Results 1 to 40 of 53
    Veteran Member Three Rings eightamrock's Avatar
    Jan 21 2016
    Floor Jack Failure
    I wanted to post a little PSA as we are starting to swap out winter tires for our summer shoes.
    Remember to use jack stands! My 2-ton sears floor jack decided to fail mid tire swap today. I pumped up the first tire, threw under my jack stand and started taking the wheel off when I saw the jack just sink slowly back to resting position. The valve must have gone bad because there was no hydraulic fluid leaking, or any other signs of failure. It just would no longer hold any weight. I had to finish the swap with my widow maker, which made me very uncomfortable.
    Now I'm in the market for a new floor jack. I like the schwaben low pro, but I cant seem to find any reviews on it. I found a few threads with people saying they have them, but I was just curious for more details about the quality. I've inherited that sears jack which has to be at least 25 years old now, Ive had it myself for at least 10 years handed down to me by my father-in-law. Looking for something that will last the next lifetime.
    Any thoughts?
    Jun 29 2015
    Issaquah, WA
    Costco has a low profile jack Arcan 3.25 ton for around $100. I use it and am more than happy.
    Sold:
    2014 Daytona Gray RS5 Prestige
    Sold:
    2012 Audi S4
    Veteran Member Three Rings kobrian85's Avatar
    Oct 23 2012
    I'm using a Harbor Freight nothing-special-something, I think it's a 3-ton. It works as intended, nothing special, was a gift a few years ago, they are pretty inexpensive.
    The only thing I would do differently is get a low profile, like the Schwaben one you link, but that's only because I'll likely have a lowered car for the next several years. That said though, the one I have worked ok with my previous JSW on coils, it was a pretty tight fit, but it worked.
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    I have this one front Harbor Freight. Works great.
    http://www.harborfreight.com/3-ton-l...ump-61253.html
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Jan 21 2016
    Quote Originally Posted by kobrian85 View Post
    The 2-ton sears jack I had did not fit under the car at stock height with the pinch weld adapter on it. I had to put the adapter on and then slide the jack under it. I definitely plan on a set of coil overs in late summer, so I think a low profile is a wise choice for me. I found some pittsburgh brand stuff at harbor freight. Looks identical with the same dimensions and capacity as the schwaben, but its $200 less. I imagine these are mass produced somewhere and companies just slap their logo/colors on them.
    Jan 21 2016
    Quote Originally Posted by jmeenach View Post
    I was just looking at the aluminum version of this one for about $90 more. Do you think the steel or aluminum construction make a difference? Im not lugging it around, I only use it in my garage....
    Mar 17 2014
    Los Angeles, CA
    Quote Originally Posted by eightamrock View Post
    If they have the same rating, I wouldn't be more concerned about one than the other. I just went steel because it was cheaper. The only time I regretted my choice was when I had to lift it by myself into the back of a bronco on 38s. Wished I had the aluminum one in that moment
    instagram
    Oct 23 2012
    Out of curiosity, which pinch weld pucks did you decide to go with?
    I think at the end of the day, a jack is a jack. And if you are responsible, you should be using jack stands anytime the car is in the air anyways.
    I have a buddy who rocks a couple of the nice aluminum 2-ton Sears jacks, and they are really nice and seem well built, but at nearly $200 I'm not sure it's that worth it when I can get a 3-ton from HF for under $80. And like you said, the HF 3-ton low profile is $100.
    Jan 21 2016
    hahaha! Looks like a family trip to harbor freight is in order today. Weird question, but do you know the inner diameter of the saddle on that lift? The pinch weld adapter I bought from protech needs at least 4.5" diameter to fit.
    Jan 21 2016
    Yeah I have an old steel set of stands that are equally as old as the jack, but they are in great shape.
    I went with this http://protechproducts.com/index.php...&product_id=56 for the pinch weld adapters.
    Apr 04 2012
    MSP
    I need to get in the habit of using stands... even just to have standing there while the car is up.
    Where do you position them? Just at the pinch weld as close to the jack as you can get?
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    Quote Originally Posted by MrFunk View Post
    Thats where I put them. Theres room on the pinch weld to fit the jack and the stand. I know people put them in other places, but thats been easiest for me so far.
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Jan 21 2016
    Quote Originally Posted by DannyDeez View Post
    I haven't found a great spot for them that's not over the pinch weld either.
    '19 Daytona Gray RS5 Sportback
    Options: B&O Sound, Dynamic, Navigation, Black Optic, RS Driver Assist, RS Stitching
    Mods: Suntek PPF wrap
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    ... Looking for something that will last the next lifetime.
    Any thoughts?
