Results 1 to 18 of 18
    Established Member Two Rings Stan77's Avatar
    Nov 24 2014
    Russian Empire
    Cete Automotive lowering module experience
    I've choosed cete automotive module 'cause it provides much more feautures instead of H&R and for lower price. The price is 999eur for module + harness, but if you're live outside the Germany you can get it for VAT-free price (-16%).
    First of all, module works with EVERY A/S/RS 6-7 pre-FL and FL, it comes with wi-fi app control and provides DIFFERENT settings for every preset. So basically if you want to go -30mm for dynamic and stock for comfort - no problem, so it means that lift option stays unaffected if you're setting up stock height on a just single preset. and you can raise your car to the max for climbing curbs for example and suspension height becoming fully controlable by app in your phone via wi-fi.
    Basicaly that's all )
    Ah yea, btw, app have option "Show mode", for all of you who like some showoff, and you can go on a max lowering, but it's not recommendeв to drive with this mode, but still possible.
    My car can go to this level. Stocky 19"sh on winter isn't so cool, better pics coming with spring when it'll finally come to Moscow.
    In my opinion it's the best solution for the lowest price for an ajustable ASC module on the market.
    And some funny vid from a manufacturer. Sorry for the soundtrack )
    A7 '13 TDI, Revo Technik chip, 300hp/640Hm. - SOLD
    A7 '15 TDI Facelift, Revo Technik stage2, Straight pipe cat-back, RS7 intake, Wagner FMIC, Cete ASC Module, Alcon 6-pot 380x32mm BBK - 310hp/690Hm - Current
    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    How do I get this in the states? Any links for me?
    Nov 24 2014
    Russian Empire
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    i just got mine and so far im not very happy, it set off pretty much every system fault, ie: sport diff, power steering, adaptive suspension, adaptive headlights etc. even after removing the module the faults remain and will not clear
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
    Feb 23 2013
    2016 Audi S6; 2015 Toyota 4Runner TRDP;2013 Toyota Prius; 2014 Yamaha FZS Waverunner
    Sinking Spring, PA
    I had to watch that video in mute...music was terrible!!
    2016 S6 Prestige | Sepang Blue | Black Optics | Driver Assistance | Sport Pkg | B&O | Comfort Seating Pkg | Carbon Inlays | Night Vision | Alcantara Headliner | OEM RS6 Grill | OEM RS6 Carbon Fiber Mirrors | AG M580 Brushed Tinted Clear | AWE Touring Exhaust | AWE S-Flo Intake | XPEL Stealth Wrap | APR Stage 2 ECU/TCU Tune | APR Downpipes |IG:Chudiddy_S6
    Sep 10 2015
    VA
    Quote Originally Posted by richib86 View Post
    Is there a US reseller now? There was no back up in the US last I looked so was worried if something like this would happen. Were you running VCDS lowering before installing this?
    Nov 05 2006
    Fair Lawn
    Quote Originally Posted by Barritia View Post
    yes, i brought the car to factory height before plugging everything in, everything seems sorted out for now as far as system faults. looks like one of the connectors that gets piggy backed into the car is pinned a bit differently in europe so the power, ground, and signal wire were not being hooked in properly with the cars systems. CETE is very responsive as far as support goes considering they are in germany. It's after 8pm there and they are going back and forth with me as we speak to sort everything out. I'll give it another go tonight and re-pin the supplied connector since im a gluten for punishment
    Nov 05 2006
    Fair Lawn
    Fixed! turns out their is a very specific order in which things need to be unplugged and plugged back in. pins were fine. The customer support from Germany was absolutely fantastic, way better than many domestic companies.
    Feb 11 2013
    C7 S6
    North San Diego
    when you get to speed, 70+, do you get an error code saying the car is too low and it's adjusting the suspension? I'm lowered on the H&R module, 40mm, and get this every time I drive. just wanted to know if this module somehow finds a way to defeat that. thanks!
    JOEY | '10.5 STi | '13 S6
    Cete | EuroCode | HRE | AWE | Deval | BFI | 034 Motorsports
    Nov 05 2006
    Fair Lawn
    Idk yet. We will see. Haven't driven it yet. I decided to do the install last night around midnight and limped to work and dropped it off at my service shop. I do have this feature where I can adjust the speed setting where it raises.
