Results 1 to 12 of 12
    Established Member Two Rings SilverRings's Avatar
    Aug 20 2015
    Louisville, KY
    Flywheel HP Calculation from WHP
    I know this one is tricky, but what percentage should S4 Dual Clutch guys use to get Flywheel from Wheel HP? Factors that I see effecting that percentage would be AWD and a Dual Clutch Automatic.
    2011 Audi S4 // P+ // Sport Diff // DSG
    EPL Stage 2 and TCU | AWE Touring Exhaust | 19x10 et42 Forgestar F14s | Ventus V12 255/35/19 | KW Street Comfort Coilovers | EuroCode Rear Sway Bar | EuroCode Trans/Diff Mount Inserts | EuroCode Alu Kreuz Driveline Stabilizer | CR15 Strut Tower Brace | StopTech SS Lines and Fluid | Akebono Euro Pads | Centric High Carbon Discs
    Apr 04 2012
    MSP
    Typically AWD cars have 20% drive-train loss... I'd use that for a rough estimate.
    Veteran Member Three Rings shoe3k's Avatar
    May 18 2015
    weedwhacker
    No where
    Calculating from WHP to crank doesn't work out like you think.
    Using 20% drivetrain loss.
    400hp (crank) * 20% = 80hp loss
    320whp*1.20 = 384, which isn't 400hp.
    Previous: |'18 Golf R | '17 S6 | '15 S4 | '15 STI | '12 GLI Autobahn | '08 Passat | '04 R32 | '05 GTI 1.8t |
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    15-20%.
    Quote Originally Posted by shoe3k View Post
    Calculating from WHP to crank doesn't work out like you think. Using 20% drivetrain loss:
    320whp / .8 = 400
    The proper calculation would be 320 / .80 = 400
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Oct 31 2013
    Morris County, NJ
    I use 20% for awd and 15% for rwd as a ballpark.
    2011 S4 P+ 6mt | AWE Touring | Roc Euro | H&R OE/Bilstein/034 RSB | APR Stage 2 DP + CPS | TSW Bathurst 19X9.5 | Michelin PSS 255/35/19
    Jan 09 2008
    Winnipeg
    Yeah, LINDW4LL has the right math on this.
    Although I thought these cars were not nearly as bad as 20% drivetrain loss. I though it was closer to 15%.
    Although all that really matters (to me anyway) is how much power gets to the ground.
    Oct 31 2013
    Morris County, NJ
    Quote Originally Posted by eurotic View Post
    These cares are closer to 350 crank.
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Quote Originally Posted by mmm def View Post
    This x2. Which means you can't even guesstimate a percentage based on wheel vs OEM claimed HP of 333. And no one knows the true crank figure from the factory since it's all just guesstimates based on wHP dyno readings. Lol.
    Someone needs to throw a spare engine on the crank dyno.
    I've always thought the figure for AWD, manual was like 20-23% loss and normal auto was more like 25-27%. This coming from the A4 b7 world
    2021 Audi S4, P34 Intake
    Established Member Two Rings Hellahashtags's Avatar
    Jan 05 2016
    From APR's website data, it's 15%-20%. For example, Stage 2 (91 pump) is claimed to be 373 WHP and 448 HP.
    May 18 2015
    weedwhacker
    No where
    Quote Originally Posted by LINDW4LL View Post
    15-20%.
    How embarrassing. I"m sitting looking at my post and realized that I never included the last sentence, which was the exact part you added. Thanks for the catch.
    Mar 01 2021
    wilbraham ma
    Just put car on dyno it pulled 373 whp so my calculations are 466 hp at the crank.
    Stage II EPL tune with SC pulley
    Runs like a beast :)
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Because you bumped a 4yrs old thread I'll add this.....APR is the only tuner that I'm aware of that has an engine out dyno for testing. Everyone else is guessing (through calculations) but they all fall within percentage points of each other.
    I won't even get started on different dyno's giving different numbers LOL
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
