Results 1 to 15 of 15
    Established Member Two Rings Bklynjay's Avatar
    Jul 10 2012
    Brooklyn, NY
    Tried but no luck - VAG code to show D1,D2,D3,D4 etc. and DRL to be brightest setting
    Hi Guys -
    Last summer I met up with AZ member we were able to some popular codes like needle sweep, turn off front side amber marker, and VIM. But we did fail in showing the gears while in Drive or Sport mode. Maybe we changed a value wrong since he did mention it was from a B8 code where most worked. Anyone knows exactly where and what the value should be for 2010 C6.5? Would also like to make the DRL as brightest setting possible too.
    Thanks All!
    2010 A6.5 Quattro | G.I.A.C Stage I | Ibis white | Prestige Package | Side assist and cold weather package | 10% tint all around | Tinted tails | Debadged - only rear Audi Black rings | 7" TV headrest OEM bolt on with MMI | 2013 S4 19" Peelers | K6 Eyelids | Quad Rear Diffuser with Porsche 911 Exhaust Tips | Aluminum Pedals | DRL Fog LED Strip with on/off switch
    Veteran Member Three Rings cal3thousand's Avatar
    Feb 19 2013
    2006%20Audi%20A8L%3B%201994%20Volvo%20850%20Turbo
    Quote Originally Posted by Bklynjay View Post
    Hi Guys -
    Thanks All!
    Do you have the color screen in the middle of the dash?
    FWIW, my 2009 Prestige has that already from factory. My 2007 S-line Avant (also MMI 2G High with color screen) did not and I never found the option to turn it on.
    If you find it, please post back. So many post and runs on this forum
    Danton Black: 2009 Audi C6.5 A6 Sedan (Quattro, 3.0T, Prestige)
    I miss my Avant, longing for a 2011 3.0T
    Dead:
    Griselda, aka Grizzy: 2007 Audi C6 A6 Avant (Quattro, S-Line)
    Just some small cosmetic mods while getting to Stage 0
    Veteran Member Four Rings maga4's Avatar
    Aug 12 2011
    Olathe, Kansas
    I've tried to get this on my C6.5 for a while too. The module is different than any of the other Audi lines (most notably B8) and just doesn't have the traction to dig through and find it.
    I talked to Ross Tech a while back about trying to get it, and they said they could do a screen share with me to walk through the different adaptations. Life has gotten in the way so I haven't had a chance, but it may be worth looking at.
    2010 A6 3.0T Prestige, Quartz/Black
    35% Tint, VCDS, Hardwired V1, LED Interior/License Plate, Chipwerke Pro, WeatherTech
    Previous: 2011 A4 P+, APR Stage 2, 35% Tint, Eibach Pro-Kit, VCDS, Gloss Black Grille, Fogs,
    LED Interior/License Plate Lights, Short Shifter, BFI Catch Can, V1, Rieger Lip Replica, FRT's FMIC, aFe Filter
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    Toronto,ON
    I have a 09 cdn model and it shows what gear I'm in in auto mode. D2 D3 D4 ect ect. Can u post the steps to how to disable the amber side markers?
    C7 S6 / AWE Touring / -14mm / EuroTails /
    Jul 17 2011
    Sin City, USA
    Quote Originally Posted by ichi d View Post
    My 2009 also shows the current gear on the center display in all 3 modes; Drive, Sport and Manual. I dont recall if I had this coded or was the way I got when I bought the car.
    '09 C6.5 A6
    Feb 15 2016
    Salt Lake City, UT
    Would be nice to see on the 2010 A6 C6.5. Only time I see D1 D2 D3... is if I use the paddle shifter. But after few sec it reverts back to D or S.
    Jul 10 2012
    Brooklyn, NY
    This worked for me to disable front amber side marker. I have 3G MMI. Damn, so no luck so far. Sigh.
    Disable amber corner lights
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 10
    Submodule 0
    Bit 3 - Set to 0 to disable amber side markers (U.S. vehicles)
    Mar 20 2012
    2012 Audi Q5 2.0t
    portland or
    do you see gears in sport mode? I dont?
    2012 Q5 2.0T
    2010 A6 3.0T
    2004 A4 Avant 6spd 1.8T (SOLD)
    1998 A4 quattro (SOLD AND MISSED)
    2006 Suzuki sv650
    Jul 17 2011
    Sin City, USA
    Quote Originally Posted by seanentrust View Post
    Yes I do.
    '09 C6.5 A6
    Mar 20 2012
    2012 Audi Q5 2.0t
    portland or
    Yes I do.
    when you paddle shift?
    2012 Q5 2.0T
    2010 A6 3.0T
    2006 Suzuki sv650
    Jul 17 2011
    Sin City, USA
    Yep.
    '09 C6.5 A6
    May 10 2013
    Toronto,ON
    Yep.
    +1 I see it in all modes too.
    Mar 20 2012
    2012 Audi Q5 2.0t
    portland or
    Yep.
    I guess I do too, but when i'm in sport mode and paddle shift is it still in sport mode? does that make sense? is that a dumb question?
    2012 Q5 2.0T
    2010 A6 3.0T
    2006 Suzuki sv650
    Jul 17 2011
    Sin City, USA
    That doesn't make since. When I am in sport mode and use the paddle shift, it will switch to manual and display M1, M2 etc. If I don't use the paddles any longer it will switch back to sport mode.
    '09 C6.5 A6
    Feb 15 2016
    Salt Lake City, UT
    +1
