Results 1 to 8 of 8
    Established Member Two Rings 029kid's Avatar
    Nov 13 2006
    Audi A4 2017 Avant 2.0 TFSI
    Oslo, Norway
    Squeaky clutch, normal?
    I just had my car back from Audi dealer as the clutch was making a weird noise.
    I think they replaced the cylinder Clutch or something but now i hear a new squeak!
    See video, is this normal? Audi told me it would go away over time as the new cylinder had to settle.
    Is this true, i dont trust this dealer...
    Video
    https://drive.google.com/file/d/0B3B...p=docslist_api
    Veteran Member Three Rings englishbay's Avatar
    Sep 30 2009
    Vancouver, Canada
    No thats not normal. I had a similar thing and it was done under warranty there is a TSB or something similar. They ended up taking lots apart and I was able to get a new clutch installed with no labour. If its still under warranty you'll be fine other wise you may have to check the TSB details to see what part has been upgraded. Either way the clutch has to be taken apart.
    B8.5 S4 DSG | APR UC/TCU | APR Intercooler System | APR Intake | Bilstein PSS10s | Ethanol Sensor
    Sep 30 2009
    Vancouver, Canada
    Quote Originally Posted by englishbay View Post
    there is a TSB.
    TSB# 2022990/1 - do a search and you will find lots of posts on this issue.
    Nov 13 2006
    Oslo, Norway
    Thanks for replying.
    Can you tell me what parts the dealer replaced ?
    I registered at ERWIN and found this TBS 2024335/5 regarding clutch:
    https://drive.google.com/file/d/0B3B...ew?usp=sharing
    Ive never used Erwin before but when trying to do a search under "search referance media" for 2022990/1 or 2022990/3 I cant find anything in ERWIN on my VIN.
    I asume that means there is no other TBS for my clutch ?
    When i search for clutch there is no other meaningful TBS regarding squeaky clutch.
    The dealer did replace the pedal/master cylinder as the 2024335/5 says, and the squeak is worse than ever.
    So Im basically fucked.. ?!
    I got 370 miles left of warranty...
    Nov 24 2013
    NYS
    In my case they replaced clutch fork (part 0B1141719K) and ball pin (parts 0B1141777B and 0B1141751) per TSB 2022990/4. (BTW, I got that TSB on erwin, it's titled "30 Creaking or clicking noises when using clutch pedal".)
    Nov 13 2006
    Oslo, Norway
    Do you have a 2.0 TFSI Q ?
    What year model ?
    Nov 24 2013
    NYS
    2010 A4 2.0T Quattro
    Jan 03 2013
    Baltimore
    Quote Originally Posted by palmface View Post
    Same for me. Squeaking went away and the pedal felt much less grainy than before. All covered under my CPO warranty. Took them about 2 weeks and in the process my alternator took a shit while they were test driving it, so i got that replaced while it was in as well.