    Veteran Member Four Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    This particular lowering module got my attention aswell.
    Interested in knowing if for example you could automaticly set the car to (adjusted) showmode preset each time you shutoff the engine/getout car and it would automaticly raise to last mode again when you turn on the car. Is this possible?
    Taking it a step further with the app itself, but it would be great if they linked gps data and you could set predefined ride modes to saved locations (for daily routes with speedbumps).
    S6 C7 avant '13 estoril | ceramics | DS1 OTS stage 2 | Lightvan | Milltek non-res X pipe | TS1 | 034 trans-diff mount | CETE ASC-EVC | FL tails & dynamic signals | Thermo ZO catless DP | SRM a2a | BC Forged 20" HCA162S | custom spoiler sideskirts | Maxton front lip & diffuser | Armor heatshield mani-turbo-dp | B&O led tweets (repli) | Forge boost hoses | FIS mmi gauges | R8GT steeringwheel | alcantara interior | SRM inlets | R8 exclusive seats | JXD driveshaft | Tial WG
    Feb 11 2013
    C7 S6
    North San Diego
    ah ok, keep us posted, would like to know if it would be worth it to sell the h&r module and get this one for that hellaflush parking lot look lol.
    Veteran Member Four Rings VeryBadman's Avatar
    Jun 23 2012
    2017 BMW X1
    Bay Area CA
    Quote Originally Posted by JoeGie View Post
    +1 and maybe if it's not going to take too much time, it would be nice to see a write up for installation steps as well.
    2020 ///M340i xDrive Mineral White Fully Loaded, IND Front Reflectors Delete Kit
    Remaining Parts: Neuspeed RSe102 19x9 et45 in Texas Grey
    Other: 2017 BMW X1
    Throwbacks: 2018 Audi TTRS, 2014 Audi RS7, 2013 Audi S6, 2011 Audi S4, 2008 Audi A4
    Nov 05 2006
    Fair Lawn
    Install is pretty straight forward(varies worldwide though since they have options we don't)
    This piggy backs in-line with these connectors in the trunk, purple goes to purple and the grey 9 pin connector plugs into the yellow
    Then the two wire leads on the cete harness get wired into the CAN BUS harness
    This is in show mode. As low as it will go. I still need to dial everything in and fine the best ride heights for the different settings(comfort, dynamic, auto)
    Feb 01 2016
    Encinitas, CA
    Show mode looks pretty good! I wonder how many millimeter drop that is?
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
    Sep 07 2010
    Belgium
    Looking good :).
    *checked with them over facebook and suggested the 'showmode' engine off - 'last ride mode' engine on (automaticly over module).
    Also suggested the integration of gps based presets, would be super handy if you could save ride modes based on gps location for speedbumps or poor roads and the app/module loads them automaticly when user drives near the preset locations.
    They appreciated the suggestions but i dought it would ever be implanted.
    Personally i bought car specificly with adaptive airride as i got tired of bone hard KW v1 with low profile tires, well loved them but speedbumps and poor road at times....not a good combination.
    Call me lazy but the automatic gps ride modes would be super imho :).
    Anyway, added to mod wishlist!
    Nov 05 2006
    Fair Lawn
    Quote Originally Posted by Djpeaksd View Post
    60mm
    Veteran Member Four Rings MadAboutCars's Avatar
    Aug 27 2015
    MY18 Audi RS6 P, MY18 Audi SQ5,MY16 Audi S6 (sold), MY12 Audi Q7 4.2L TDI S-line (sold)
    New Zealand
    I really like the idea of an ignition off settable height and a settable height for above a certain speed. I was hoping it had this already.
    2018 Audi RS6 Performance - Floret Silver, Titanium styling package, 21" titanium 5 V spoke wheels, Dunlop SP Sport Maxx GT 285/30/21, Black sports seats, Carbon inlays, Sports diff, Sport exhaust, Matrix LED headlights, 360 camera, Head up display, Active lane/side assist with adaptive cruise control, Park assist, Privacy glass, Electric tailgate with foot open
    Mods: Dura-Seal exterior/interior, Audi Sport door lights
