Results 1 to 37 of 37
    Established Member Two Rings rtk8892's Avatar
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    No ac, Econ light not on what to do
    Hello. So my ac is blowing out warm air. I've tested everything with vagcom and its all good. My refrigerant pressure is 5 bar which to my knowledge is good but for some reason I cannot get cold air and I live in Georgia where it's super hot already. Any help on where to start and what to do?
    Established Member Two Rings ajbuckner's Avatar
    Feb 01 2016
    Loveland, CO
    Just click your Econ button off... I turn mine on from time to time and all I have to do is press it to turn it off. Econ just brings air in from outside
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    It doesn't get cold regardless of whether or not the Econ is on or off.
    Veteran Member Three Rings luvsspeed's Avatar
    May 13 2007
    04 S4
    North Carolina
    Quote Originally Posted by rtk8892 View Post
    I'm going though the same thing right now in NC. Sorry to tell , but you will need a new compressor.
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    ^^^x2
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    cheapest thing you could try is to getting the system vac'd, and refilled ,
    May 13 2007
    04 S4
    North Carolina
    Quote Originally Posted by earhythmic View Post
    ^^^x2
    Check your compressor tq
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    The compressor isn't getting torque
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Your AC compressor is likely shot. Since you have pressure in the refrigerant system, the ECON button isn't stuck on, and there likely are no fault codes in the 08-HVAC module then I am willing to bet that you need a new AC compressor, receiver drier, orifice tube, and o-ring seals.
    How many miles do you have? There was a running joke that the B6/7 S4 AC compressors failed every 60K miles like clockwork at one of the dealerships that I worked at.
    May 13 2007
    04 S4
    North Carolina
    I agree with Jimmy, as he as confirmed the same thing with my a/c.
    Veteran Member Three Rings Das Audi's Avatar
    Oct 14 2009
    Brampton
    Quote Originally Posted by luvsspeed View Post
    Me too and add check the pressure sensor on the side of the condenser. The codes should conform the problem for you.
    AKA: fuzzy_onetoo
    Sep 28 2009
    Boston
    Check the ac high pressure switch. If I remember correctly I had my headlight removed when I noticed it was leaking. My ac wouldn't get cold and the econ button wouldn't turn off. I refilled the ac system and heard the hissing sound where it was leaking through the ac pressure switch. It is a much cheaper fix as it cost me under $70 for that little piece.
    2005 Nogaro Blue S4 6spd/Black Leather/FI Catback/JHM Stage 3 Clutch/LWFW/Vogtland Coilovers/H sport sway bars/Ecodes/RNS-E/Cupra R lip/LED's/HID fogs/Carbon fiber wrap/Intake spacers
    2003 Atlas Gray Allroad 2.7t 6spd/Magnaflow catback/Podi custom vent boot gauge/tint/clear corner/5000k 55watt headlights &fogs/TSX-R projector lenses/Cupra R lip/Pionner AVH 3500 BHS headunit/JHM stage 1 clutch & LWFW
    Senior Member Three Rings prfktgntlmn's Avatar
    Sep 24 2011
    2017%20gmc%20canyon%20sle%20
    Atlanta
    Quote Originally Posted by black01s4 View Post
    My ECON light was stuck on. Scan for codes in the HVAC module. If you see G65 High Pressure Sensor fail you might get lucky and have a bad sensor. I used a can of Freon that had a pressure gauge on it from Walmart. Pressure was low. Started filling the system and heard hissing from the driver side bumper which happens to be where the high pressure sensor is located. I removed the electrical connector from the sensor and it started leaking Freon. Installed new sensor. Refilled system. Cleared code. AC is nice and cold now. No more ECON light.
    2007 Audi RS4 Phantom Black/Black Premium
    Jun 07 2014
    phila pa
    if u need ac compressor i just took one off my car to replace with a new one (replacing all accessories with new while engine is out). you can have it for $75 shipped.
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    I might take you up on that, is there any chance that a bad engine coolant temp sensor could cause the compressor to not engage? There's no leaks and no codes for the pressure sensor. The only code I'm getting is for the ect sensor. I got under my car and the compressor is not seized up, it's just not spinning. I can spin it with a long screw driver when the cars running and the the drive shaft in it sits nice and tight from what I can see
    Jun 07 2014
    phila pa
    No idea...
    Sent from my SM-N910T using Tapatalk
    Sep 24 2011
    Atlanta
    You check the fuse?
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    Yeah I checked the fuse, it's not busted. I'm just trying to check every single thing before i order a new compressor and everything else I need
    May 18 2012
    2005 S4
    Portland, OR
    If the compressor is not spinning, something is wrong. That driveshaft should be spinning any time the engine is running. If it's not moving at all, then it possibly sheared off.
    May 13 2007
    04 S4
    North Carolina
    Well if you need a new one.
    https://www.fcpeuro.com/products/aud...or-4f0260805ah
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    Thanks for the link, they actually have them about $100 cheaper on partsgeek.com
    Veteran Member Four Rings FastEddie's Avatar
    Apr 01 2012
    Queens
    Perfect timing. My A/C is not blowing cold so now i have to troubleshoot. Im hoping its not the compressor.
    - - - Updated - - -
    Quote Originally Posted by JimmyBones View Post
    What makes this joke even funnier is i just passed 62k on my dash.