    I've had several jacks over the years, ranging from Craftsman heavy duty to the lightweight aluminum "racing" jacks. When I got the S4 I decided that it was time to get a high-quality jack that would last as long as me (or longer). I got an AC Hydraulic DK20Q jack from Pelican Parts. These jacks are Danish made and their quality far surpasses anything I've had or used before; they're in the professional/commercial use range. They have a "quick lift pedal" allowing for quickly raising the jack, and go as low as 80mm saddle height. They are rated up to 4400lbs capacity. See details at Pelican's AC Hydraulic page. One last item is that you can also adjust the drop speed on this jack. See this video that describes making this adjustment. Not sure how many other jacks have this feature. Found a few reviews on Amazon.
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Jun 17 2010
    Madison WI
    Quote Originally Posted by stigster View Post
    I also have this jack, from Costco. Works great for swapping tires on both the S4 and SQ5.
    2015 6MT S4, EPL Stage 2 no more...
    2010 6MT S4, APR Stage 2 no more...
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    http://www.harborfreight.com/15-Ton-...ump-60569.html Ive used this one for years. On car and Suv's No issues what so ever. But I use jack stands when i get under the car.
    Mar 21 2015
    Quote Originally Posted by chaos2984 View Post
    I have the same one, it's great.
    Established Member Two Rings o1brit's Avatar
    Jul 16 2015
    2004 Mini Cooper S - MC-40
    Grand Rapids, MI
    I as well use this one and it does everything expected. Price point is solid. Always check fluid levels prior to first use. I've heard stories of failures due to users failing to do this even though the manual clearly states to do so.
    Glad you used jack stands and it didn't fail at a more inopportune time. Could have been a completely different PSA. Thanks for sharing
    2012 S4 - Ibis White, Prestige / Titanium, 6MT
    -APR Stage I, Bilstein/H-Sport Suspension, Roc Euro Intake, RS4 Mesh Grille, Hoen Endurance Fogs, P3 MultiGage, BFI Magma shift knob, Ziza LED light kit
    Jan 21 2016
    Quote Originally Posted by o1brit View Post
    Do you know the saddle diameter by chance? It's not listed, just curious if my protech adapter will fit.
    Yeah, learned years ago that you have to use jack stands. A lot of people just trust the jack, especially when they are just doing a quick tire change.
    Jul 16 2015
    Grand Rapids, MI
    Off the top of my head, I don't. I'd go measure quick but all of my possessions are on a moving truck somewhere in the Midwest. If somebody else doesn't chime in, I'll try to get a measurement for you this weekend.
    Jan 21 2016
    Quote Originally Posted by BillyG View Post
    My wife has a Q7. It takes a lot of height to get those wheels off the ground. A good option.
    Oct 23 2012
    I had to fill my HF jack with oil after I got it assembled, doesn't come out of the box ready to use.
    Nov 29 2013
    Silver Spring, MD
    I bought a Hein-werner. Rock solid, but it was overkill and wasn't low-profile . Sold it and bought an OTC racing jack. No complaints so far.
    2017 BMW F80 M3 | Mineral Grey | BBS FI-R | AWE Non-resonated Exhaust | M Performance HAS | Ceramic Pro
    Gone but not forgotten: 2014 S4| Phantom Black| BBS CI-R Platinum Silver 19 x 9 ET 42 | 3M Crystalline 40 Tint | Opti-Coat Pro | Bilstein Coilovers | SPC UCAs | EuroCode ÜSS Sways/Links | Alu Kreuz | Roc-Euro | 034 Trans Mount | RS5 Front BBK | ECS Street Shield | AWE Touring 102s | AWE ColdFront | RS4 Grille
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    http://m.harborfreight.com/15-ton-co...ump-60569.html
    This one has worked well for me, and never had an issue fitting it under my lowered A4.
    2021 Audi S4, P34 Intake
    Established Member Two Rings Danny2323's Avatar
    Mar 30 2015
    Cincinnati
    2014 S4 DSG | Monsoon Grey | B&O | Nav | Sports Diff | Nappa Leather | Carbon Atlas Trim w/ oCarbon Dash | LED Interior w/ Red Ambient Footwells | LED Reverse & Turn Signals | Alu Kreuz | CR-15 Strut Brace | Carbon Mirrors | Llumar 50% Ceramic Tint | Trim Blacked-Out | M'Autolite LED Fogs | Eurocode Drivetrain Insert Kit | Ultra Racing Strut Brace | H&R Sways & MOOG ends | Bilstein PSS10 | SPC adj UCA | HRE FF01 IPA | PSS 275/35/19
    Veteran Member Four Rings vwblackb5's Avatar
    Jun 26 2007
    New Jersey
    Here's my Non-widow maker setup. I use both for my B5 and the B8.5. I'm still on winters for both, but will prob switch next week.
