Results 1 to 4 of 4
    Mar 07 2015
    2003 SL55 AMG, Audi Q7
    San Francisco, CA
    Check engine light - P0235
    Yesterday, i was merging (somewhat agressive) into a freeway and my check engine light came on.
    No error messages on the dash, no other warning lights, no strange behavior. Car was driving perfectly fine at high speed. Did no loose any power.
    I had my OBD adapter in the glove box, so i pulled over and checked the codes. This is what i got:
    OBD2 - confirmed:
    P0235 - Turbocharger/Supercharger Boost Sensor "A" Circuit
    OBD2 - pending:
    P0068 - MAP/MAF - Throttle Position Correlation
    I reset the codes, started the car and drove back home. It was a 120+ mile drive. The check engine light never came back. Car drove fine.
    Let me say that i got this same code about 5 months ago, again, on a ramp, merging into a local freeway, under semi-full throttle.
    Same deal - erased the code and it did not come back for months, until yesterday.
    Car is 2011 S4, DSG, EPL Stage 1 Tune and K&N air filter. Close to 70k miles. Very well maintained.
    What could be the reason behind this code? Why does it get triggered under acceleration? Bad sensor acting up? Software bug after the EPL tune?
    Any ideas?
    DM
    Jul 21 2004
    South Florida
    Could be bad map sensor, throttle body or even a boost leak.
    Mike
    2018 Audi S5
    Gone-
    Jun 07 2015
    B8.5 allroad, Jag F-Type R, B8.5 Audi S4, Ford F150, Ducati SF
    Centennial, CO
    I think I had a similar code on mine twice as well. It was due to a bad fuel, my EPL tune is sensitive to fuel. Since mixing 91/E85, I have never seen it again.
    Established Member Two Rings DankFX's Avatar
    Jul 07 2014
    Quote Originally Posted by danmm7 View Post
    OBD2 - confirmed:
    OBD2 - pending:
    Any ideas?
    DM
    any update.
    2013 b8.5 Audi S4 DSG Estroil Blue | no tune | CTS intake | AWE Touring exhaulst |
    Solorwerks Coilovers| CR-15 | 034 Xbrace | 034 rear sway | 034 Trans mount insert |
