"2.0 R4 16v TSI/TFSI (EA888)Edit
Manufacturing commenced March 2008.
identificationparts code prefix:
06H, 06J;
ID codes:
CAEA, CAEB, CAWA, CAWB, CBFA, CCTA, CCTB, CCZA, CCZB, CCZC, CCZD, CDNB, CDNC, CHHA, CHHB, CJXA, CJXB, CJXC, CJXD, CJXE, CJXF, CJXG, CYFB
engine displacement & engine configuration:
1,984 cubic centimetres (121.1*cu*in) EA888*inline-four engine*(R4/I4); bore x stroke: 82.5 by 92.8 millimetres (3.25*in ×*3.65*in), stroke ratio: 0.89:1 - undersquare/long-stroke, 496.1*cc per cylinder; compression ratio: 9.6:1 (10.3:1 A3 Cabrio 2009), 88*mm (3.46*in) cylinder spacingcylinder block & crankcaseGJL 250 grey cast iron; 33*kg (73*lb), die-forged steel crankshaft with five 58*mm (2.28*in) diameter main bearings, two chain-driven counter-rotating*balance shaftssuppressing second degree free inertial forces and oil pump, horizontal-baffled oil sump. The water pump bolts to the side of the block, under the intake manifold, and is driven by a toothed belt and a pulley on the back of the intake-side balance shaft.cylinder head & valvetraincast aluminium alloy; four valves per cylinder, 16 valves total, low-friction roller finger cam followers with automatic hydraulic valve clearance compensation, toothed chain-driven double overhead camshaft (DOHC), continuous vane-adjustable*variable intake valve timing.
Audi variants have two-stage*"valvelift"*inlet valve lift variable controlaspirationhot-film*air mass meter, cast alloy*throttle body*with*electronically controlled*Bosch*E-Gas*throttle*valve, plastic*variable length controlled intake manifold*with charge movement flaps controlling combustion chamber air movement, IHI water-cooled*turbocharger*incorporated in exhaust manifold, sandwiched central front-mounted*intercooler*(FMIC)fuel systemfully demand-controlled and returnless; - fuel tank–mounted low-pressure fuel pump;*Fuel Stratified Injection*(FSI): single-piston high-pressure injection pump driven by a four-lobe cam on the exhaust camshaft supplying up to 190 bars (2,760*psi) fuel pressure in the stainless steel common rail fuel rail, four combustion chamber sited direct injection sequential solenoid-controlled six-hole fuel injectors, air-guided combustion process, multi-pulse dual-stage injection during the induction and compression stroke with homogeneous mixing, stratified lean-burn operation with excess air at part load, 95*RON*ultra-low sulphur unleaded petrolignition system & engine managementcentrally positioned longlife spark plugs, mapped direct ignition with four individual direct-acting single spark coils; Bosch*Motronic*MED*17 electronic*engine control unit*(ECU), cylinder-selective*knock*control via two knock sensors, permanent*lambdacontrolexhaust systemcast iron exhaust manifold (with integrated turbocharger), close-coupled and main*catalytic converters*- both ceramicDIN-rated motive power & torque outputs and applications -
Non-valvelift*variants125 kilowatts (170*PS; 168*bhp) @ 4,300-6,000 rpm; 280 newton metres (207*lbf·ft) @ 1,700-5,000 rpm — CAWA:*VW Tiguan125 kilowatts (170*PS; 168*bhp) @ 4,300-6,200 rpm; 280 newton metres (207*lbf·ft) @ 1,700-4,200 rpm — CCZC:*Audi Q3, engine is installed transversely,*VW Tiguan132 kilowatts (179*PS; 177*bhp) @ 4,500-6,200 rpm; 280 newton metres (207*lbf·ft) @ 1,700-4,500 rpm — CCZD:*VW Tiguan147 kilowatts (200*PS; 197*bhp) @ 5,100-6,000 rpm; 280 newton metres (207*lbf·ft) @ 1,800-5,000 rpm — CCTA/CBFA: 2009*VW Golf Mk5 GTI*(US only),*VW Golf Mk6 GTI(US only),*Audi Q3*(US Only),*VW Jetta Mk5,*VW Jetta Mk6,*VW Passat B6,*VW CC,*Audi A3 (8P)147 kilowatts (200*PS; 197*bhp) @ 5,100-6,000 rpm; 280 newton metres (207*lbf·ft) @ 1,700-5,000 rpm — CAWB:*Audi A3Cabriolet,*VW Scirocco,*VW Tiguan, CCZA:*Audi TT,*Škoda Superb Mk2 (3T),*Škoda Octavia155 kilowatts (211*PS; 208*bhp) @ 5,000-6,200 rpm; 300 newton metres (221*lbf·ft) @ 1,800-4,900 rpm — CPSA:*Audi Q3, engine is installed transversely155 kilowatts (211*PS; 208*bhp) @ 5,300-6,200 rpm; 280 newton metres (207*lbf·ft) @ 1,700-5,200 rpm — CCZB:*VW Golf Mk6 GTI,*VW Scirocco,*VW Passat B6,*VW CC,*VW Tiguan, SEAT Altea Freetrack, SEAT Leon FR.DIN-rated motive power & torque outputs and applications.
