Results 1 to 22 of 22
    Oct 03 2015
    West Hartford, CT
    Upper Control Arms: Adjustable vs Non
    I am going to be replacing my upper control arms when my car goes in for her 75k maintenance and was curious.. is there value in getting adjustable control arms if i don't have any intention of dropping the car? (or are all upper control arms adjustable and i'm just an idiot)
    M
    2015 Monsoon Grey S3
    2008 Brilliant Red S4 Avant 6MT @thatredwagon
    Veteran Member Four Rings FulhamFTW's Avatar
    Jul 10 2010
    STL, MO
    If you aren't lowering, then non-adjustable is just fine
    Oct 02 2006
    Wadsworth,OH
    No reason to run adjustable control arms unless you are lowered/plan on lowering.
    Jason
    Oct 22 2015
    Wichita Falls, Texas
    Quote Originally Posted by FulhamFTW View Post
    If I am planning on lowering should I budget for adjustable ones then? Not planning on doing anything drastic. Just trying to get to get a little more flush of a look.
    Senior Member Three Rings hkdolphins's Avatar
    Dec 03 2014
    Noggy Avant, B8.5 Allroad
    SF/CA
    I didn't lower it and it replaced with a non one. Report shows one side is off a bit when i did the wheel alignment. Can't adjust more without change it to adjustable one, i was wondering change it or any other options
    B6 Noggy Avant, B8.5 Allroad
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by Maxwild07 View Post
    Unless you don't mind replacing your tires more often due to inner camber wear.
    Other than that you would need to be very particular with tire rotation. Which may require dismounting and remounting tires more occasionally to balance out the additional inner camber wear on the inside tire wall.
    Jason
    Oct 22 2015
    Jason
    Good Stuff. Thanks Jason.
    Veteran Member Three Rings luvsspeed's Avatar
    May 13 2007
    04 S4
    North Carolina
    Quote Originally Posted by hkdolphins View Post
    I just went though the same thing. I did non adjustable on 11/2014 and this January I couldn't get my alignment is spec. I just changed them for adjustable. Honestly I would just save yourself the headache and get the adjustable control arms and be done.
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    Quote Originally Posted by luvsspeed View Post
    bs... unless your REALLY lowered or running bags... there is NOT really a reason to go adjustable.
    that said... (RACECAR) well absolutely run the harshest most adjustable parts you can get.... just find a guy that can actually DO an alignment... remember fellas, a lot of these places have faulty/worn out equipment (catered toward DD cars) or some dumb @zz that dont know how to do anything that is NOT in the book.
    PAST 2004 Audi S4 4.2L 2006 Audi S4 4.2L 25th #167
    2015 Audi B8.5 A4 2.0T P+ S-line JHM K04-R Turbo 3" HFC/Downpipe FMIC Stage 3 K04 ECU and Stage 2 ZF8 TCU tunes ECS-Luft-Technik CIA/Air Scoop/Silicone Intake Tract GFB DV Bilstein Sport Struts/Shocks H&R Sport Springs 034motorsport Catch Can Kit D/L Control Arms/Bushing Rear Sway Bar with Front/Rear End Links 15mm-F/20mm-R Spacers Bullet Nose Studs/Nuts RS4 Honeycomb Mesh Front/Fog Light Grilles
    Jul 10 2010
    STL, MO
    Quote Originally Posted by TarlCabot View Post
    Agreed. There's no reason a competent tech can't get you in spec with regular arms and no lowering. Hell, I'm lowered a bit and the master tech at my dealer was still able to get it damn near perfect.
    Dec 03 2014
    SF/CA
    my Left Chamber is -1.4 (spec is -1.2 to 0.4), shop reinstall the arm again and still can't make it to -1.2. Any suggestion? Thanks
    Jul 10 2010
    STL, MO
    Find a new shop....They should be able to adjust the subframe to help get it into spec. It doesn't make sense that they can't get it within spec if you're still at the factory height.
    Would I need adjustable uppers if I were to use b5 pirch plates on my s4 b7 with standard shocks and springs.
    I need to replace them but don't know if I should get adjustable or standard.
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    Quote Originally Posted by stu_pot View Post
    i have b5 perches and non-adjustable with no problems... im even running a very wide tire details in sig
    Veteran Member Four Rings Silver Streakin's Avatar
    Mar 05 2004
    B8 S4, 17 Expedition EL, 2009 328ix coupe
    NoVA
    Leave it. Stop following the book specs. -1.4 is fine, as long as the other side is close to that too.
    I run -1.9 to -2.0 on mine, my CTSV was like that, same with my B5 A4.
    I run less toe than spec as well.
    2011 S4, 6M, BB/panda, Sport diff, ADS, B&O | UniTronic stage 3 Dual Pulley | MercRacing HX | RocEuro intake | AWE Track & DPs resonated | H&R c/o w/Bilstein B8 rears| 19" VMR 710 & 19" Peelers | 034 trans insert | AK brace | CR15 bar | DEVAL CF Diffuser
    SOLD 2007 S4 DTM, Phantom Black Pearl, manual | JHM | FI | H&R | VMR | 034
    RIP 2001.5 A4 1.8TQMS, Silver/Ebony | APR stage 3 | STaSIS Tracksports | StopTechs
    SOLD 1995 90
    Apr 27 2015
    2005 BMW 745li, 2014 jetta Base Model
    Macomb MI United States
    Actually setting the camber on these cars is quite difficult. The whole sub frame is losened and then shifted back and forth. It's not the equipment it's just a real pita to do it the right way.
    I'm gonna go with the 034 oem density ones.
    Need to get my fenders rolled first before I put the pirches on.
    Jan 29 2010
    north ga
    got these bad boys for sale:
    just bought a brand new rebuild kit for them. already put on the heim joints, just need to have the new bushings pressed in and they're pretty much a brand new set.....just $120 cheaper
    $315 shipped
    Veteran Member Three Rings DarrenOman's Avatar
    Nov 03 2014
    2009 Gray A3
    California
    Quote Originally Posted by BCsniper View Post
    $315 shipped
    Where did you get the rebuild kit from. I didnt know you could get an upper arm rebuild kit?
    Would worn control arms add to vibration? I have some around 120/130 kmh
    Sent from my SM-G920F using Tapatalk
    Jan 29 2010
    north ga
    034 adjustable arms are rebuildable. Go to their site and find the kit for $95. The arms themselves should last forever, it just the bushings and joints you need to replace every so often
    Nov 03 2014
    2009 Gray A3
    California
    Okay, so our stock arms are not rebuildable, just replaceable.
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by DarrenOman View Post
    You can replace the bushings but once the ball joint goes bad the arm is junk.
    Jason
