Results 1 to 19 of 19
    Feb 11 2016
    Eugene/Oregon/US
    Coilovers or springs with struts?
    Looking to drop my 2013 S4 a bit, but trying to decide between coilovers, or short springs with performance shocks/struts.
    Opinions?
    Registered User Four Rings Jay@JXB's Avatar
    Dec 21 2014
    2018 Silverado 3500 HD DRW, Bart the Big Ass Red Trailer.
    Milwaukee
    I started with H&R Sport with Bilstein Sport shocks. Very good option for street use, cuts down on body roll a lot and still rides very nicely.
    Since I autocross and track my car a ton though I threw on Bilstein PSS10 coils this year. Turned into an absolute monster on the track. With coils set at 10/10 dampening it's backbreaking on the street. My girlfriend complains about her boobs hurting every time we hit a bump. However with dampening all the way down at 1 it actually rides really nice. The shocks feel about the same over small bumps and rough pavement but the springs are certainly stiffer, giving you that "tossing you around" feeling when you go over dips and pavement transitions in intersections. The H&R Sports never did that.
    Sent from my VS986 using Tapatalk
    Apr 04 2012
    MSP
    I'm very happy with my HR OE springs and Bilstein B8 Sport shocks. Before that I only had the OE springs with OEM shocks and it was quite bouncy and un-composed. I cannot compare it to coils as I've actually never driven a B8 S4 with coils but for road use I think the ride and performance of the suspension as I have it is perfectly dialed in - I do have several other suspension and frame upgrades though which all add to the ride... I won't ever adjust my suspension so the need for adjustable coils is pointless to me... and the risk of them (coils) rusting in this climate also was a deterring factor.
    Mar 03 2016
    Dublin, OH
    Go with the coilover since the labor charge will be the same.
    Jul 21 2005
    Springs - fixed height. Coilovers are adjustable.
    I see post like "I can lower for summer, raise for winter". Unless you know how to corner balance and have equipment to do so, you're better off with springs. Manufacturer already did the legwork testing them.
    Coilovers usually have dampers that are matched perfectly to springs it came with. You have to find good dampers to match your set of springs. To me, this is where the coilovers outshine springs.
    Damper (valving) adjustability is not an issue for street and occasional track since you can get adjustable struts/shocks for springs as well. Tunable dampers are must haves for serious track use, but only if you have the knowledge and experience to do so. Remember that Formula One teams use driver + telemetry + engineers + mechanics to adjust suspension. Even then the setup is still a compromise for any given track.
    You also have to maintain coilovers. Those threads attract dirt.
    My $0.02.
    2007 Ibis White A3 3.2 S-tronic
    18" Audi BBS CH, Sport Seats, OpenSky, Bluetooth, Sirius radio, Sport Pedals
    Jan 18 2015
    If your budget allows look into something like the Bilstein ride control b16 setup. On comfort it's more comfortable than stock and in sport it's plenty stiff for canyon driving. I don't track my car however. There's no need to corner balance with coilovers, most people would never be able to tell or care for street driving.
    Jul 21 2005
    Quote Originally Posted by Rocket Tech View Post
    Basically, you just play with adjustable valving once ride height is set like a spring + adjustable damper combo. Only difference is push button if you have electronic ride control.
    Veteran Member Three Rings blingaling's Avatar
    Feb 12 2011
    05 ninja 636(RIP)
    NEPA
    I have springs, they perform better than stock but not as good as coils. For the price i love em and i dont plan on going to coils. For the price difference cant beat it. But depends what your budget allows. I preferred my money to go more toward other things.
    Sent via smoke signals
    Oct 31 2013
    Morris County, NJ
    H&R OE springs on Bilstein sport dampers. Very composed, smooth ride. Super happy with it. I'm a set it and forget it guy plus I was never going to adjust the height so this works for me.
    2011 S4 P+ 6mt | AWE Touring | Roc Euro | H&R OE/Bilstein/034 RSB | APR Stage 2 DP + CPS | TSW Bathurst 19X9.5 | Michelin PSS 255/35/19
    Jan 18 2015
    Quote Originally Posted by 40ventiller View Post
    Kind of - the b16 kit has a predefined comfort and sport valve setting. I used to run koni adjustables but found myself constantly tweaking and never being quite happy with where I was at. The settings Bilstein have selected for this kit are great.
    Jul 21 2005
    It must be a pain adjusting Konis. Don't you have to remove struts/shocks to make adjustments? I think Bilsteins are better in that department.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Bilstein Sport Shocks with Eibach springs (called a b12 kit), install and forget, no maintance, very good ride quality.
    Oct 31 2013
    Morris County, NJ
    That's correct
    Veteran Member Four Rings SDV325's Avatar
    Jan 20 2014
    Calgary, AB
    I chuckled at this as well. I ran coilovers (Teins and PSS9's) on my Impreza GC8 for 7 -8 years, not once did i raise or lower it for a Canadian winter lol. Heck i barely changed the dampening with the exception of track or auto-x days.
    We all have the best intentions for stuff like that haha
    2016 Audi SQ5 | Technik | Glacier White | Magma | Black Optics | Beaufort Inlays | Roc-Euro | Revivify Graphene Pro | EPL Stg 2 | Eurocode USS | MOOG Endlinks |
    2014 Audi SQ5 Estoril- STOLEN / RIP
    2015 Toyota Rav4 - Family Wagon
    Aug 07 2011
    Montreal
    Are you guys ever concerned about premature wear on the bushings or other parts? I'm dying to lower but read a lot about other parts wearing out ahead of time.
    15' S4
    Jan 18 2015
    I ran them on my mustang, the adjustments were on the top of the shock and at the bottom, no need to remove. I imagine the adjustment is pretty similar to the pss10s if I'm remembering correctly.
    I was realistic about how much adjusting I would do given my history with the konis. Single push button from the inside of the car is the way to go!
    Jul 21 2005
    You can't access from top on Audi B8s both front and rear. PSS10s have adjustment on bottom. Dampers are actually inverted inside tube.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    The large majority of people with coilovers will never adjust their ride height after setting it initially. A quality shock/spring setup can be just as good. If you have no need to adjust ride height, then it simply comes down to the price difference between two comparable setups (coilovers vs springs/shocks)
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Jan 09 2008
    Winnipeg
    Quote Originally Posted by Habber View Post
    I've heard the same thing and some of that can be mitigated. Control are bushings are the best example. Control are bolts should be tightened with the arms at ride height so when the car is at rest there is no tension/ twist on the bushing. When you lower the car and don't adjust that, it's like the car is sitting with the suspension in compression and there is tension on the bushings. They need to be reset to their new normal resting position.
    Shocks are the same if you just install springs as the shock will be under more compression even when at rest.