    SUSPENSION-KW V3-Hotchkiss RS4 sway bars-034 Adj UCA-034 strut mount-034 F&R end links-034 motor mounts-034 Snub mount W/bracket-034 Trans mount l BRAKES-ECS Stage 4 BBK-ECS rear rotors & lines, Hawk pads l Engine-JHM Tune-JHM 6 rib pulley-Milltek catless DP's-FI exhaust l EXTERIOR-RS4 black grille-Custom headlights-LED city & DRL lights-ECS LED tail lights & plate lights l INTERIOR-Custom steering wheel-SRP pedals-ECS LED lights-MOMO shift knob-Gen 2 RNSE & AMI l WHEELS-OEM RS4 W/ Michelin PSS
    May 13 2007
    04 S4
    North Carolina
    Quote Originally Posted by FastEddie View Post
    - - - Updated - - -
    Well I hope you make out better than I just did.
    Apr 03 2010
    Northern Virginia
    - - - Updated - - -
    Not so sure that it is funny but rather sad.
    Senior Member Three Rings REVOofRustler's Avatar
    Jan 17 2014
    Redmond, WA
    I guess I'll go ahead and chime in here as well. I bought my B6 at ~150k, and the AC didn't work when I got it. I took it to a shop to have them try to recharge it, and they said the refrigerant was spraying out from the compressor. I'm getting ready to pull my core support off and take care of some other maintenance things, and I thought I might as well take a peek at my compressor while I'm in there. I'm wondering if any of you guys know what I should be looking at in particular? And is there a way I can actually test for leaks at home without the motor/compressor running? I scanned it a couple weeks ago, and the fault I got for the AC system was:
    00819 - High Pressure Sensor (G65)
    07-10 - Signal too Low - Intermittent
    Are there any common leak spots on these systems? Or is it pretty much a crapshoot?
    2004 S4 Avant 6MT Dolphin Grey
    | JHM Tune | JHM Short Throw Shifter Trio Package | Fast Intentions Dual 2.5 Resonated Catback | JHM 4:1 Center Diff | BC BR Type Coilovers | Hotchkiss Rear Sway Bar
    Instagram: tha_notorious_b | rotational.media
    Sep 24 2011
    Atlanta
    Quote Originally Posted by REVOofRustler View Post
    Mine was leaking through the high pressure sensor. Same with black01s4's car. If you still have some pressure in the system you can try disconnecting the electrical connector from the sensor and see if pressure bleeds out from the back of the sensor. Should be able to hear and smell it.
    Jan 17 2014
    Redmond, WA
    I'll have to check that. Where is the high pressure sensor located on our cars?
    Sep 24 2011
    Atlanta
    A little forward and under drivers headlight. I was able to get to it without removing the entire bumper.
    Jan 17 2014
    Redmond, WA
    I'm assuming this is what I'm looking for haha
    https://www.youtube.com/watch?v=1Vzz33IDL4E
    Sep 24 2011
    Atlanta
    Mine wasn't as bad. But could hear it hissing when putting in Freon, with the A/C and car off too.
    Jan 17 2014
    Redmond, WA
    Ok, one more question. I'm guessing that since the pressure switch is detecting low pressure, that my compressor won't be running. If I just start my car and check, will there even be a way to tell if that switch is bad? Or is that something that needs to be checked when trying to refill the system? If so, would it be possible/safe to hook my air compressor up to the condenser and check that way? Just wanna make sure I don't end up with more problems than I start with.
    Sep 24 2011
    Atlanta
    I'm not sure with a compressor. I found the leak by adding some Freon; with a can which had a pressure gauge on it from Walmart. Showed I had no pressure. Started filling to the recommended amount and heard the hissing. Removed the connector from the sensor and I believe the rest of the Freon leaked out from the back of the sensor. I did it with the A/C on but engine off.
    May 18 2012
    2005 S4
    Portland, OR
    Yeah, the system is under some pressure even when off, but if you've had a leak for a while it's probably not anymore.
    Jan 17 2014
    Redmond, WA
    Alright. Being that mine hasnt worked since I bought it over a year ago, im sure there's no pressure in it haha. I'll go pick up an AC recharge kit and test it this weekend. Thanks for all the help!
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    So my driveshaft was sheared off. The new one sits too far in the gear when I put the new compressor and shaft on. Is there a way to fix this?
    Established Member Two Rings scorpioS4's Avatar
    Mar 31 2011
    New Jersey/Delaware,Dover AFB
    Quote Originally Posted by jakeoboy67 View Post
    ^^^ did this at my local shop when I had this same issue and it worked . but I am pretty sure my Compressor is about kick it. original compressor 130k miles
    2k5.5 Moro blue S4 6spd: k&n drop in/FI x-pipe cat back non res/Piggie DP's/JHM 93 octane Tune w-LA/Intake man. spacers/lightweight crankpully/JHM shifter Trio/JHM stage4 lwfw&clutch/Elbow Heater Bypass Kit/Led strip inlays & taillights (fly's V4's)/6000K D1S and 3000K HID Fogs /Cupra R lip/R.
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    Yeah I had to replace my compressor and the driveshaft. I've had ice cold air for 2 weeks now with no problems!