    - 1.5 Ton Aluminum Race Jack Harbor Freight (low profile)
    - Ebay Special Polyurethane Jack Pad adapter
    - 2x Wheel chocks
    - Wheel Hanger (M14x1.5)
    - Long reach protecta sockets
    - Breaker bar
    - Torque wrench
    - Impact wrench + Torque limiting sockets
    - Spare 2 Ton Steel Craftsman Jack (standard height)
    Fitment on the B8.5 S4 pinch welds
    Fitment on the B5 pinch welds
    16 B8.5: S4 | Premium Plus | Ibis White | PNY | PPS | GH2 | 1BL | Black Nappa | CTS
    99.5 B5: K04-015 / GIAC PC-16 / 315cc Genesis / Custom FMIC / 034 TP / TT Downpipe / Jetex Catback / Forge 007P / ECS AFPR @ 2.7Bar / ABD Tuning Intake / Blinktek Heatshield / Koni FSD / Eibach Pro Kit / SouthBend Stage 2 Endurance OFE HD / 312mm Slotted A8 BBK
    Mar 30 2015
    Cincinnati
    Quote Originally Posted by vwblackb5 View Post
    Just a helpful tip if you're considering getting one of the blue aluminum jacks from Harbor Freight - the hoop handles on either side can be removed with a hex wrench, allowing more room to squeeze in a jack stand next to the floor jack on the pinch weld. I actually just removed one of the screws, and rotated the handle out of the way.
    May 13 2011
    2015 BMW F30
    @vwblack
    more info on the impact wrench? do you need to have more than one battery around?
    | Autospeed | JHM | Pure MS
    Jun 26 2007
    New Jersey
    Quote Originally Posted by Danny2323 View Post
    Agree with redundancy of having a jack stands, but the handles are pretty handy on the jack :) FWIW, having a wheel hanger in place of one of the bolts allows you to remove the wheel and rest the new wheel/quickly get a couple lugs in a less than a minute (unless seized/stuck). In any note, always recommend putting the spare wheel underneath, just in case if jack stands are not available.
    Quote Originally Posted by S4 00 2.7 View Post
    @vwblack
    It's an 18V Makita XWT02Z. Actually have multiple batteries (1) 3.0AH and (2) 2.0AH I got with my other Makita kit (Impact Driver and Drill). You can definitely do full wheel swaps with a single battery charge with room to spare. Plenty of torque, paired with long reach protecta sockets (for removing) and torque limiting sockets (for installing), highly recommend
    Mar 21 2015
    I never payed attention or tried to removethe handles. Those things keep it from rolling under the side of my toolbox. I'm taking one off tomorrow. Thanks for the heads up.
    Oct 23 2012
    @vwblack
    I have a Dewalt impact, I never feel like I'm remotely close to needing more than one battery for a full remove and reinstall.
    2019 RS5 \ Sonoma Green
    IG: kobrian85
    May 13 2011
    2015 BMW F30
    thanks guys! I was asking about battery life in case I worked on a couple cars in one day.
    Apr 04 2012
    MSP
    I use the same jack and puck. I'm going to remove the loop handle as suggested...
    Jun 17 2010
    Madison WI
    That it does, and that is exactly why I grabbed the jack from Costco. My previous jack didn't go high enough for the SQ.
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    I had a jack from Sears that started to fail too! Nicknamed him Sir Squishy.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Jan 21 2016
    [QUOTE=vwblackb5;11516621]Here's my Non-widow maker setup. I use both for my B5 and the B8.5. I'm still on winters for both, but will prob switch next week.
    - 2x Wheel chocks
    - Breaker bar
    - Torque wrench
    Great setup. I use an impact driver to set the lugs then use a torque wrench to cinch them down to the proper spec. Does your impact driver do that in one shot or do you still have to torque the bolts? Im not familiar with torque limiting sockets. They sound incredibly efficient.
    Jan 21 2016
    Great tip! I have my eye on this jack, seems a lot of members are using them.
    Jan 21 2016
    This is awesome! Thanks for the photo.
    The protech one I have is 4.5" in diameter, but it has an outer lip that makes up the additional .5". I'm 99% sure I can just shave it off and it will fit perfectly on the pad.
    Jun 26 2007
    New Jersey
    Aren't you glad you kept the S4 :) Anyways, yes impact Wrench (not driver) to break the lugs loose and then remove using standard impact socket. The torque limiting sockets is basically a rod with a steel spring. When it reaches a certain torque it flexes under the load and that absorbs the impact of the gun. They only work with impact wrenches, if you use them with a breaker bar it won't limit the torque.
    The reverse process goes hand tightening the lugs, then use impact wrench with (torque limiting socket @ 75 ft*lbs) -- star pattern, and lastly finish off with a torque wrench (star pattern) all the way to 90 ft*lbs. Remember, when removing you can apply a larger amount of torque. When installing, you have to distribute the torque evenly and to the specified spec.
    Jan 21 2016
    LOL Yes! It is definitely growing on me, glad I kept it. I haven't chipped it yet, but I have my list of upgrades growing. I'll post a build thread once I really start getting at it.
    I do the same process but without the torque limiting sockets. Do you torque with the wheel off the ground or after lowering the car down? I have read in many places over many years that since these are hub centric it doesn't matter. It's also the way I've been doing it since my first GTI many many years ago. I drive the bolts to get the tire lined up properly, drop it and torque the bolts (star pattern) Curious what others are doing.
