Results 1 to 33 of 33
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    Radiator repair or replace
    I have an 04 automatic S4, the radiator has a small leak on the top left if you are looking into the engine bay, i will post pictures later, it is a very small leak that I can tell, and the person who had it before me must have used bondo or JB weld on it at some time, should I take it to a radiator repair place or just try to spend the 1200 on a new and have it installed, which if a replacement is necessary it will have to be a while. someone told me to add pepper to my radiator and that will fix it, and I kinda felt like smacking him..
    Maybe heat it up a bit in that location and use a braising rod, similar to making welds on brass tubing?
    Ideas, thoughts appreciated, going to take it to the radiator repair place this week to get an estimate on it.
    Oct 05 2015
    Billings, MT
    May 18 2012
    2005 S4
    Portland, OR
    Although the B6 automatic radiators are stupidly expensive, they are not $1200. Currently ECS Tuning has them for $624. Repairing radiators might work as an emergency fix to get yourself home from somewhere, but I would never advise it as a permanent solution.
    Veteran Member Three Rings MidwestB6's Avatar
    Aug 01 2013
    1970 Ford Maverick
    Iowa City
    https://jhmotorsports.com/shop/catal...h=21_56_61_240
    Same thing happened to mine, just replace it.
    2004 Light Silver 6MT S4
    Oct 05 2015
    Billings, MT
    Quote Originally Posted by MidwestB6 View Post
    link doesn't work, Also, the 1200 was what Audi told me.. if I can find one for around 600 then that would be awesome! Thanks I will check ECS.
    https://www.ecstuning.com/Audi-B6_S4--V8/ES436187/ is the one i found, I thought the manual vs tiptronic had different radiators.
    this one is a bit more expensive https://jhmotorsports.com/shop/catal...on-p-1143.html 779.95
    May 18 2012
    2005 S4
    Portland, OR
    Quote Originally Posted by Terry.Reese View Post
    Yeah, the link tries to take you to a sign-in page. I do have a JHM account but the same happens when I click it.
    Never just take Audi's price at face value. They charge a fortune for parts because they can, and many people don't question it. These are still pricey cars for sure, but not nearly as bad as you might be led to believe if you just got all your parts from the local dealer.
    8E0121251AB is your part number, ECS was the best price I could find but it did look like it was on sale. Next best price I found was $730 or something like that at genuineaudiparts.com.
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Thanks for the support!
    Veteran Member Three Rings jr1415us's Avatar
    Mar 08 2011
    Chicago IL
    The b7 radiators are under $400.
    2013 Arctic White Allroad Premium Plus
    RIP 04 S4 Avant 2012-2017
    Oct 05 2015
    Billings, MT
    Quote Originally Posted by jr1415us View Post
    Link? How hard are they to make fit for a B6
    May 18 2012
    2005 S4
    Portland, OR
    My understanding is that they work fine on manual cars (and in fact is what mine currently has installed on it) with a couple minor tweaks, as detailed on JHM's site, but that the auto ones are not interchangeable.
    Mar 08 2011
    Chicago IL
    http://www.jimellisaudiparts.com/pro...wd=&origin=pla
    Aug 31 2011
    Lathrop
    Here are our radiators: https://jhmotorsports.com/shop/catal...r+main&x=0&y=0
    We also have a DIY to adapt a B7 radiator into the B6 chassis to save some money!
    Senior Member Three Rings hkdolphins's Avatar
    Dec 03 2014
    Noggy Avant, B8.5 Allroad
    SF/CA
    http://www.amazon.com/Volkswagen-8E0...ilpage_o06_s00
    Basically its ship by GenuineAudiParts.
    I just replaced my one with lower and upper hose last Nov. This should be the best online price i found.
    The original part end with "AB" ($800) but Audi already updated the listing to "AJ" ($350) one.
    B6 Noggy Avant, B8.5 Allroad
    Oct 05 2015
    Billings, MT
    ^ and that will work for tiptronic automatic?
    By the way, those mats are amazing, everyone loves them!
    Dec 03 2014
    SF/CA
    Oct 05 2015
    Billings, MT
    sweet, I found the part on Jim Ellis for 302.95 and that's with shipping, If I call them I can probably get my military discount added to that also. Thanks for the Part number!
    Oct 05 2015
    Billings, MT
    So I called Audi and they said that my model will not work with the one's you provided, I have to get the E0121251AB which is a fuckton of more money, like almost 900.00$ looks like I am going to scour the parting out forums..
