Results 1 to 7 of 7
    Veteran Member Three Rings 2BblkAudis's Avatar
    Feb 15 2007
    San Mateo, CA
    DIY for Xenon bulb replacement
    Anyone have any experience swapping out the Xenon bulbs on a Q5?
    Tried searching and didn't find anything.
    Just want to know if it's straight forward of if things need to get removed to access the back of the housing.
    Thanks in advance.
    Veteran Member Three Rings rusq5's Avatar
    Mar 26 2015
    SF Bay Area
    Its easy. There is a panel on the back of the light. Once open there is a ring that must be turned to unlock, then the bulb comes out.
    Check out step 3.
    http://www.audizine.com/forum/showth...ighlight=Ecode
    -Rusty
    2022 RS6 Deep Green/Cognac
    2019 RS3 Nardo/RS Design
    IG: @grn_rs6
    Feb 15 2007
    San Mateo, CA
    doom,
    thanks for the response. I guess in a nutshell it's easiest to remove the headlight assembly for bulb replacement. I really didn't want to pull out the airbox etc.
    Thanks for the reply.
    Mar 26 2015
    SF Bay Area
    I don't think you need to. The how to is for replacing the US spec headlights with the eu spec. I think you can access the hatch while the lights are in.
    -Rusty
    IG: @grn_rs6
    Senior Member Two Rings SpyderMR's Avatar
    Mar 06 2008
    Tampa, FL
    I changed mine out a few weeks ago, the driver side is easy. Passenger side you will have to move the airbox a little so you can reach a bolt holding the headlight. You have to move the headlights a little forward so the cover on the back can be taken out. At least that's how mine was.
    Joey
    2014 SQ5 Panther Black Crystal
    Ecodes and LED Fogs
    Otherwise stock for now...
    (Gone but not forgotten)
    2005 allroad 2.7T Tip
    APR 91, 93, valet
    17Z BBK, H-Sports
    B6/B7 300mm Rear Rotor upgrade
    Magnaflow Catback & Vast Piggies
    Mar 26 2015
    SF Bay Area
    Also the airbox is super easy to pull out. only 2 screws for the funnel part. The actual box is just set in some rubber mounts. Perfect time to port some holes in and rip out the snow guard!!
    -Rusty
    IG: @grn_rs6
    Mar 13 2013
    Chicago Western burbs, Il
    Quote Originally Posted by SpyderMR View Post
    Joey
    Agree - just need to slide the lights forward, no need to take out. These are some of easiest HID's I've ever changed. You will need to take airbox out but that's an easy job once you do it. Clean hands and no touch bulb.
    If anyone is looking for upgraded D3S's OSRAM or Philips take a look at:
    http://www.hidconcept.com/
    mike@hidconcept on audizine is a good resource to ask questions.
    '21 Atlas 2.0 AWD, Stg1 93/Stacked JB4 E25, Eibach Springs, AFE Catback
    '18 mk7.5 Golf R STG 2 E30, TCU, IC, Milltek DP/HFC, AW SwitchPath
    '12 Golf R APR S2 93 HPFP W/iABED RCF, IC, UM Haldex, Milltek HFC, SMF STG2, Fluidampr, RVC, PSS10, PolarFis
    '08 R32 UM ECU/DSG, Schrick 268/264,Milltek Headers/HFC, Corsa Catback , RNS 315/RVC, PolarFis
