Originally Posted by
Danny2323
I can't help you with info yet, but I just got these HRE FF01 19x9.5 ET45 with PSS 275/35/19. They arrived yesterday (thanks TAG!), so I haven't had a chance to fit them. I'll let you know.
Edited to add the offset
PCHS4 runs that exact setup (same wheels and tire size). He had to run something over -2 degrees of negative camber, and deal with a little rubbing in the rear. Nothing major, but something to be aware of.
I say this every 100 posts or so, but I'll say it here since we're not in the fitment thread.... Again, this isn't directed at anyone, just more of a general comment to keep things in perspective. Everyone's car is a little different. When you are pushing the limits in terms of tire size (like a 275), low offsets, or wide wheels, it is going to come down to all possible factors; that's the wheel size/offset, the actual tire you go with, ride height, and alignment specs (including how your subframe is positioned).
Don't be so quick to assume that because something worked for someone else that it will work for you unless EVERYTHING is the same, and that's rarely the case. I try to stick to a more general approach or a range that works as opposed to specifics. It's pretty dangerous to solely rely on what has worked for one person unless you have all of the information I mentioned above. Things like tires and alignment specs make a huge difference when you're pushing the limits.
Just to add to the above.... You can make just about anything work if you really want to. There are people running lower offset 10" wheels (ET33) with 275 tires, but they had to pull and roll their fenders, do some trimming, etc. There's a whole group of people that are fine doing those things, and another that wants a rub free fitment. It's best to decide which camp you fall in before you do anything too aggressive.