    Oct 05 2015
    Billings, MT
    If anyone can confirm that the AJ version can actually fit to the 04 S4, the 05 had a body change halfway though and they said the AJ fits that one.
    Senior Member Three Rings ImAudiHeree's Avatar
    Jun 30 2014
    Mercedes Metris
    Sacramento, CA
    The AJ will work fine no problem, have it in my current vehicle Audi is trying to blow smoke up your ass to try and make a buck. Just buy the B7 radiator and be done with it. Literally all you have to do is bend the ac pressure switch on the condensor maybe an inch tops for hood clearance i just grabbed it with my hand and did it. Save yourself $600 and a headache trying to find older one.
    Oct 05 2015
    Billings, MT
    Thats what I was looking for ^^, someone who has done it. Thanks. much more relieved now.
    Dec 03 2014
    SF/CA
    Quote Originally Posted by ImAudiHeree View Post
    can you post a pic where the switch need to bend? My shop replaced the radiator months ago and didnt mention any change they need to made. thx
    Nov 12 2015
    Oregon
    for what its worth, i just did my radiator. STUPID easy to change. Took like 30 minutes....only because i didn't know what needed to be done to change it. From when i was looking at replacing mine, the 2 radiators are interchangeable if you bend the AC pressure switch.
    (manual, not auto)
    don't let people who are only in it to make a buck tell you it cant be done. That's why these types of forums are around. Good luck!
    My build log
    Jun 07 2013
    West
    First you have to clean up that my-garage-technology "fix". Then try your own. I would replace it. It is a CRITICAL engine component and if that leak happened more are sure to come. Not to mention the reduced cooling capability of it by now the insides are not good. These engines run HOT.
    Nov 12 2015
    Oregon
    There is no question about it. Replace it. Don't ever put stop leak or anything into the radiator/cooling system ( unless it's life or death... ex: you're stuck in the middle of nowhere and it blows out because you"fixed" it instead of replacing it.)
    Just my 2 cents. And don't bother with a used one. You'll be doing this again sooner if you do. Good luck!
    My build log
    Oct 05 2015
    Billings, MT
    So back to the main question then, I see everyone is talking about manual, mine is an automatic(tip-tronic), not trying to beat a dead horse here, but I don't want to order one and then have it not work because I have a automatic and not a manual.
    Thank you all for the insight and patience with me. I am the newbie when working on my Audi, little intimidated at times on some things, but you all make it sound easy so I feel confident.
    Nov 12 2015
    Oregon
    https://jhmotorsports.com/shop/catal...on-p-1682.html
    this should be all the information you need!
    My build log
    Oct 05 2015
    Billings, MT
    Quote Originally Posted by VinnysS4 View Post
    Awesome. awesome. awesome.. I can get this for 275 from jmellis Audi in GA, coupon negates the shipping. Thanks everyone for putting up with all my questions, I hope to be as knowledgeable one day as all of you.
    Dec 03 2014
    SF/CA
    amazon this number 8E0 121 251 AJ
    $243 + $20 shipping.
    Feb 18 2014
    Arizona
    Quote Originally Posted by midwestb6
    Quote Originally Posted by Jake@JHM View Post
    just to let you know, the one that ends in -AJ doesn't show up for those of us who have told the site that we only want to see parts for the B6. At first I thought that midwestb6 had posted a dead link above, cuz all I got was a message that said "product not found." Then I noticed that "show b6 only" setting and cleared it out, and after that the link started working. Must be because the fitment chart for that part only lists the b7 even though the title says b6/b7
    Oct 05 2015
    Billings, MT
    Quote Originally Posted by 2004B6S4 View Post
    did the same and that is how I got to see it.
    May 18 2012
    2005 S4
    Portland, OR
    That exact thing is why I stated earlier that I didn't think the auto trans radiators were interchangeable....notably because the B7 radiator for manual trans DOES show up with the B6 filter on. I think it's just a small coding issue on JHM's site; they should have the tiptronic radiator listing show up the same way. I know for a fact that the B7 radiators do work on B6 for manual at least because it's what I personally have.
    Oct 05 2015
    Billings, MT
    Radiator ordered from Amazon, thanks HK! I will post updates on it with modifications, Thanks again for everyone's insights and assistance to this newbie!
    Nov 12 2015
    Oregon
    no problem! i just changed mine a few weeks back. pretty easy. I have a subscription to alldata if you need any book information, just pm me!
    vinny
    My build log
