Results 1 to 8 of 8
    Account Terminated Two Rings
    Dec 10 2013
    s6
    Jun 23 2011
    Toms River, NJ, USA
    Do you know what engine code the RS7 uses? Is it more similar to the S8's engine (CGTA) or the S6/S7's engine (CEUA)?
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    MI/CA
    Quote Originally Posted by Vol 4.0T View Post
    I'd like to start a discussion on the specific engine differences between the S6/7 and RS7...
    Start here:
    https://www.youtube.com/watch?v=ra7zTXv1DfU
    2022 Tesla Model 3 Performance
    2023 Genesis GV60 Performance
    2015 Q5 TDi - Torque, baby!
    (Gone) 2013 S6, Glacier White over Black.
    (Gone, never forgotten) 2011 S4 Prestige S-tronic wSTaSIS stuff
    Veteran Member Four Rings hodrosS42001's Avatar
    Mar 18 2012
    New Jersey
    Your one fault is that the RS6/RS7 do NOT have the came compression ratio at the S6/S7... 10:1 (S6) to 9.3:1 (RS7)... which is a HUGE difference in the ability to run higher boost pressure and timing without having knock. Of course cooling and other factors have an impact.. but that is the largest.
    https://dl.dropboxusercontent.com/u/...lf%20study.pdf
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by zcd2.7t View Post
    Interesting at the very end there appears to be 1 second where they appear to show what I believe is the intake/exhaust duration of the camshafts.
    180/200 ºKW on the S7
    190/210 ºKW on the RS7.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Jan 19 2010
    MI/CA
    Thanks but I've already watched it several times. I also have other technical documents and materials on the 4.0T from Quattro GmbH. If you read my post and watch the video, you'll see why I posted what I posted and why the questions still remain...
    For you, maybe, but I'm betting that there won't be too many others who are as obsessed with the detail differences as you are...
    Why not just wait another year or so and buy an RS7 if you want RS7 performance?...
    Good luck with your research, nonetheless.
    Mar 26 2010
    US
    BMW M3 Competition X-drive
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    One thing that you may want to consider if that the RS7 and the S6/7 have different intake plenums. When I say intake plenum, I am not talking about the air box, air filter or turbo inlet pipes (there has been research completed on them, we know the RS components flow more).
    By this I mean that everything from the turbo outlet to the intake manifolds is different. You have a different air to water heat exchanger (sometimes referred to as a brick), a different intake plenum box at the front of the car and different charge pipes that go from the intake plenum to the intake manifolds.
    A lot of people get wrapped up in the external heat exchanger at the front of the car and looking to upgrade it.
    Another huge difference between the two cars is that the RS models have upgraded water and oil cooling. This is typical from Quattro GmBH, they always upgrade the water an oil cooling on RS models.
    I think the research should be put into learning the difference in air flow (CFM) between the two systems.
    One last thing to consider is that there is a huge gearing difference (gearing is a torque multiplier) between the S6/7 and RS models, 1:1 is achieved in different gears, as well as a a different RPM range.
    APR is one of the most thorough and transparent companies when it comes to collecting and sharing data, we are blessed that they have been able to provide products/data for multiple platforms, with consistent testing via their dynapack.
    Just remember, comparing a RS model vs a S6/S7 with RS turbos is not going to be apples to apples, primarily because of the transmission/gearing differences.