Valvelift*variants132 kilowatts (179*PS; 177*bhp) @ 4,200-6,000 rpm; 320 newton metres (236*lbf·ft) @ 1,500-4,000 rpm — CAEA/CDNB:*Audi A4 (B8),*Audi Q5,*Škoda Kodiaq155 kilowatts (211*PS; 208*bhp) @ 4,300-6,000 rpm; 350 newton metres (260*lbf·ft) @ 1,500-4,200 rpm — CAEA/CAEB/CDNC:*Audi A4 (B8),*Audi A5,*Audi Q5,*SEAT Exeo155 kilowatts (211*PS; 208*bhp) @ 4,300-6,000 rpm; 350 newton metres (258*lbf·ft) @ 1,600-4,200 rpm — CESA:*Audi TT Mk2 (8J), engine is installed transversely.162 kilowatts (220*PS; 217*bhp) @ 4,500-6,200 rpm; 350 newton metres (258*lbf·ft) @ 1,500-4,400 rpm — CHHB:*Audi A3,*Skoda Superb,*VW Golf Mk7 GTI,*Škoda Octavia RS165 kilowatts (224*PS; 221*bhp) @ 4,500-6,250 rpm; 350 newton metres (258*lbf·ft) @ 1,500-4,500 rpm — CNCD:*Audi Q5169 kilowatts (230*PS; 227*bhp) @ 4,700-6,200 rpm; 350 newton metres (258*lbf·ft) @ 1,500-4,600 rpm — CHHA:*VW Golf Mk7 GTI Performance,*Škoda Octavia RS230195 kilowatts (265*PS; 261*bhp) @ 5,350-6,600 rpm; 350 newton metres (258*lbf·ft) @ 1,750-5,300 rpm — CJXE:*SEAT Leon Cupra206 kilowatts (280*PS; 276*bhp) @ 5,100-6,500 rpm; 380 newton metres (280*lbf·ft) @ 1,800-5,500 rpm — CJXA/CJXB:*SEAT Leon Cupra,*Skoda Superb. (Audi S3*and*VW Golf Mk7 R*in some foreign markets)213 kilowatts (290*PS; 286*bhp) @ 5,900-6,400 rpm; 350 newton metres (258*lbf·ft) @ 1,700-5,800 rpm — CJXD:*SEAT Leon Cupra215 kilowatts (292*PS; 288*bhp) @ 5,400 rpm; 380 newton metres (280*lbf·ft) @ 1,800 rpm — CYFB:*VW Golf Mk7 R*in North America (lacks*MPI)221 kilowatts (300*PS; 296*bhp) @ 5,500-6,200 rpm; 380 newton metres (280*lbf·ft) @ 1,800-5,500 rpm — CJXC:*Audi S3,*VW Golf Mk7 R*(Europe),*SEAT Leon Cupra228 kilowatts (310*PS; 306*bhp); 380 newton metres (280*lbf·ft) — CJXG:*Audi TTSreference"Audi adds 2.0 TFSI with Valvelift to A5 Coupé".*PaulTan.org. 25 June 2008. Retrieved*4 September*2009.
"SEAT Exeo with new engines".*Auto-motor-und-sport.de. 3 May 2008. Retrieved*5 May*2010."
From,
https://en.m.wikipedia.org/wiki/List..._engines#EA888
Sent from my SM-G930VL using
Audizine mobile app
