Quote Originally Posted by JeriQo View Post
    At one point a couple months ago he said he was a little over 300 pieces sold. So who knows now.
    Dec 14 2015
    Montreal, QC
    I did sent him a PM but didn't get an answer? Does his reply time normally long?
    Murdered B8.5 S4
    Build Thread
