Results 1 to 22 of 22
Thread: 4.2 specs
    Mar 14 2016
    Atlanta Georgia
    4.2 specs
    Is there anyone here able to tell me the specs on a b5 a4 after doing the swap to the 4.2. Whp? Torque? Top speed? Anything like that. I'm strongly considering this swap
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Check your last 4.2 thread you made.
    Mar 14 2016
    Atlanta Georgia
    Quote Originally Posted by tar View Post
    I'm also looking for 0-60 times as well and I don't recall seeing the torque or top speed though.
    Sent from my LG-H901 using Audizine mobile app
    Jul 07 2009
    Socal/IE
    Search, all depends on what 4.2 what mods/tune and what trans. The info is out there. It's not gonna be fast but should be quick enough. If your serious talk to nollywood or someone with the 4.2 your planning.
    Hint check the tech/projects and build forums for threads.
    Dec 10 2013
    Borden, Ontario, Canada
    300hp. 325lb-ft.
    No one has taken one of these swaps to that track as far as I know
    WHP is often mid 200
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Jul 07 2009
    Socal/IE
    You know wrong then.^
    Guy with orange sticker in Colo tracked his and videos ect. Can't remember name right now
    Mar 14 2016
    Atlanta Georgia
    Thanks. I need to find those threads. Im still trying to learn how to use this app lol my bad
    Nov 03 2011
    All Over!
    There's no easy answer to your query, there are so many variants of the V8, different transmission ratios, final car weight etc. V8 engines can be split into groups.
    077-series 32V.
    077-series 40V.
    079-series 32V.
    079-series 40V.
    077-series 32V
    4.2 V8 32V Quad Cam. 300hp / 400Nm. Audi A8 D2, 1995-1999.
    4.2 V8 32V Quad Cam. 340hp / 420Nm. Audi S8 D2, 1997-1999.
    077-series 40V
    4.2 V8 40V Quad Cam. 310hp / 410Nm. Audi A8 D2, 1999-2002.
    4.2 V8 40V Quad Cam. 310hp / 410Nm. Audi A6 C5, 1998-2003.
    4.2 V8 40V Quad Cam. 340hp / 420Nm. Audi S6 C5, 2000-2003.
    4.2 V8 40V Quad Cam. 360hp / 430Nm. Audi S8 D2, 1999-2002.
    4.2 V8 40V Quad Cam. 340hp / 430Nm. Audi A8 D3, 2003-2005.
    079-series 32V
    4.2 V8 32V FSI Quad Cam. 350hp / 440Nm. Audi A8 D3, 2005-2009.
    4.2 V8 32V FSI Quad Cam. 420hp / 430Nm. Audi RS4 B7, 2006-2008.
    079-series 40V
    4.2 V8 40V Quad Cam. 340hp / 410Nm. Audi S4 B6, 2003-2005.
    4.2 V8 40V Quad Cam. 340hp / 410Nm. Audi S4 B7, 2004-2008.
    I have carried out 6 V8 swaps from 2000-2016, using the 077-series 32 and 40V motors. I can tell you one thing - none have been the same, spec will always vary, so will performance to a degree. Different ECU's with different factory tunes, different transmission (01A / 01E) types. Both 5 and 6-speed transmission can have a mixture of ratios.
    Intake set-ups can also affect how power is delivered. Weight of your car can also vary with factory options, as well as whatever custom deletes you choose - aircon delete being one of the biggest mechanical weight reduction routes you can take.
    I have not really pushed any of my swaps the way I would like to. However this summer, I am driving to Germany via France, so I can push the car on the Autobahn, see what it can do. I am also looking at a weekend at the Nurburgring.
    What year is your B5? Quattro or FWD, 1.8T or V6?
    1986 Type 85 Audi 90 quattro
    Mar 14 2016
    Atlanta Georgia
    077-series 32V.
    077-series 40V.
    079-series 32V.
    079-series 40V.
    077-series 32V
    077-series 40V
    079-series 32V
    079-series 40V
    I drive a 2001 2.8 quattro. I thought about putting a turbo on it but the engine hasnt been taken Care of very well and is over 200k. Plus I like the sound of the v8 better.
    Nov 03 2011
    All Over!
    Quote Originally Posted by kaleil View Post
    The V8 is not everyone's choice. However, it's my favourite. Make the choice that best suits your budget, goal and driving style.
    Mar 14 2016
    Atlanta Georgia
    Thanks.
    Mar 14 2016
    Atlanta Georgia
    Have you done a 2.8t build yet?
    Nov 03 2011
    All Over!
    I haven't even considered a 2.8T build.
    Jul 07 2009
    Socal/IE
    Like no1 has, and I'm talking starting with the a4 block not S4.
    It's just gonna be a money pit unless you actually know cars and don't rely on others for build ideas. Look around you Will find like none. Or alot of threads started by new members that go nowhere and have the same arguements/posts in them.
    In short unless you have alot of money to blow.
    Buy a 1.8t and build that or buy a s4 and build that or 4.2 swap.
    Best logical 30v setup is pes g2 kit.
    Personally if ur working with a 01 30v qm I would find a s6 Or a6 4.2 to swap in and be done with it. I see a6s around me for. Under 1k regularly.
    There is a 4.2 swapped avant for sale for 4500 already done also semi near you
    Veteran Member Three Rings Johns's Avatar
    Oct 03 2014
    Woodstock, CT
    077-series 32V.
    077-series 40V.
    079-series 32V.
    079-series 40V.
    077-series 32V
    077-series 40V
    079-series 32V
    079-series 40V
    The 4.2 Guru
    Mar 14 2016
    Atlanta Georgia
    I just can't seem to get into the avants. As far as the 1.8t goes I have seen too many and don't wish to go that way. I saw the thread on the single turbo based off the s4 build and it didn't seem to be much of a money pit if anything it seemed cheaper than buying the sc. And way more of an outcome. But I do see where you are coming from. I think I will do the v8 considering my b6 is over 200k already.
    Jul 07 2009
    Socal/IE
    Umm cheaper than sc no..
    You gotta read more the sc is a bolt on and done clutch needed.
    For quality stuff for the stk I'd have atleast 7k budgeted. Tuning, clutch, mounts, internals, quality fmic, list goes on. As far as I remember the 034 kit is piping and turbo/wastegate@ 3.2k for jb turbo.
    Mar 14 2016
    Atlanta Georgia
    I was mistaken. Thank you for your input. This has made my descision 100% clear.
    Jul 07 2009
    Socal/IE
    Yep and my v8 guess for budget including a 1k a6 (2001) would be 4000. Keep in mind you can part out the a6 body/interior and your old 30v motor. And that's with all quality parts and some extra for anything that comes up. Can it be done cheaper yes, but I would want to do it right over what's cheapest.
    Hope you go for the v8 swap I plan to eventually and have half the parts sitting for a future car.
    Mar 14 2016
    Atlanta Georgia
    It was close between the v8 and the 2.8t but I do like the sound the v8 makes. but what all would you be including in your budget for the v8?
    Jul 07 2009
    Socal/IE
    New clutch lwfw, euro tune, miltek dps, billet mounts, trans mounts, radiator ect and some left for random maintainance and other things it will need.
    Again nollywood or someone thats done it would know better but 4k seems about right
    Mar 14 2016
    Atlanta Georgia
    Makes sense. Okay I appreciate it.
