Results 1 to 7 of 7
    Established Member Two Rings BB c7's Avatar
    Jan 23 2016
    Chicago
    Will 20x10.5 rims w/ 255 35 20 tires work on 4 corners on our A6 c7
    Hello all
    Will 20x10.5 rims work for the REARS and FRONTS without rubbing issues?
    i will be using 255/35/20 tires.
    i will be at stock height with sport package.
    Thanks.
    Jan 30 2015
    2012 A6 3.0T Prestige + others
    Irvine/CA
    Quote Originally Posted by BB c7 View Post
    Hello all
    Thanks.
    Offset?
    - Michael
    2012 A6 3.0T Prestige:
    GIAC Dual Pulley 57.1+187 / Merc HX / Injen Intake / OEM muffler mod (Quad Tips + X-Pipe) / Eurocode drivetrain inserts / 034 Swaybar / Volk wheels / Bilstein+Eibach / RS front grill / Deval Carbon rear diffuser / Maxton Front Spoiler and Side Skirt add on / Carbon trunk spoiler / Carbon mirror / Stoptech rotors.
    Veteran Member Four Rings madyspop's Avatar
    Nov 19 2005
    07 S8, 07 V10 Treg, 11 Stasis S4, 13 S6
    Central IL
    255's will be extremely stretched on a 10.5" wheel.
    13 S6 Glacier Stage 3 llllllll APR DP's l Akrapovic l EC sways, endlinks and Alu Kruez l 034 mounts l Garrett GTX2873 turbos l Custom ECU/TCU tune l 3m tint l CETE Bluetooth Lowering Module l Escort 9500ci built in radar/laser diffuser l AWE Gen 2 intake l Xpel l P3 Gauge l RS 6 Grill l E-codes l APR HE l Carbon Designs valance & mirror caps l Dynamic tails l facelift rear bumper l 20" BBS CX-R on Blizzaks l 20" HRE P101 on Mich PSS l 034 density mounts
    Established Member Three Rings HackDevil's Avatar
    Jan 23 2016
    chicago
    It depends on the wheel. I have a friend on insta that has 20x10.5 et42 Vossen with 275-30 and they fit perfect.
    13 Audi A6 3.0T Prestige Oolong Grey
    Here's my: Instagram / Build Thread / YouTube
    Veteran Member Three Rings Demandred's Avatar
    Jul 24 2011
    2016 Merc CLA250 Shooting Brake
    Auckland, New Zealand
    I looked at some 10.5" rims for my S6 and with the offset they would have hung out past the guards
    COuldn't get them in an offset that would fix that - I imagine you are more spoilt for choice there though
    Now : 2018 Mercedes E63S
    Previous: 2017 Audi RS6 Performance Avant....Too many other Audis
    Mar 14 2008
    Audi S5, Porsche 718 Spyder, Audi RS5
    MA
    Hello all
    Thanks.
    Do not do this. You might get the wheel fit, but the wheel offset will have to be precise to the millimeter. A 255 tire, however, is WAY too stretched on a 10.5" rim. A 255 will sit best on an 8.5 to 9" rim. That said, if you are into that super stretched look, then the 255 should have enough stretch to clear the fender even under compression. Aesthetically, however, even if you like the super stretched look, you really need the car lowered to even remotely pull it off.
    Current Fleet: Porsche 718 Spyder * Audi S5 Sportback * Audi RS5 Sportback
    On order: Audi RSQ8 Performance
    Jan 23 2016
    Chicago
    Thanks for the replies guys. I am still green on this stuff but still learning :). Now i know. Only reason that i asked because, i found i good deal on 20x10.5 wheels. I Thanks again folks.
