Results 1 to 14 of 14
    Established Member Two Rings 029kid's Avatar
    Nov 13 2006
    Audi A4 2017 Avant 2.0 TFSI
    Oslo, Norway
    Exclamation Humming noise from engine room A4 B8 2.0 TFSI ?
    I recently noticed a dark humming noise (drrrrrrrr sound) from my Audi A4 B8 when driving above 30 mph, the noise gets more noticeable when driving 40 mph+.
    The noise surpasses the engine sound itself if I hit the pedal in neutral, when driving 30mph+.
    Could it be the timing belt ?
    If its relevant Audi fixed the car due to oil consumption problems 1 year ago, they changed pistons and rod(s).
    The car has 62.000 miles on the clock.
    Senior Member Two Rings oshwi's Avatar
    Oct 07 2013
    nutley, nj
    These cars have timing chains instead of belts. It could be your wheel bearing as well.
    Veteran Member Four Rings poweredbyaudi7's Avatar
    Dec 19 2006
    996TT
    San Antonio, TX
    Quote Originally Posted by oshwi View Post
    This....when driving at 40+ swerve across the lane, then back a couple of times (make sure no traffic is present). If the sound comes and goes, it is a bearing.
    '14 A4 Q6MT / APR KO4 / AWE / HRE / H&R / 034 Motorsports / P3cars / JHM
    Nov 13 2006
    Oslo, Norway
    ah of course, chains :)
    Ill try that , actually I ran into a giant whole in the road the other day.
    Maybe thats why..
    Veteran Member Three Rings Dannaye's Avatar
    Mar 20 2014
    1968 Oldsmobile 442
    Orlando FL
    Is yours coming from the passenger side? I just recently started hearing the same sound. Like a whistle for me
    Instagram @Dannaye
    Nov 13 2006
    Oslo, Norway
    I cant tell whether or not the noise is coming from the passenger side, it seems somewhere within the engine..
    I just tried to swerve across lanes but the noise did not come and go, still there.
    See videos I just took, its not my exhaust even though it might sound like it.
    https://www.dropbox.com/s/qoexqkur8r...94636.mp4?dl=0
    https://www.dropbox.com/s/tt6rir4hsg...00527.mp4?dl=0
    Veteran Member Three Rings ducati's Avatar
    Sep 02 2008
    Greater Toronto Area
    I say bearings or maybe a rotor is bent?.
    Veteran Member Four Rings lettuce's Avatar
    Jun 19 2015
    Boston
    Quote Originally Posted by 029kid View Post
    Well that's pretty obviously going with speed, not revs, so it wouldn't be anything engine-related.
    It also persisted through depressing the clutch and shifting gears so I highly doubt it's transmission-related.
    My money's on something in your suspension or driveline. If it's coming from your engine bay then the problem is most likely somewhere from your front axles to your wheels.
    Unfortunately that's not my area of expertise so that's as helpful as I'll probably be able to be. Personally I'd start with wheel bearings and CV joints, the former of which is a common issue with these cars.
    B8 A4 - Eurodyne-tuned F23L - 12.6 @ 107 on 93
    Mar 20 2014
    1968 Oldsmobile 442
    Orlando FL
    Quote Originally Posted by lettuce View Post
    Could it be an alignment? I know I'm in need of one. I didn't think until you said suspension issue but I only hear the whistle sound at low speeds
    Instagram @Dannaye
    Nov 13 2006
    Oslo, Norway
    FYI, turns out to be wheel bearings :)
    Got it replaced under warranty today.
    They did however say that one of the brake rotor was worn, and told me it would make a noise when driving.
    1000$ for both, think Ill find a local dealer.
    Thanks all!
    Veteran Member Four Rings pierreb's Avatar
    2020 A4 allroad
    NH
    In the US, a set of OEM front rotors and pads for both sides can be obtained for under $300 total. $1000 is VERY high, even if you don't do the installation yourself.
    Nov 13 2006
    Oslo, Norway
    Norway, nuff said :)
    Im sure a local dealer will do it for 500-700 $ inc installation.
    Oct 07 2013
    nutley, nj
    do it for just the parts. very easy diy
    2013 S5 Prestige
    STOCK. for now.....
    Gone: 2010 A4
    Mods: apikol rear diff mount / Zubehör rear diffuser / Unitronic HFC and DP / solo werks / awe boost gauge / carbonio APR intake
    Repairs done: Engine removed to complete repair Piston rings replaced (stage 1 and stage 2 oil consumption fix) / Wheel bearing(s)/hub(s) replaced / Crankshaft pulley/balancer replaced / Timing chain tensioner update
    Mar 20 2014
    1968 Oldsmobile 442
    Orlando FL
    Thanks all!
    Naw bruh go aftermarket with stop tech. Just got my front and back rotors and pads for 400 shipped. It's all labor that they charge you for. I did my back one time and charged me 700 for rotors and brakes
    Instagram @Dannaye
