Originally Posted by
koolade9
Running a harness like that is a tragedy waiting to happen. Find yourself a fabricator and have them make you a proper harness bar. Or don't run one at all. The point of the harness is a safety device. Take a minute and run though the scenarios of what could happen to the occupant in that harness if the vehicle were hit from various places. (hint: don't count on the unibody staying rigid in an accident)
koolade, due to what I reasearched prior to purchasing the belt I decided in favour of the QuickFit.
If you can take the time and read what I found, I would gladly like to hear your thoughts about it.
I don't know if you know the manufacturer Schroth. They supply their harnesses for various types of motor-sports, including F1, WRC, etc. With the harnesses that are dedicated to street cars, that can be used on the track or at rally events, they also provide the appropriate TüV and ECE certification, which is mandatory in most EU countries. With that TüV and ECE the harnesses can also be used on various track events. To get this certification in Germany, various crash tests have to be performed.
But that is all nice in theory.
In practice at the end of the day,
it's my neck that is going to snap if I crash - so I did a lot of research:
1st thing as you mentioned - harness bars, which raise the angle of the shoulder straps upwards, to prevent compression of the spine when the belt tightens in the event of a crash.
I don't have a problem with this angle, due to the holes in the bucket seats placed higher and myself being a bit short - I'm around 5'8'' (I won't say very short :P ) - the shoulder straps leave my shoulders in an upwards angle towards the holes in the seat - thus the holes acting as a harness bar to prevent spine compression.
2nd thing as with any 4pt harness is the missing 5th belt (Anti-Sub belt) that goes between your legs - this prevents the body slipping under the lap belt in the event of a crash.
With the Schroth you get the Patented ASM technology - flexible fibres that in the event of a crash let the body lean forward a couple of degrees, before slowly tightening (with this they also reduce the inertia on the body). When the upper body is tilted slightly forward it cannot push the pelvis under the lap belt. With this ASM technology Schroth quick fit belts are the only 4pt safety belts that can also legally be used on the road. This means they also comply with the E13 regulation here in the EU.
3ed thing is the use of any harness type, be it 4pt, 5pt, 11pt (I'm exaggerating here) WITHOUT a roll-cage, which is very dangerous in the event of a roll-over of the car. Because if the roof is pressed in and your head gets squished, because it can't "fiddle" out of the way due to the static belt.
I take this danger into account as the bucket seat headrest is a lot higher above my head and in the event of the roof coming down, the seat would be folded back, also allowing my body to move/break backwards. But honestly I'm not intending to flip my car any time soon - if I have to, I will rather do that with a dedicated track car, fitted with a proper roll-cage.
Bonus:
An added bonus is also that the quick fit integrates into the existing safety system of the road car. Because it plugs into the OE female connectors, the air-bags and tensioners are regulated normally as if using the OEM 3pt harness.
Audi has only the pre-tensioner at the base of the OEM 3pt harness, so tat is useless for the QuickFit. But Mini and BMW have an added tensioner on the female lap-belt connector, so in the event of a crash this would also tension the after-market harness like it was the OEM belt.
Here are actual crash tests of the QuickFit and the ASM technology:
https://www.schrothracing.com/sdocs/...Crash_Test.wmv
https://www.schrothracing.com/sdocs/SchrothASMII.wmv
VAG installation instructions:
https://www.schrothracing.com/docs/V...structions.pdf
Sorry for the long post, but I wanted to share what I found when I was doing the research on harness options. What are your thoughts on this subject?
@badblue: the QuickFit and other harnesses from Schroth can easily be combined with HANS devices, but can also be used without. At events where a HANS device is mandatory, there are also various other regulations: roll-cage, fire prevention system, etc.
Depends on the event. My current over all track time is about 2-3 hours per year, so not much, just the occasional open track day or driver training with instructors. If I manage to get more free time to attend the track, I would also fully dedicate a second car just for this purpose.
