Results 1 to 12 of 12
Thread: Oil additives?
    Established Member Two Rings mahunik's Avatar
    Dec 06 2015
    New York, Clifton Park
    Oil additives?
    After calling AOA and my local audi dealership I was told that nothing really can be done to help rebuild my motor due to having 110k miles . I'm slightly pissed off because I bought the car from a certified audi dealership with 95k miles obviously not knowing of an oil consumption issue (FYI burns 1 quart per 1500-2000 depending on driving). So im assuming they knowingly sold this oil burner to me. I talked to a good friend who has been in the automotive industry for 50 years and he knows of the issue. He stated that the main reason these cars start to burn oil is because of the long drain intervals of 10k miles and told me that I couldnt do much but to instead change oil every 3k not every 5k like I have been doing. Now the question I made this post for, Any of you guys know of some additives that would be safe to add to my car? Should I try 5w30 instead of 5w40? and what other input would you suggest? ALL help is appreciated from you fellow Audi owners, thank you
    Also I have been using Audi recommended Motul Specific 5w40 and Liqui Moly 5w40
    And one last question, would it be stupid to go APR stage 1 considering I already have a oil problem?
    2010 Audi A4
    6 Speed Manual
    Premium Plus
    30% Tint all round
    RS5 Honeycomb Grill
    Valentine One Radar
    Weather tech laser fit mats
    110,XXX Miles
    Veteran Member Three Rings Peter.dupuis's Avatar
    Jun 28 2015
    2018 Atlas
    Bend, OR
    Oil additives?
    This is a fuel additive my local Audi dealership said would be good for the cleaning the engine. I have 53k miles right now and do an oil change every 5k and add this to the gas tank. Maybe a little excessive now but I think it'll be better further down the line.
    I did the same for my b7 that still ran perfect on the original motor when I sold it at 198k
    Feb 13 2004
    Silicon Valley, CA
    Before you "blame" the long drain intervals, run the service history on your car. There was an oil burning issue with the 2009-2012 models. First phase of the fix was a new PCV and software update. Second phase was new rings. This is well documented in the 3rd sticky in this forum. Cars have been known to burn up to 1qt per 500 miles. I know that after I had the fix, I have not had to add oil between 10k changes in 4 years now.
    Kevin - Moderator, Audizine
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Changing the oil every 3,000 miles is ridiculous. Longer intervals are not the root cause of consumption.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    I use liqu moly ceratec along with the castrol edge oe professional oil.. ( only oil that lights up bright blue under black light)... Also use the above oe fuel additive every 1500 miles along with shell vpower that's always used....
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Mar 21 2015
    My buddies 2010 A4 just got redone due to oil consumption with 96k on the clock and out of warranty. Try another dealer.
    Mar 28 2012
    Houston
    add oil when necessary, 3k changes are going to get old really quickly
    Active Member One Ring GreyGoose11's Avatar
    Jul 15 2015
    Michigan
    Quote Originally Posted by hyperunion View Post
    I love the ceratec, I also use
    You may also want to use the Liqui Moly Ventil Sauber for rings etc.....
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    You need to run 0w40 instead.
    Feb 10 2009
    '01 A4, '87 Chevy 1 Ton
    Knoxville, TN
    1qt per 1500-2000 miles sounds like typical VAG oil consumption. You don't need to change oil every 3k miles. Just stick with every 5-7k mile oil changes. Next oil change use a heavier oil like a 15w40
    1988 Shelby Dodge CSX-T, 2.5L 4cyl, T04E 40 trim w/ .63 A/R, Stg2 Ported 8v Head (Sold) it was a torque monster!!! :(
    2001 A4 1.8T turbo back 2.5in exhaust, SB clutch w/ 17lbs SMFW, Forge splitter, Revo stage 1 flash, 4:1 Center diff, ST Coilovers, 034 RSB, Forge FMIC.
    Dec 06 2015
    I thank you all for the help and answers but in terms of having it rebuilt at 110k I think its nearly impossible. Talked to two dealers and AoA and each time they said I would've had to be in the 80k range which means im over 30k miles over that. Does anyone know if these worn rings will effect compression? I also talked with the audi service department and they recommended not to use any kind of oil additives but instead just add oil.
    2010 Audi A4
    6 Speed Manual
    Premium Plus
    30% Tint all round
    RS5 Honeycomb Grill
    Valentine One Radar
    110,XXX Miles
    Veteran Member Three Rings Jacon's Avatar
    Jan 05 2009
    B8 A4 6MT P+
    Ft Worth TX
    Have you tried switching oil brands? The dealers use Castrol because they're paid to, but I've had the best luck with Motul 5w-30.
    I drive an 09, put a quart in every 2500 miles and change at 5K. I get the least amount of consumption with Motul. I've never had the oil consumption problem many have stated, but then again, I broke the engine in properly from day 1 and have been the only owner.
    My current rides...
    Audi
    Jetta
