Results 1 to 10 of 10
    Nov 10 2015
    Sudbury, ON
    Best place to buy brake calipers/rotors/pads?
    I am upgrading the brakes on my 04 USP 1.8T, I need new rotors/pads anyways, so might as well spend the money wisely.
    I am going for B6/B7 S4 front brakes, and B7 A4 rears. Or will the B6/B7 S4 rear calipers fit with the stock E-brake cables? Is it a pain to get the cables to fit?
    From Rock Auto I can get front S4 calipers, OEM remans by Cardone or Centric (used both before many times, good as original) for $75.00 + shipping. (CDN prices). $42 core cost. Power stops (powder coated Red) are $82 each, $42 core.
    -Rear S4 calipers run $88 each, with a $106 core cost.
    -Rear B7 A4 calipers run $81 each, $98 core cost.
    Is there any direct bolt on brake kits For B6's?
    2004 Audi A4Q 1.8T Ultrasport 6MT
    Frankenturbo'd, Meth, front mount, custom tune, full exhaust, bunch of other crap
    2004 Audi A4 Quattro 1.8T Tip Sport Pkg SOLD
    18" S4 Avus wheels l Eibach Lowering springs l Magnaflow 16601 l 3" TP l Pioneer Double Din l USP Bumper/S4 Door blades/Spoiler l Black on Black
    Feb 12 2008
    Michigan
    your gonna need mounting brackets for both a4 or s4 calipers, I dont think they are included in the A1cardon price.
    you will be more than happy with the S4 front brakes and b7 a4 rear combination, ebrake will work also
    I really like the ecs tuning Geomet slotted rotors, had them over a year and no rust and they are holding up well. for pads I run hawk hps, low dust and great bite
    Nov 10 2015
    Sudbury, ON
    Quote Originally Posted by Fast4esT View Post
    yep they come with brackets! and ecs is a jew when it comes to cdn shipping
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by jesse500 View Post
    the parts you listed are a direct bolt on. I run B6 S4 fronts and B7 A4 rears all of which were low mile take offs. I got Centric rotors and Wagner thermoquiet pads from Rockauto. Call around to some local wreckers, they might have some low mile cars there and sell you the calipers for cheap. You could also do B7 A4 brakes all around since the rotors aren't that much smaller in the front compared to the S4 and probably not have to pay the "S4 tax"
    Nov 10 2015
    Sudbury, ON
    Quote Originally Posted by seanf86 View Post
    Yea I know they are direct bolt on, my only concern is how tight is the Ebrake cable with the S4 rear calipers. Im in northern Ontario, not alot around. Only S4 I could find he wanted $500 for the 4 calipers and brackets, 210K original used. Not much for B7 A4 / S4 parts around here.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    The B7 A4 calipers are the same as the B7 S4 calipers, just with a different mounting bracket allowing the use of larger rotors. ECS sells the bracket as an upgrade to the B7 A4 guys.
    https://www.ecstuning.com/Audi-B7_A4...rmance/ES4525/
    2019 SQ5 Prestige
    Nov 10 2015
    Sudbury, ON
    Quote Originally Posted by texasboy21 View Post
    Good to know! If only one could buy brackets alone
    Established Member Two Rings callmemaurice's Avatar
    Apr 24 2008
    Indy
    Think there would be an issue with returning A4 cores for S4 calipers/brackets?
    '91 Vanagon Carat
    '74 Beetle
    '08 A6 Avant
    Apr 01 2007
    houston texas
    Quote Originally Posted by callmemaurice View Post
    I called a while ago (3 years?) about that B6 A4 for B6 S4 calipers and they would not accept them. It needs to be the same caliper.
    2019 SQ5 Prestige
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    I'm in Canada too and I picked up a full set of used B7 brakes with carriers and dust shields. I will be rebuilding them and hope to find quality OEM seals etc. Not sure if the dealers carry those. Then I plan to get these from Rock Auto:
    - Centric High Carbon Alloy rotors
    - StopTech Street Performance brake pads
    - StopTech Stainless Steel lines
    This kit from RockAuto is $467 plus shipping (almost another $100) plus taxes.
    They also sell this Power Stop kit for the same price: http://www.rockauto.com/en/moreinfo....849&cc=1434142
    I'm not too keen on drilled & slotted rotors. I would like slotted only, but this is a daily driver and will not see any track duty, so blanks are just fine.
    Hope this helps in your search and do post back on what you decide to get.
